Epson Pro EX9240 Projector Review: A Top Choice for 3-Chip 1080p Performance?
mufcroberts
First Impressions​
The projector has a sleek and professional design that fits well in both office and home settings. It feels sturdy and well-built, which adds to its overall appeal as a serious piece of office equipment. The compact size allows for easy transport and setup, whether I’m moving it between a courtroom or my living room.
Epson Pro EX9240 Projector​
Highlight
Built-in picture skew sensor — automatically analyzes the picture and instantly corrects the vertical keystone to help square the image
Incredible sound — built-in 16 W speaker for astounding audiovisual experience and incredible sound quality right out of the box
True 3-Chip 3LCD technology — displays 100% of the RGB color signal for every frame, providing outstanding color accuracy while maintaining excellent color brightness, without any distracting “rainbowing” or “color brightness” issues seen with other projection technologies
Get up and running in no time — with easy image adjustments and convenient control like 1-1.6x optical zoom, horizontal slider and auto vertical correction
GET MORE, SPEND LESS: One Caseta smart switch can control many bulbs at once; Make many bulbs smart, even your existing bulbs. Get smart control of multiple styles of LED, incandescent, and halogen bulbs
Wireless connectivity — including screen mirroring with Miracast, plus two HDMI ports, so you can easily video conference and connect streaming devices, including Fire TV, Apple TV, Roku and Chromecast (2)
Viewing Experience
The viewing experience has been largely positive, with bright and clear images even in well-lit environments. At 50% brightness, the exhibits displayed during my courtroom trial were easily readable, which is crucial for my work. The projector also performed admirably in bright rooms, making it suitable for lectures and presentations. However, I found the internal speaker to be just adequate, and while the picture quality was fantastic, the noise from the fan detracted significantly from the overall viewing experience, especially when trying to hear audio.
Setting up the projector was straightforward, especially when I read the manual thoroughly beforehand. I was able to connect it to multiple devices via HDMI and wireless options without too much hassle. The "Quick Corner" feature for image alignment was particularly useful, allowing me to adjust the projection to fit my screen perfectly, even in less-than-ideal setups. However, I encountered some confusion with Wi-Fi connectivity, where it only worked seamlessly with one of my laptops.
User Feedback​
• Excellent brightness and resolution, suitable for various lighting conditions
• Quick Corner adjustment feature for easy image alignment
• Well-suited for presentations and office use
• Affordable price for the quality offered
• No audio output, requiring workarounds for external sound systems
• Loud fan noise, which can be distracting during use
• Built-in speaker is subpar for larger spaces
• Confusing setup for wireless connectivity
Overall, I feel that this projector is a great value for its intended use in professional settings, such as classrooms and offices. It excels in brightness and image quality, making it a reliable choice for presentations. However, its limitations in audio options and the distracting fan noise make it less suitable for home theater use. If audio quality is a priority, I would recommend looking for alternatives that provide better sound output. In summary, for the price and performance in a business context, this projector is hard to beat, but it may not meet all expectations for home entertainment.
horizon936
I've had a bunch of projectors, but I usually go for the cheaper ones. This one, though, has the best picture for the price! It's super bright and sharp. Once I've used it more, I'll come back and update this review.
