Epson EpiqVision Ultra LS300 Review: Is This Ultra Short Throw Laser Projector a Good Fit?
Barend Ray
Active member
First Impressions​
The Epson LS300 isnt meant to be portable as its a big and heavy projector, and it lacks an integrated battery, so you need to plug it in. The projector lacks auto keystone correction, so youll need to adjust the image manually, and it also doesnt have autofocus. It does have an integrated 2.1 speaker system, so you won't need to worry about connecting it to a soundbar if you do move it.
The Epson LS300 projector uses a laser light source, which requires no maintenance and will last for 20,000 hours or more. You likely wont ever have to worry about replacing it. As its a 1080p projector, its limited to outputting a 1080p @ 60Hz resolution. Its an Ultra Short Throw (UST) projector, so its capable of projecting on a 61 screen at a distance of 1 and up to 120 at a distance of 15.2".
Epson EpiqVision Ultra LS300​
$999.99​
Home Cinema, Gaming​
Epson LS300 Ultra Short Throw Laser Projector, power cord, remote control with AAA batteries, Android TV dongle with remote control and AAA batteries, Quick Setup Guide.​
Highlight
Epson Certified-Refurbished: Inspected and tested by quality-assurance team
Picture Quality: Supports up to 120" display with 4K content for Full-HD HDR
Sound System: Custom 2.1 speaker system by Yamaha; Bluetooth connectivity
Built-In Android TV: Latest interface with voice search and Google Assistant; access to streaming channels
Ultra-Short Throw Technology: Multi-array laser diodes for high brightness and enhanced black density
N/A - 120 Inches​
11.1 Feet - 11.1 Feet​
3600 Lumen​
Ultra Short Throw Laser Array Technology​
Viewing Experience
The Epson EpiqVision LS300s delivers a strong overall performance with its impressive peak brightness, making it suitable for bright environments and ensuring vibrant colors. However, its brightness uniformity is only satisfactory, and while it performs adequately in darker settings, the contrast could be improved as the blacks lack depth. The projector offers a decent color gamut and excels with the Rec. 709 color space, but struggles with the wider Rec. 2020 color space. Overall, it is a solid option for users looking for a bright projector for varied lighting conditions, though it may fall short in contrast and wider color reproduction.
20000 Hours​
Voice Control​
Voice​
388 watts​
Bluetooth​
Hardware Connectivity​
USB, HDMI
Television, Gaming Console, Laptop, Speaker, Smartphone​
Ultra Short Throw​
18.39"L x 15.75"W x 5.87"H​
The projector offers a seamless and efficient user experience with its built-in Android TV, providing access to a wide range of apps. The full Chromecast integration enhances its functionality by allowing easy content streaming from mobile devices. The integrated Yamaha 2.1 speaker system, featuring two 5W full-range speakers and a 10W subwoofer, delivers a robust audio experience. With two HDMI ports, including one that supports ARC, alongside Bluetooth and Wi-Fi connectivity, the projector is versatile and well-equipped for various entertainment needs. Overall, it presents a compelling combination of performance, connectivity, and sound quality.
User Feedback​
• Excellent image quality with vibrant colors and focus
• Extremely bright, usable in well-lit rooms
• Easy setup and connectivity via QR code
• Quiet operation with minimal fan noise
• Good performance with streaming services like Netflix
• Adjustable brightness settings that help conserve lamp life
• Affordable price for a renewed unit
• Top image can be slightly jagged while the bottom is straight
• Focus wheel can be difficult to adjust precisely
• Lack of Ethernet port for a more stable connection
• Internal Android may pause the screen during picture adjustments
• No native Netflix app available
• No Harmony remote support
The LS 300 projector impresses with its bright and vibrant image quality, making it a solid choice for home theater enthusiasts. Its user-friendly setup and operation, combined with its ability to perform well in various lighting conditions, make it an appealing option. While there are some minor drawbacks, such as the jagged image and focus wheel issues, they are easily manageable. Overall, for the price of a renewed unit, the LS 300 offers excellent value and performance.
