Epson Home Cinema 3800 vs 8350 vs 2350: What’s the Difference for Home Cinema and Gaming Projector Performance?
Epson Home Cinema 3800​
Epson PowerLite Home Cinema 8350​
EPSON Home Cinema 2350​
Price​
$1679.99
$1499.99
$1253.03
Home Cinema, Gaming​
home entertainment, watching movies, sports, and playing video games​
Gaming​
HDMI Support: Full 18 Gbps HDMI 2.0, compatible with all color formats, depths, and spaces; supports 4K HDR at 60 Hz
Lens Type: Epson Precision Lens with multi-element glass for clarity and edge-to-edge focus; features vertical and horizontal lens shift
Brightness: 3,000 Lumens for color and white brightness; contrast ratio up to 100,000:1
Video Processing: Real-time 12-bit analog-to-digital processing for smooth tonal transitions; reduces banding and blocking
Audio: Built-in stereo speakers with dual 10 W system; apt Bluetooth for wireless connectivity to external sound systems​
Contrast Ratio: up to 50,000:1
Light Output: 2000 lumens color and white
Resolution: 1920 x 1080 (1080p)
Aspect Ratio: Native 16:9, Compatible with 4:3 and 16:9
Technology: C2Fine technology, 3LCD, 3-chip technology​
Flexible Sound Upgrade Options
Input Lag Time Under 20 Ms
New Compact Design
Side-by-Side Comparison​
N/A - 300 Inches​
40 Inches - 500 Inches​
2.15 Meters - 1.32 Meters​
3.9 Feet - 48.7 Feet​
50000:1​
35,000:1​
Display Resolution​
3840 x 2160 pixels​
1920 x 1080p​
3840 x 2160 Pixels​
3840 x 2160​
3840 x 2160​
3000 lumen​
2000 lumen​
2800 lumen​
Picture Quality Enhancement​
4K PRO-UHD​
D7 chip and 3LCD, 3-chip technology​
Pixel shifting/Upscaling​
H.264, H.265 (HEVC), VP9​
10 Watts​
200 Watts​
10 Watts​
Light Source Life​
4000 Hours​
Button Control​
Button Control​
Remote, Touch​
Remote, Voice​
Mount Type​
Tabletop Mount​
Tabletop Mount​
Tabletop Mount​
Noteworthy Features​
Built-In Speaker​
HDMI Connectivity​
Built-In Speaker​
Connectivity​
Bluetooth, HDMI​
DisplayPort^HDMI​
Wi-Fi, HDMI​
Hardware Connectivity​
HDMI​
HDMI​
USB, HDMI, 3.5mm Audio​
Gaming Console​
Gaming Consoles​
Gaming Console, Laptop, Smartphone​
Measurements​
Dimensions L x W x H​
16.1"L x 13"W x 6.5"H​
13.1"L x 10.8"W x 4.8"H​
Item Weight​
15.2 Pounds​
16.1 Pounds​
9 Pounds​
Product
PROS AND CONS​
Pros
• Bright, crisp 4K picture quality with excellent contrast
• Very quiet operation, especially in ECO mode
• Good auto iris functionality for deeper blacks
• Portability allows for easy transport
• Clear and engaging visuals for both video and gaming
• Minimal issues with focus after initial setup
• Overall quality upgrade from previous models
Cons
• Initial cosmetic defects (small pits and scratch on the lens)
• Slightly softer image in one corner during initial use
• Concerns about quality control during assembly and handling
Pros
• Performs flawlessly after several months of use
• White color is less conspicuous when mounted at ceiling level
• Nicely laid out and backlit remote
Cons
• Fixed aspect ratio of 16:9 when using HDMI connections, limiting compatibility with 4:3 content
• HDMI input aspect ratio cannot be adjusted, impacting viewing experience for older DVDs
• Lack of clear communication regarding aspect ratio limitations from the manufacturer
• May not be suitable for users who watch older movies or TV shows in 4:3 ratio
Pros
• Outstanding brightness levels, even in well-lit environments
• Excellent color accuracy with a delta E of <2.5 after calibration
• Good gamma calibration options for accurate image quality
• Effective HDR performance, suitable for casual viewing
• Strong 4K enhancement capabilities for upscaling 1080p content
• User-friendly advanced calibration settings available
• Multiple keystone correction options and vertical lens shift for image adjustment
• Built-in streaming device that can be removed to free up HDMI and USB ports
• Good overall value compared to other 4K projectors
Cons
• Higher price point at $1299
• Brightness decreases significantly after calibration
• Lack of a manual included with the product
• No trigger output, requiring workaround for screen automation
• Included remote is not backlit, making it less convenient in dark settings
• HDR performance may not match that of higher-end projectors
• Potential for complicated settings that may confuse some users
