Epson Home Cinema 4010 Projector Review: Full Feature PRO-UHD with Impressive HDR Performance
First Impressions​
When I first unboxed the Epson 4010, I was struck by its substantial size and robust design. At 24 pounds and measuring 20 inches wide, this projector certainly commands attention. The heft and build quality give it a feeling of durability, suggesting it could withstand years of use. Its sleek aesthetic, combined with a metallic finish, fits well in a dedicated home theater or even a living room setting. While its bulk could be an issue for some, I appreciate the solid construction that gives me confidence in its longevity.
Epson Home Cinema 4010 Projector​
$1795.04​
Home Cinema, Business​
Power cord, Quick Setup Guide, 2x HDMI cable clamps, Home Cinema 4010 projector, Remote control with AA batteries​
Highlight
EXTREME COLOR GAMUT – One of the first commercially available home theater projectors capable of displaying the full three dimensional DCI P3 (4) color space. This extreme color performance is 50% wider than typical 1 Chip Rec. 709 projectors and allows for a truly professional level of color accuracy
OUTSTANDING BRIGHTNESS – Capable of displaying 4K content at an incredible 2,400 lumens for both color and white brightness (2). This not only provides for a wider performance envelope but allows for an exceptional HDR performance
3 AXIS MOTORIZED PRECISION LENS – After installation, you can shift the lens 47% left or right on the horizontal axis and 96% up or down on the vertical axis. You can also set the zoom and focus, then store all the settings in one of ten lens memory presets
DIGITAL IMAGING PROCESSING – Realtime 12 bit analog to digital video processing for smooth tonal transitions, while helping to eliminate banding, blocking, and other compression artifacts from the final visual performance. This powerful processor faithfully reproduces the source material the way it was intended to be shown
EPSON PRECISION LENS – Designed for zero light leakage, all Epson Precision Lenses utilize a proprietary 15 element precision glass structure for outstanding image clarity and edge to edge focus uniformity
HDR PROCESSING – Full 10 bit HDR (3) color processing accepting 100% of the HDR source information to faithfully reproduce HDR content for an exceptional visual performance.Lamp type: 250 W UHE
50 Inches - 300 Inches​
1.35 Feet - 2.84 Feet​
200000:1​
4096 x 2160​
2400 Lumen​
Viewing Experience
The viewing experience with the Epson 4010 has been nothing short of astounding. The image quality is vibrant, with colors that pop and a brightness that holds up even in well-lit rooms. While the black levels aren’t as deep as I’d like, they still surpass what I'd expect from a typical 1080p projector. Upscaling Blu-ray content to near 4K resolution has been impressive—details are sharp enough that I can see individual pores on actors' skin. However, I did notice that it only supports 4K HDR at 30Hz, which might be a limitation for gamers looking for 4K at 60fps.
Button Control​
250 Watts​
250 watts​
Wireless, HDMI
Hardware Connectivity​
USB, HDMI
DCI-P3 Color Space, 3LCD Technology, No Rainbowing​
20.5"L x 17.7"W x 7.6"H​
Setting up the Epson 4010 was surprisingly straightforward, thanks to the Quick Setup instructions provided. I was able to place it on a custom-built shelf I designed for my home theater, eliminating the need for a complicated projector mount. The lens shifting feature made aligning the image to my screen a breeze, allowing for a perfect fit without much hassle. However, I did have to ensure all my equipment was 4K compatible, and I recommend getting a good HDMI 2.0 cable for optimal performance, especially if the distance from the receiver exceeds 10 feet.
User Feedback​
- Excellent picture quality with vibrant colors.
- Easy setup with lens shifting capabilities.
- Bright enough for daytime viewing.
- Quiet operation compared to previous projectors.
- Good customer service experience when issues arose.
- Large and heavy, potentially difficult to mount.
- Requires an external sound system; no built-in speakers.
- Limited to 4K HDR at 30Hz, not ideal for gaming.
- Some users reported reliability issues, including fan noise and image defects.
Overall, I am extremely satisfied with the Epson 4010. It has dramatically improved my home theater experience, providing a picture quality that rivals what I’d see in a cinema. Despite its size and some connectivity limitations, the benefits far outweigh the drawbacks. While I have encountered a few reliability concerns mentioned by other users, my experience has been largely positive. I believe this projector is well worth the investment for anyone serious about creating their own theater-like setup at home.
