Amanda Brown
Active member
Unboxing Experience
- 1.1.1 Epson Home Cinema 1080:
- 1.1.2 Epson Home Cinema 1060:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 Epson Home Cinema 1080:
- 1.3.2 Epson Home Cinema 1060:
- 1.4 Features
1.5
- 1.5.1 Epson Home Cinema 1080:
- 1.5.2 Epson Home Cinema 1060:
1.1
Unboxing Experience
- 2 Conclusion
Parameter | Epson Home Cinema 1080 | Epson Home Cinema 1060 |
Reference Price | $649.99 | $694.98 |
Recommended Uses | Home Cinema, Gaming | Gaming |
Built-In Media | Projector | Epson 1060 |
Highlight | Color Modes: Dynamic, Bright Cinema, Cinema, Game Color Brightness Technology: 3LCD, 100% RGB color signal Setup: Built-in speaker, easy setup Picture Quality: 1080p, optimized for fast-action Contrast Ratio: Up to 16,000:1 Warranty and Support: 2-year limited warranty, full-unit replacement, lifetime technical support | Resolution: Full HD 1080p Image Size: Up to 300 inches Brightness: 3,100 Lumens Connectivity: 2x HDMI ports (1x MHL) Technology: 3LCD Operating Distance: 19.0 feet (6.0 meters) |
Unboxing Experience
The Epson projector presents a sleek and modern design that immediately caught my attention. Its compact form allows it to blend seamlessly into any environment, whether it's set up indoors or outdoors. The finish feels high-quality, and the buttons are intuitive and accessible, giving it a professional look that suggests durability. When I first laid eyes on it, I felt confident that it would perform well, and its aesthetic only enhanced my excitement to set it up.Epson Home Cinema 1060:
The overall appearance of the Epson 1060 projector is solid and functional. Its design is straightforward, exhibiting a robust build quality that gives off a professional vibe. The projector is not overly flashy, which suits my home theater setup without drawing unnecessary attention. The lens is well-protected, tucked deep within the unit, which also helps in avoiding any direct glare from the bright light source. Although it is somewhat heavier than other models, this weight contributes to a sense of durability.Display
Screen Size | 33 P - 300 Inches | 60 Inches - 60 Inches |
Throw Distance | 2 Feet - 11.1 Feet | 10 Feet - 30 Feet |
Contrast Ratio | - | 15000:1 |
Maximum Resolution | 1920 x 1080 | 1920 x 1080 |
Native Resolution | 1920 x 1080 | Full HD - Full HD (1920 x 1080) |
Brightness | 3400 Lumen | 3100 Lumen |
Display Type | LCD | LCD |
Picture Enhancement | - | Epson 3LCD technology |
Viewing Experience
The viewing experience was nothing short of spectacular. The picture quality is crisp and vibrant, even in bright daylight, which is a testament to its 3400 lumens brightness. I’ve used it for everything from casual backyard movie nights to intense gaming sessions, and it has performed excellently in all scenarios. The colors pop on the screen, and I found myself fully immersed in whatever I was watching. Admittedly, the internal speakers leave something to be desired, but connecting to an external sound system significantly enhanced the experience.Epson Home Cinema 1060:
The viewing experience with the Epson 1060 has been exceptional, particularly in a room with a lot of ambient light. The projection quality is bright and vibrant, making it suitable for daytime viewing without compromising color quality. I enjoyed sports, movies, and gaming with clarity and minimal washout. The only downside has been the handling of dark scenes, which can sometimes appear a bit grey, but I find this acceptable given the projector's performance in brighter conditions. Watching content in a well-lit room has been a pleasure, and I prefer the larger image over my previous 65-inch TV.Features
Other Features | Built-In Speaker, Digital Keystone Correction | Built In Speaker, Portable |
Video Encoding | - | H.264, H.265 |
Lamp Wattage | - | 210 Watts |
Control Method | Remote, Touch | Touch |
Connectivity Technology | USB, HDMI, 3.5mm Jack | hdmi |
Compatible Devices | - | Gaming Console, Laptop, Smartphone, Tablet, Television |
Wattage | 100 watts | 315 watts |
Mount Type | Tripod Mount, Tabletop Mount | Wall Mount |
L x W x H | 11.9"L x 9.9"W x 3.6"H | 11.9"L x 9.8"W x 3.6"H |
The setup was surprisingly straightforward. I was able to plug it in and get started without much hassle, which is always a plus for me. Though there were some nuances with the auto keystone adjustment that I found a bit cumbersome, the overall process was efficient. I appreciated that I could easily fit it into a small space, especially since I was using an 80” screen and it filled it beautifully. I also found that, despite being a few years old, the projector's reliability in various conditions, like dust and outdoor settings, was impressive.Epson Home Cinema 1060:
Setting up the Epson 1060 was remarkably easy right out of the box. I quickly connected it to my existing home theater system and was able to mount it on the ceiling without any hassle. The remote control's menu navigation is intuitive, allowing me to adjust keystone and zoom settings effectively. I especially appreciated the manual sliders for fine-tuning the image to fit my 100-inch screen perfectly. However, I did encounter a minor challenge when attempting to flip the image right side up, as the initial configuration was set for front surface projection.Conclusion
Pros:• Beautiful picture quality even in bright conditions.
• Easy setup and reliable performance.
• Great for gaming and outdoor viewing.
• Affordable for the quality offered.
• Excellent brightness with 3400 lumens.
• Loud fan noise, especially in normal mode.
• Auto keystone adjustment can be cumbersome.
• Internal speakers are not ideal; external audio recommended.
• Some issues with short throw distance as advertised.
• Warranty process can be tedious.
Overall, I am thrilled with my purchase of this Epson projector. It has exceeded my expectations in terms of picture quality and versatility, making it an excellent choice for both indoor and outdoor use. While there are some minor drawbacks, particularly with the fan noise and the need for external audio, these do not detract significantly from the overall performance. The warranty experience was a bit of a hassle, but the quick turnaround for a replacement was reassuring. This projector has transformed my viewing experience, and I can confidently say that I won’t need to look for another one anytime soon.
Pros:- Great looking image quality
- Bright performance even in ambient light
- Easy setup and adjustment options
- Excellent color balance for various media types
- Good value for the price
- No audio output options
- Some noise from the fan in normal mode
- Internal speakers are subpar
- No 12V trigger input
Overall, I am thoroughly impressed with the Epson 1060 projector, especially considering its price point. The image quality is superior, making it a fantastic choice for home viewing, whether for movies, sports, or gaming. While the lack of audio output and some fan noise were drawbacks, they were minor in comparison to the projector's strengths. I believe anyone looking for a reliable, bright projector for various viewing scenarios would be happy with this purchase. For me, it has proven to be a worthwhile investment that has enhanced my home entertainment experience significantly.
