Epson Home Cinema 1080 vs 880: Which Built-In Speaker Model Should Influence Your Decision?
Epson Home Cinema 1080​
Epson Home Cinema 880​
$649.99​
$740.96​
Home Cinema, Gaming​
Projector​
Projector​
Color Modes: Dynamic, Bright Cinema, Cinema, Game
Brightness: 3,400 lumens
Connectivity: Two HDMI ports
Color Technology: 3LCD, 100% RGB color signal
Resolution: 1080p
Features: Built-in picture skew sensor for automatic keystone correction
Easy setup: Built-in speaker, HD entertainment ready out of the box
Dynamic contrast ratio: Up to 16,000:1
Connectivity: All-digital HDMI for cable/satellite, Blu-ray, gaming, streaming
Picture correction: Built-in picture skew sensor for automatic keystone correction
Color technology: Best-in-Class Color Brightness with 3LCD for 100% RGB color signal
Picture quality: Detailed 1080p images, optimized for fast-action content
Unboxing Experience​
Epson Home Cinema 1080:​
The projector boasts a sleek and modern design that fits well in any home or outdoor setting. Its build quality feels robust, ensuring that it can withstand occasional outdoor use without significant wear. The overall aesthetic is unobtrusive, allowing it to blend seamlessly into a home theater or casual viewing space. The large lens and clean lines give it a professional look, and despite its size, it remains manageable for setup and storage.
Epson Home Cinema 880:​
The Epson Home Cinema 880 boasts a sleek and modern design that fits well into any home theater setup. It's smaller and lighter than previous models, making it easier to mount or transport when needed. The projector's overall aesthetic is appealing, with a clean white finish that can blend seamlessly into various environments. The minimalist design doesn't detract from the viewing experience and feels professional enough for both casual and formal settings.
33 P - 300 Inches​
25 Inches - 386 Inches​
2 Feet - 11.1 Feet​
2 Feet - 11.1 Feet​
3400 Lumen​
3300 Lumen​
3LCD technology​
The viewing experience with this projector has been nothing short of impressive. The picture quality is sharp and vibrant, even in bright daylight, making it perfect for outdoor movie nights or gaming sessions. I particularly enjoyed watching sports and movies, where the colors popped and details were clear. While the internal speaker could use improvement, I found that using external sound systems significantly enhanced the overall experience, allowing me to immerse myself fully in whatever I was watching.
The viewing experience offered by the Epson Home Cinema 880 is nothing short of impressive. The 3300 lumens brightness ensures that images remain vibrant and clear, even in well-lit environments. While it cannot quite match the superior color accuracy and contrast levels of an OLED display, many users, including myself, find the cinematic quality of projected images to be captivating. The absence of motion blur enhances the overall experience, making it suitable for both movies and gaming. Watching on a large 120-inch screen truly transforms the way I enjoy content.
Built-In Speaker, Digital Keystone Correction​
Button Control​
Remote, Touch​
Remote, Touch​
USB, HDMI, 3.5mm Jack​
Television, Gaming Console, Laptop, Smartphone​
100 watts​
170 watts​
Mount Type​
Tripod Mount, Tabletop Mount​
Tabletop Mount, Ceiling Mount​
11.9"L x 9.9"W x 3.6"H​
Setting up this projector was a straightforward process, which I greatly appreciated. I was able to get it up and running quickly, and the manual zoom and quick corner features made adjusting the image size and alignment a breeze. However, I did encounter some issues with the auto keystone adjustment; it required recalibration each time I powered the device on. Despite this minor inconvenience, I found the overall setup to be far more reliable than traditional televisions when used outdoors, especially in dusty conditions.
Setting up the Epson Home Cinema 880 is relatively straightforward, especially if you're replacing an older model. The projector comes equipped with a three-hole mounting system compatible with most universal mounts. However, it does require precise placement to achieve the desired screen size, which can be a bit tricky for some users. Newcomers to projectors might find this aspect challenging, but with a little patience, the adjustment process can be navigated successfully.
• Easy setup and quick adjustments
• Excellent picture quality with vibrant colors
• Bright enough for use in well-lit environments
• Reliable for outdoor use
• Good warranty support from the manufacturer
• Loud fan noise in normal mode
• Auto keystone adjustment can be cumbersome
• Internal speaker quality is lacking
• Some may find the throw distance limitations frustrating
Overall, I am highly satisfied with this projector. It delivers exceptional performance for its price, especially in terms of brightness and clarity. While there are some drawbacks, such as fan noise and keystone adjustments, the positives far outweigh these issues. I would recommend this projector to anyone looking for an affordable and high-quality option for both indoor and outdoor viewing. It has certainly exceeded my expectations and has become a staple for my entertainment needs.
- Super bright picture, works well even in daylight.
- Adjustable keystone for image alignment.
- Quiet operation in Eco mode.
- Excellent color and sharpness for the price.
- No rainbow effect, thanks to Epson's 3LCD technology.
- Iris noise can be distracting in quiet moments.
- Requires precise mounting distance for optimal image size.
- Limited built-in audio quality; external speakers recommended.
- No optical zoom or lens shift, making installation a bit restrictive.
My overall impression of the Epson Home Cinema 880 is overwhelmingly positive. It represents an excellent balance of quality and affordability, especially for those looking to elevate their home entertainment experience without breaking the bank. Although it has some drawbacks—like iris noise and installation challenges—the sheer joy of watching content on a large screen makes it worth it. I can confidently say that this projector has become an essential part of my viewing routine, and I would recommend it to anyone considering a projector for home use.
PlayStationPepe
Epson Home Cinema 1080 - I wasn't impressed with the sharpness at first, but it turns out I was using crappy sources. Once I switched to full HD, the picture was way better and totally met my expectations. I should've held off on that bad review!
Just got the Epson Home Cinema 1080 and after one night of watching football outside, I'm super happy! The picture quality is awesome for the price, and that 16ft screen looks so bright and sharp!
goalweiser
We got the Epson Home Cinema 880 to watch movies outside, and I was worried it wouldn't be bright enough. Turns out, I had nothing to worry about! We set it up behind an inflatable screen for a couple of movie nights, and it looked amazing—super bright and clear. Totally recommend it!
goalweiser
Got the Epson Home Cinema 880 at the end of 2021 and we use it as our main TV in the living room every day. It's now August 2024 and we’ve had zero problems!
Trollatopoulous
Epson Home Cinema 880 is a solid projector! It gives you a super clear picture and you can zoom it in and out a bit, so you don’t have to stress about getting the perfect distance.
