Epson PowerLite 2250U vs L265F: A Comparative Look at Two 3LCD Projectors for Your Needs
Harry Williams
Epson PowerLite 2250U​
Epson PowerLite L265F​
$1498.87​
$1330​
Security​
Digital Signage, Conference Room, Presentation, Class Room​
PowerLite 2250U Projector, Remote control, Batteries, Power cable, Computer cable (VGA), CD with User Guide Link, Warranty card, Quick Setup Sheet​
Power cord, Cable cover, Two (2) AA batteries (for remote), PowerLite L265F standard-throw laser projector, HDMI Cable, Projector remote control​
Split Screen (4): Simultaneously project two images from different sources
Remote Management: Remote monitoring and control via included software; compatible with Crestron RoomView
Portability: Small size for travel
Connectivity: 2x HDMI, MHL, VGA, RJ-45, and more
Color Technology: 3LCD, 3-chip for 3x Higher Color Brightness and up to 3x Wider Color Gamut
Lamp Life: Up to 10,000 hours in ECO Mode
Contrast Ratio: 15,000:1 for sharp detail and clarity in text and graphics
Display Technology: 3LCD, 3-chip
Brightness: 4600 lm
Resolution: Full HD
Contrast Ratio: 2,500,000:1
Connectivity: HDMI, USB port for PC/MacBook
Unboxing Experience​
Epson PowerLite 2250U:​
The Epson projector boasts a robust design that aligns well with its purpose as a professional-grade device. It's larger than typical portable projectors, giving it a sturdy presence, but it still manages to look sleek and modern. The aesthetic is functional; the controls are intuitive, and the overall build quality feels solid, which is reassuring when investing in a product for regular use in a church or event setting.
Epson PowerLite L265F:​
The projector has a sleek and modern design that is not only visually appealing but also compact and lightweight, making it an excellent choice for ceiling mounting. Its packaging was impressive, with Epson ensuring that the unit was well-protected during transit, which speaks to the brand's attention to quality and customer satisfaction. Upon unboxing, I found the projector to be in perfect condition, ready for immediate setup.
N/A - 300 Inches​
N/A - 309.96 Inches​
1.46 Meters - 8.95 Meters​
4.9 Feet - 30.6 Feet​
15000:1​
2,500,000:1​
1920 x 1200​
1920 x 1080 Pixels​
1920 x 1200​
4600 Lumen​
The viewing experience with this projector has been impressive, particularly in bright environments. Even when the brightness is reduced to 35%, the image remains sharp and vibrant, making it perfect for displaying sermon graphics and videos. The clarity of the picture is commendable, with no distortion, which is crucial for conveying text and detailed visuals. The brightness level, rated at 5000 lumens, ensures that presentations can be viewed clearly without dimming the lights, even in an auditorium setting with ambient light.
The viewing experience has been nothing short of phenomenal. With a brightness of 4,600 lumens and a dynamic contrast ratio of 2,500,000:1, the images are incredibly vivid and clear, making it perfect for large venues like the church where I use it. The projector easily handles screens up to 14 feet from a distance of 15 to 20 feet, and the picture quality is a huge upgrade from our previous projector, ensuring that every detail is crisp and vibrant.
• **Pros**:
- Super bright and clear image quality
- Compact and lightweight design
- Easy setup and programming
- Excellent for large screen displays
- Image correction feature enhances viewing experience
• **Cons**:
- None noted during my use
Ceiling Mountable​
300 Watts​
10000 Hours​
20000 Hours​
Button Control​
App​
USB, HDMI
Wi-Fi, USB, Ethernet, HDMI
PC, Mac​
429 watts​
272 watts​
Mount Type​
Tabletop Mount​
Ceiling Mount​
20.9"L x 15.1"W x 8.1"H​
4.1"L x 12.8"W x 11.7"H​
Setting up the projector was a breeze, fitting seamlessly into our existing ceiling mount without any need for complicated adjustments. The ease of use continues with straightforward controls and settings that allow quick adjustments to brightness and image quality. Although it emits a noticeable noise upon startup, this quickly subsides, making it manageable for most environments. The projector's compatibility with a range of setups, including direct wall projection, is a significant plus, especially in venues that may not have an ideal screen.
Setting up the projector was a breeze; I found it incredibly user-friendly. The programming options are straightforward, allowing for easy adjustments to fit various screen sizes and distances. I was particularly impressed with the image correction feature called Arc Correction, which worked seamlessly with my 110-inch curved screen. This functionality is a game changer for achieving the perfect display without hassle.
• Excellent brightness and clarity, even in well-lit environments.
• Easy setup and compatibility with existing mounts.
• Good color accuracy and sharp image quality.
• Affordable compared to high-end options for similar performance.
• Quiet operation after initial startup noise.
• Larger size may not suit all portable needs.
• Some users reported reliability issues after limited usage.
• Customer support experiences varied significantly.
• Initial noise during startup can be distracting.
Overall, the Epson projector has exceeded expectations in terms of performance and image quality, making it a valuable asset for church services and events. While there are some reported issues with reliability and customer support, the projector's brightness, clarity, and ease of setup make it a strong contender in its price range. For those needing a dependable solution for presentations in bright spaces, this model is worth considering, but potential buyers should also weigh the experiences of others regarding long-term reliability.
Overall, I am extremely satisfied with my purchase of this projector. It has exceeded my expectations in brightness and clarity, making it a significant upgrade for both my church and my event production needs. The ease of setup and the additional features like Arc Correction make it a standout choice in the market. I would highly recommend it to anyone looking for a high-performance projector that delivers exceptional results.
OneTimeSE
Just got my Epson PowerLite 2250U and on the second use, an alarm won’t shut up unless I hit the AV Mute or slide the projector. Tried to return it, but they expect me to pay for shipping. What a joke!
laxhockey11
Epson PowerLite L265F is a beast for events! It blasts bright images on 14-foot screens from 15 to 20 feet away, no problem. Plus, it's a breeze to set up and tweak!
