Epson Pro EX11000 vs PowerLite 2250U vs L265F: Which 3LCD Projector is the Right Choice for Your Needs?
ApaHualpa
Epson Pro EX11000​
Epson PowerLite 2250U​
Epson PowerLite L265F​
Price​
$1299.99
$1558.98
$1268.9
Business​
Security​
Digital Signage, Conference Room, Presentation, Class Room​
Warranty: 1-year limited warranty, full-unit replacement, lifetime technical phone support
Display Size: Up to 300", 1080p resolution, 16 times larger than 75" flat panel
Light Source: High-performance laser, 20,000 hours maintenance-free
Brightness: 4,600 lumens color and white brightness
Setup Ease: Easy image adjustments, 1 –1.6x optical zoom, horizontal slider, auto vertical correction​
Lamp Life: Up to 10,000 hours in ECO Mode
Contrast Ratio: 15,000:1
Remote Management: Software for remote monitoring and control; compatible with Crestron RoomView
Image Size: Bright, widescreen images up to 300"
Resolution: WUXGA (1920 x 1200); Full HD 1080p support
Wireless Networking: Optional module; enterprise-level security; compatible with WEP, WPA, WPA2-PSK, WPA2-EAP​
Interface: HDMI
Contrast Ratio: 2,500,000:1
Resolution: Full HD
Image Quality: Clear and crisp with vivid colors
Connectivity: USB port for instant projection from PC/MacBook
Color Technology: 3LCD, 3-chip​
Side-by-Side Comparison​
Epson Pro EX11000​
31 Inches - 310 Inches​
N/A - 300 Inches​
N/A - 309.96 Inches​
1.32 Feet - 2.12 Feet​
1.46 Meters - 8.95 Meters​
4.9 Feet - 30.6 Feet​
Up to 100,000:1​
15000:1​
2,500,000:1​
Display Resolution​
1920 x 1080 Pixels​
1920 x 1200​
1920 x 1080 Pixels​
1920 x 1200​
4600 Lumen​
4600 Lumen​
Laser​
Picture Quality Enhancement​
Epson Pro EX11000​
272 Watts​
300 Watts​
Light Source Life​
20000 Hours​
10000 Hours​
20000 Hours​
Button Control​
App​
Mount Type​
Tabletop Mount​
Tabletop Mount​
Ceiling Mount​
Noteworthy Features​
Built-In Speaker, Lightweight, Built-In Wi-Fi​
5,000 lumens of color and white brightness, Full HD 1080p resolution; project up to 130" 20,000-hour laser light engine with no lamps, HDMI connections, HDBaseT and optional 5GHz wireless connectivity Built-in edge blending and split screen features​
Ceiling Mountable​
Connectivity​
Epson Pro EX11000​
Wi-Fi, Ethernet, HDMI​
USB, HDMI​
Wi-Fi, USB, Ethernet, HDMI​
Hardware Connectivity​
VGA, USB, Ethernet, HDMI​
USB, HDMI​
Television, Laptop, Smartphone, Tablet, Gaming Console​
PC, Mac​
Measurements​
Epson Pro EX11000​
Dimensions L x W x H​
4.1"L x 12.8"W x 11.7"H​
Item Weight​
9.5 Pounds​
10.2 Pounds​
9.5 Pounds​
Product
PROS AND CONS​
Epson Pro EX11000​
Pros
• Excellent picture quality with vibrant colors
• High brightness (4600 lumens) suitable for well-lit environments
• Long lifespan of approximately 20,000 hours without the need for bulb replacement
• Easy installation and setup
• Smooth performance with no noticeable ghosting during fast movements
• Good contrast, especially for sports and general viewing
• Price and quality ratio makes it a great option for home use
Cons
• Limited refresh rate of 60hz, which may not satisfy gamers
• Contrast not as high as some premium projectors
• Not ideal for videophiles seeking intricate details in dark scenes
• Blacks may appear flat in certain conditions
• 4k capability not included at this price point
Pros
• Brightness of 5000 lumens ensures visibility in well-lit environments
• Accurate color reproduction enhances image quality
• Reliable performance for presentations and video content
• Portable design allows for easy travel with suitable case
• Suitable for various settings, including churches and large rooms
• Positive feedback on image quality from users
Cons
• Larger size compared to typical mobile projectors may affect portability
• Requires careful setup to avoid direct lighting on the screen
• May not be as cost-effective for smaller venues needing less brightness
Pros
• Extremely bright at 4,600 Lumens, suitable for large screens up to 14 feet
• Crisp picture quality with a dynamic contrast ratio of 2,500,000:1
• Laser technology enhances durability and performance
• Features image correction (Arc Correction) for curved screens
• Compact and lightweight design makes it ideal for ceiling mounting
• Comes with a 3-year warranty for peace of mind
• Easy to program and adjust settings
Cons
• None mentioned in the description
