Emotn N1 Projector Troubleshooting Guide, All Issues
YOYO
Emotn has launched the Emotn N1 portable Netflix-licensed projector on the market. Here are the troubleshooting guides for usual issues.
What is Emotn N1 projector with no audio output?​
a. Be sure not to press the remote control "Mute" button.
b. Be sure the projector interface "LINE OUT", "HDMI ARC" or Bluetooth does not connect to the external audio device.
What if Emotn N1 projector has no image output?​
a. Press the power button on the top cover. If powered on, the button indicator light will turn off.
b. Be sure the power adaptor has power output.
What if there is no network on Emotn N1 projector?​
a. Enter settings, and check the network connection status in the network option.
b. Be sure the network cable inserts the projector interface "LAN" normally.
c. Be sure the router is configured correctly.
How to fix if Emotn N1 projector has blurry image?​
a. Adjust the focus ring or keystone.
b. Projector and screen/wall must be at the effective distance.
c. Projector lens is not clean.
How to fix there is a non-rectangular image on Emotn Projector?​
a. Place the projector perpendicular to the screen/wall, if the keystone correction function is not used.
b. Use the keystone correction function to adjust the display.
What to do if the automatic keystone correction failed on Emotn N1?​
a. Be sure the TOF on the front panel not be blocked or dirty.
b. The best automatic keystone correction distance is 1.5-2.5m, horizontal ±20°.
What to do if the autofocus failed on Emotn N1?
What to do if the autofocus failed on Emotn N1?​
b. The best autofocus distance is 1.3-2.5m, horizontal ±20°.
What to do if the remote control is unresponsive on Emotn N1?​
a. Be sure the remote control is paired successfully via Bluetooth communication. If the pairing is successful, the indicator light does not
flash when the button is pressed.
b. If the pairing is unsuccessful, the Remote Control at IR communication, the indicator light does flash when the button is pressed.
c. Be sure there are no interferences or obstructions between the projector and remote control.
d. Check the battery charge and installation polarity.
How to fix Emotn N1 not connecting to Bluetooth devices?​
Enter settings, open the Bluetooth option to check the Bluetooth device list, and connect the device.
