Epson Pro EX9240 Projector Review: Is This 3LCD Model the Right Fit for Your Needs?
windstri85
First Impressions​
Upon first glance, this projector is sleek and modern, designed to fit seamlessly into any setting, whether it's a classroom, outdoor teaching space, or home theater. Its compact size makes it easy to transport, and its aesthetic doesn’t scream “tech gadget,” allowing it to blend in effortlessly with various environments. The placement of ports, while initially confusing, is well thought out for users who value convenience and minimalism in design.
Epson Pro EX9240 Projector​
$849.99​
Business, Home Cinema​
Pro EX9240 projector, power cable, projector remote control, batteries, Quick Start Guide​
Highlight
GET MORE, SPEND LESS: One Caseta smart switch can control many bulbs at once; Make many bulbs smart, even your existing bulbs. Get smart control of multiple styles of LED, incandescent, and halogen bulbs
Stunning image quality — amazing Full HD 1080p resolution delivers crisp text and images; perfect for displaying professional-quality presentations, video and more
Amazing brightness — 4,000 lumens of color and white brightness (1) ideal for displaying large-group presentations, spreadsheets and videos, even in well-lit rooms
Get up and running in no time — with easy image adjustments and convenient control like 1-1.6x optical zoom, horizontal slider and auto vertical correction
Wireless connectivity — including screen mirroring with Miracast, plus two HDMI ports, so you can easily video conference and connect streaming devices, including Fire TV, Apple TV, Roku and Chromecast (2)
Built-in picture skew sensor — automatically analyzes the picture and instantly corrects the vertical keystone to help square the image
N/A - 300 Inches​
1.32 Meters - 2.14 Meters​
Viewing Experience
The viewing experience with this projector is fantastic, especially given its brightness. It performs admirably even in well-lit environments, ensuring that every detail is clear for my audience. The full HD resolution is a significant upgrade from my previous model, and the split-screen feature adds versatility for presentations. However, the built-in audio leaves much to be desired; while it can project sound adequately in smaller spaces, I found myself relying on Bluetooth speakers for a better audio experience.
380 Watts​
16 watts​
HDMI
Hardware Connectivity​
HDMI
Portable, Bluetooth​
12.2"L x 11.2"W x 3.5"H​
Setting up the projector was relatively straightforward, although there were some initial hiccups due to the configuration of HDMI ports and the keystone adjustments, which weren't as intuitive as I hoped. The projector boasts built-in WiFi for seamless connection with devices, which is a major plus, although I did encounter some compatibility issues with my MacBook that required some patience and assistance from technical support. Overall, once the setup was complete, the projector was ready to go, proving to be a reliable tool for my teaching needs.
User Feedback​
• Bright and sharp image quality, even in daylight
• Easy to set up and connect with various devices
• Lightweight and portable
• Effective split-screen feature
• Lacking audio output options for external speakers
• Built-in speakers are insufficient for larger rooms
• Some initial setup confusion with HDMI ports and keystone adjustments
• The fan can be quite loud, potentially distracting during use
Overall, I am quite satisfied with this projector. It has exceeded my expectations in terms of brightness and clarity, making it a solid choice for both professional and casual use. While there are minor drawbacks, such as the audio limitations and some setup challenges, the quality of the image and ease of use far outweigh these issues. This projector is an excellent investment for anyone looking for a reliable and high-performing projection solution.
Roy_Knable
For the price of this projector, it’s a pain to connect external speakers. The built-in speaker just doesn’t cut it for bigger rooms. They really should’ve added an audio out port or a headphone jack.
I'm super happy with my purchase! A few months in, and I can confidently say it's totally worth it. This Epson projector is the best bang for your buck. Don’t skimp out—just get this one and you’ll love it! I'll update later! :)
