Unboxing Experience
- 1.1.1 ELEPHAS Mini Projector:
- 1.1.2 AuKing Projector:
- 1.1.3 NICPOW Mini Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 ELEPHAS Mini Projector:
- 1.3.2 AuKing Projector:
- 1.3.3 NICPOW Mini Projector:
- 1.4 Features
1.5
- 1.5.1 ELEPHAS Mini Projector:
- 1.5.2 AuKing Projector:
- 1.5.3 NICPOW Mini Projector:
1.1
Unboxing Experience
- 2 Conclusion
Parameter | ELEPHAS Mini Projector | AuKing Projector | NICPOW Mini Projector |
Picture | |||
Reference Price | $79.99 | $299.99 | $49.99 |
Recommended Uses | Indoor/Outdoor | Education, Home Cinema, Gaming, Business | Outdoor or indoor |
Built-In Media | 1 x Remote Control, 1 x Projector, 1 x HDMI Cable, 1 x Manual, 1 x Tripod | Remote X 1 (Battery NOT Included), Power Cord X 1;HDMI Cable X 1, AV Cable X 1, User Manual X1, Netflix-Officially-Licensed Projector x 1 | 1 x NICPOW Projector,1 x HDMI Cable 1 x 3 inches (approx. 2.5 x 7.6 cm) AV Cable,1 x Power Supply ,1 x User Manual,1 x Remote Control, 1 x Tripod |
Highlight | Model: Elephas Mini Projector Size: Comparable to a smartphone, handheld Resolution: 1080P HD Lens: German emerald glass lens Color Support: 24-bit true color (over 16.77 million colors) Screen Size: Up to 200 inches Ports: USB, HDMI, AV, Audio, Chromecast Compatibility: iOS, Android, Windows, various media devices (no support for Netflix, Amazon Prime, Hulu) Speaker: Built-in HIFI speaker Noise Reduction: Efficient heat dissipation system to reduce fan noise Certificates: CE, FCC, RoHS, PSE Support: 3-years factory support Included Accessories: Mini stand, portable power station (not included) | Streaming Capability: Supports over 1,000,000 videos from certified apps like Netflix, allows downloading additional apps online. Auto-Focus Feature: Rapid auto-focus and image correction using high-precision sensors and gyroscopes. WiFi Connectivity: Dual-band WiFi 6 technology for enhanced signal reception and transmission. Stand Design: Unique removable and foldable stand for versatile projection angles and portability. Brightness & Resolution: 800 ANSI lumens, supports 4K input, delivers images brighter and clearer than typical 1080P projectors. Audio Experience: Dolby-certified Hi-Fi stereo speakers with immersive 3D sound and AI sound balancing technology. Bluetooth Functionality: Bidirectional Bluetooth connectivity for streaming audio or using the projector as a Bluetooth speaker. Note on 4K Playback: Requires 4K devices connected via HDMI; 4K videos may display at 1080P resolution. | Resolution: 1920x1080P (originally 1280x720P) Lamp Life: 65,000 hours Projection Distance: 3.3 to 21.8 feet (optimal 6.5 to 8.2 feet) Viewing Size: 32'' to 240'' Brightness: 7500 lux Color Contrast: 6000:1 Aspect Ratio: 4:3 / 16:9 Keystone Correction: ±15° Speakers: 2x3W HiFi stereo speakers with SRS sound system Connectivity: HDMI, 2xUSB, AV, AUDIO interfaces Compatibility: Smartphones, TV sticks/boxes, game consoles, PCs, tablets, laptops, DVD players, USB sticks Warranty: 36 months replacement support and lifetime technical support |
Unboxing Experience
The ELEPHAS 2024 Upgraded 1080P HD Mini Projector may not have the sleek, high-end design of pricier models, but its compact and portable form factor makes it suitable for casual users and outdoor enthusiasts alike. It comes in a practical carrying case, ensuring that it stays protected during transport. The projector’s controls are intuitively laid out, with a large focus ring that’s easy to adjust, contributing to an overall user-friendly experience.AuKing Projector:
Upon receiving the Au King mini-projector, I was immediately impressed with its sleek and compact design, which makes it highly portable. The packaging was well thought out, and the included color instruction manual was a nice touch, making it easy for even a granddad like me to set it up in just about ten minutes. The build quality feels sturdy, and the overall aesthetics are appealing, making it a great addition to my entertainment setup.NICPOW Mini Projector:
The projector, while not compact enough to fit the "mini" label, still has a compact and portable design, approximately the size of an open hand. Its build quality feels decent for the price, and it comes with a small tripod that, while not very sturdy, adds to its portability. The overall aesthetic is functional rather than flashy, emphasizing practicality for casual use like outdoor movie nights or camping trips.Display
Screen Size | 80 Inches - 200 Inches | 30 Inches - 300 Inches | 32 Inches - 1E+2 Inches |
Throw Distance | 2.6 Feet - 14.5 Feet | 4.6 Feet - 16.4 Feet | 3.3 Feet - 22.9 Feet |
Contrast Ratio | 6000:1 | 28000:1 | 6000: 1 |
Maximum Resolution | 1920x1080 Pixels | 1920 x 1080 | 1920 x 1080 pixels |
Native Resolution | 1920 x 1080 | 1920 x 1080 | 1280 x 720 |
Brightness | 3500 lumen | 28000 Lumen | 7500 lumen |
Viewing Experience
The viewing experience is best in a dark room, as the brightness levels are not sufficient to counteract ambient light. However, once the lights are dimmed, the picture quality shines, delivering sharp images and vibrant colors, particularly for a budget projector. I appreciated how well it projected onto a light-colored wall without needing an additional screen, making it even more convenient for spontaneous movie nights.AuKing Projector:
The viewing experience with the Au King mini-projector has been delightful. The picture quality is sharp, with vibrant colors that truly enhance movie nights, whether indoors or outdoors. I appreciate the auto-focus and keystone adjustment features, which function almost flawlessly, making it easy to set up the perfect viewing angle. The sound quality from the built-in speakers is surprisingly good, though I found it beneficial to connect to external speakers for an even better experience during larger gatherings.NICPOW Mini Projector:
The picture quality is surprisingly good for the price, with a clear image that holds up at 720p resolution, even when projected onto a large screen. While brightness levels can vary depending on ambient light—performing best in darker settings—the contrast and color reproduction remain decent, making it suitable for indoor use. The sound quality from the built-in speakers, however, is average at best, necessitating external speakers for a more immersive experience, especially in larger settings.Features
Other Features | HDMI Connectivity, Portable | Netflix Official License/Prime Video,YouTube Support Auto focus | Built-In Speaker |
Video Encoding | AVC | H.264, H.265 | AVC |
Lamp Wattage | 38 Watts | - | 75 Watts |
LightSource Life | 50000 Hours | - | 65000 Hours |
Controller Type | remote | Remote Control | Remote Control |
Connectivity Technology | HDMI | Bluetooth, Wi-Fi, USB, HDMI | MHL, USB, HDMI, VGA |
Compatible Devices | Smartphone, Laptop, Tablet, Television | Laptop, Gaming Console, Smartphone | Television, Gaming Console, Speaker, Laptop, Smartphone, Tablet |
Wattage | 60 watts | - | 50 watts |
Mount Type | Tripod Mount | Tabletop Mount | Wall, ceiling, vertical, desktop mount |
L x W x H | 6"L x 4.4"W x 2.4"H | - | 8.66"L x 7.09"W x 3.94"H |
Setting up the projector was a breeze. I simply connected my Firestick through the HDMI port, plugged it in, and selected the source within minutes. The initial picture quality required some tweaking, especially with RGB adjustments, but once dialed in, the results were surprisingly good for such an inexpensive device. The included remote control worked adequately, though I did find the battery cover a bit tricky to open.AuKing Projector:
Setting up the projector was a breeze. I managed to get it up and running in under ten minutes, which is quite impressive given my experience with other projectors. The automatic self-correcting system for image balance and clarity worked effectively, providing a clean and crisp picture without much manual adjustment. It seamlessly connects to Bluetooth devices, enhancing the audio experience, and the built-in apps like Netflix and Amazon Prime make streaming incredibly convenient without the need for additional devices.NICPOW Mini Projector:
Setting up the projector is straightforward. I found that connecting it to various devices, including laptops and gaming consoles, was a hassle-free experience. The included HDMI cable makes it easy to get started, although you will need additional adapters for mobile devices. The keystone and focus adjustments are user-friendly, allowing for quick image correction, but the keystone adjustment range is limited, which might require some careful placement for optimal results.Conclusion
Pros:• Excellent value for the price, comparable to more expensive models.
• Easy to set up and use, particularly with streaming devices like Firestick.
• Good picture quality in dark environments, making it suitable for movie nights.
• Compact and portable, making it ideal for travel and outdoor use.
• Includes a carrying case and tripod for easy transport and setup.
• Limited sound quality; external speakers are highly recommended.
• Short power cable necessitates being near an outlet or using an extension cord.
• Some connectivity issues with streaming services, particularly on iOS devices.
• Keystone correction is minimal, which can limit setup options.
Overall, the ELEPHAS 2024 Upgraded 1080P HD Mini Projector exceeded my expectations for a budget projector. While it has its limitations, especially regarding sound and connectivity, the picture quality and ease of use make it a fantastic option for casual viewing, camping trips, or backyard movie nights. I feel it's a solid investment for anyone looking for an affordable yet functional projector that delivers decent performance without breaking the bank.
AuKing Projector:
Pros:• Excellent picture quality and vibrant colors
• Easy setup process
• Built-in streaming apps like Netflix and Amazon Prime
• Good auto-focus and keystone correction
• Sturdy build quality
• Responsive customer support
• Some users reported minor screen defects
• Sound quality could be improved for larger spaces
• Need to adjust screen settings each time it’s turned on
• Limited app customization options
• Poor Apple mirroring experience
Overall, I am thoroughly satisfied with the Au King mini-projector. It offers a great balance of quality and affordability, making it a standout choice among budget projectors. Despite a few minor issues like the sound volume and the need for adjustments each time it starts up, the projector's strengths far outweigh its weaknesses. The excellent customer service further enhances my positive experience. I would highly recommend this projector for anyone looking to elevate their home entertainment setup without breaking the bank.
Pros:- Impressive display quality for the price
- Easy connection to various devices
- Suitable for both indoor and outdoor use
- Compact and portable design
- Built-in speakers are quiet and underwhelming
- Not truly "mini" in size
- Limited keystone adjustment range
Overall, I am quite pleased with this projector, especially considering its price point. It performs adequately for casual movie nights, gaming, and presentations. While there are some drawbacks, such as the average sound quality and the misleading "mini" label, its value for money cannot be overlooked. If you're seeking an affordable projector that does its job well, this one is hard to beat, especially for casual use or as a temporary solution in place of a traditional TV.
