Bellmeister
- 1 Introduce
2
Side-by-Side Comparison
- 2.1 Display
- 2.2 Features
- 2.3 Connectivity
- 2.4 Measurements
- 3 Conclusion
Parameter | Epson Pro EX10000 Projector | Epson Pro EX9240 Projector | Epson Pro EX7280 Projector | Epson Pro EX7260 Projector |
Picture | ||||
Price | $1480 | $789.99 | $649.99 | $654.85 |
Recommended Uses | Business | Business, Home Cinema | Office, Home | Education, Home Cinema, Business |
Highlight |
Screen Size | N/A - 300 Inches | N/A - 300 Inches | 33 Inches - 320 Inches | N/A - 300 Inches |
Throw Distance | 1.33 Meters - 2.16 Meters | 1.32 Meters - 2.14 Meters | 1.3 Meters - 1.56 Meters | 1 Inches - 1 Inches |
Contrast Ratio | up to 100,000:1 | 16,000:1 | 16000:1 | 15000:1 |
Display Resolution | 1920 x 1080 | 1920 x 1080 | 1280 x 800 | 1280 x 800 |
Native Resolution | 1920 x 1080 | 1920 x 1080 | 1280 x 800 | 1280 x 800 (WXGA) |
Brightness | 4500 lumen | 4000 lumen | 4000 lumen | 3600 Lumen |
Display Type | LCD | LCD | LCD | LCD |
Picture Quality Enhancement | 3LCD | 3LCD | 3-chip 3LCD technology, dynamic contrast ratio adjustment | 3LCD, 3-chip technology |
Video Encoding | H.265 | H.265 | H.264, H.265 (HEVC), or VP9 | - |
Lamp Wattage | 16 Watts | 380 Watts | 200 Watts | 200 Watts |
Light Source Life | 20000 Hours | - | 4000 Hours | 6000 Hours |
Controller Type | Button Control | Button Control | Button Control | Button Control |
Control Method | Remote | Remote | Remote | App |
Mount Type | Tabletop Mount | Tabletop Mount | Tabletop Mount | Tabletop Mount |
Noteworthy Features | Portable | Portable, Bluetooth | Built-In Speaker | Portable |
Connectivity
Connectivity Technology | HDMI | HDMI | USB, HDMI | MHL, Ethernet, HDMI |
Hardware Connectivity | HDMI | HDMI | HDMI, USB 2.0 | HDMI |
Compatible Devices | Television, Speaker, Laptop, Fire TV, Apple TV, Roku, Chromecast | Television, Gaming Console, Speaker, Laptop, Smartphone, Tablet | Laptop, Smartphone, Tablet, Speaker | Smartphone, Tablet |
Measurements
Dimensions L x W x H | 12.8"L x 11.8"W x 4.1"H | 12.2"L x 11.2"W x 3.5"H | 15.5"L x 15.2"W x 6.75"H | 11.9"L x 9.9"W x 3.6"H |
Item Weight | 14.15 Pounds | 7.7 Pounds | 8.47 Pounds | 5.5 Pounds |
Product | PROS AND CONS |
Epson Pro EX10000 Projector | This projector is used for off-campus teaching, and it’s been a real game-changer. Connecting it wirelessly to my laptop was a breeze—no hassle at all. Then, when I switched to HDMI and USB connections, everything worked flawlessly, offering great video and audio quality on both. I’ve only had it for a month, but so far, it’s exceeded my expectations. I can jump onto any site without worrying about image quality or room lighting, which is a huge relief. Setting it up was fairly straightforward, with plenty of customizable options to fine-tune its position to perfection. There’s just one quirk: when running directly on a network (whether wireless or wired), you’ll need an app in Chrome to project from a LAN. It takes a bit of extra setup initially, but once it’s done, it’s smooth sailing—just keep Chrome running in the background. Once you're past that initial hurdle, the projector is simple to use, and I love the flexibility it gives me for both teaching and presentations. |
Epson Pro EX9240 Projector | This projector is incredibly user-friendly and even comes with its own carrying case, making it easy to take on the go. Whether I’m projecting onto a wall or using a screen I purchased for teaching, it’s straightforward to set up. The image quality is sharp, and resizing the display is effortless with a simple dial on the projector. That said, a few drawbacks are worth noting. As others have mentioned, it’s significantly louder than my older projector—about twice as much. It’s not a dealbreaker, but it's definitely noticeable. The other issue is with HDMI connectivity: when connected to my computer, it forces the desktop to recognize the projector as a secondary monitor, even when the projector is switched off. It stays "active" as long as the HDMI cable is plugged in, and the desktop continues to think there’s an extra monitor, even if there’s no power running to the projector. It’s a little annoying, especially if you prefer to work without an additional display, but it's manageable once you’re aware of it. |
Epson Pro EX7280 Projector | This projector packs a serious punch, and given its price, it better! One of its standout features is the incredibly bright bulb, which ensures that even during the day, you can still enjoy a clear and vibrant image on the screen. However, this is a large projector, so if you're tight on space, it's worth measuring your setup before pulling the trigger. The picture quality is crisp, and it offers multiple media options for versatility. The onboard speakers are a nice bonus—while they provide decent sound, they're not exactly top-tier, but they get the job done if you’re not looking to invest in external audio right away. One limitation to keep in mind: it only has one HDMI port (plus an old VGA port), which could be restrictive for some setups. If you need more HDMI connections, an HDMI switch is a simple workaround. The projector does generate quite a bit of heat, though it’s not dangerously high. Just be sure to keep the vents clear, as obstructing them could lead to overheating and potentially damage the device. Despite these quirks, the overall performance and value make it a solid choice. |
Epson Pro EX7260 Projector | This projector ticks all the boxes for my needs. It provides enough brightness to perform well in a well-lit room, and the color rendition is solid. Setup is a breeze, and though it’s not the most compact in its class, I don't mind since I only move it around and don’t travel with it. It operates quietly and stays cool, even after extended use—no overheating or uncomfortable warmth. You can easily shut it down and store it in its carrying case immediately. Both HDMI and wireless connections have been hassle-free so far, and the built-in speaker is more than adequate for small room presentations, providing decent sound for narration. However, I've encountered an issue where the projector’s manual menu sometimes doesn't appear on the screen. |
