EGJSG Mini Projector vs WANBO T2 Ultra vs Polocsh Mini: Which Offers Better Built-in Cooling?
EGJSG Mini Projector​
WANBO T2 Ultra Projector​
Polocsh Mini Projector​
$79.99​
$199.99​
$189.99​
Indoor/Outdoor​
Home Cinema​
Outdoor, Home Cinema, Gaming​
User Manual, Remote, Adapter​
User Manual, T2 Ultra Projector, Remote​
User Manual, Power Cord, Battery, Remote, HDMI Cable​
180° Rotatable - Swivel bracket allows projection from various angles, including wall to ceiling. Clear picture from 40-130''.
HD Quality - Supports 1080P 4K resolution, advanced colour technology, HDR10, and HLG for vivid visuals. Best projection distance of 5.51ft and size of 60''.
Smart Features - Built-in TV Store for downloading apps like Netflix, YouTube, Prime Video; smooth video playback.
WiFi6 Connectivity - Supports Wi-Fi, Bluetooth, Miracast, AirPlay, DLNA; equipped with HDMI, USB, Type-C, audio output for versatile connections.
0.9:1 High Projection Ratio - Projects larger images from shorter distances, ideal for compact spaces like bedrooms and small living rooms.
Auto Keystone & Zoom - Automatically corrects trapezoidal distortion; 100%-50% zoom function for flexible size adjustments and clear focus.
Operating System: Android TV 11.0
App Support: Over 5,000 apps (e.g., Netflix, YouTube, Amazon Prime Video, Hulu)
Projection Angle: 120° adjustable
Native Resolution: 1080p
Brightness: 500 ANSI lumens
Contrast Ratio: 2500:1
Audio: 10W full-range speaker with dual bass diaphragm
Auto Focus: Exclusive ASA 3.0
WiFi Connectivity: 2.4/5G WiFi, Chromecast built-in
Optical Engine: Fully sealed for dust-free experience
Noise Level: 30dB
Light Source Lifespan: Over 20,000 hours
Resolution: Native 1080P, 4K supported
Brightness: 300 ANSI lumens
Contrast Ratio: 13000:1
Battery Life: 2.5 hours (movie), 6 hours (music)
Weight: 3 lb
Projection Angle: 270° adjustable
Connections: HDMI, USB, 3.5mm audio port
Keystone Correction: 4-point, ±45°
Zoom Capability: 50%-100%
Screen Size: Up to 150 inches
Aspect Ratio: 4:3, 16:9
WiFi: WiFi 6
Bluetooth: Bluetooth 5.3
Warranty: 3-year repair warranty, lifetime technical support
Unboxing Experience​
EGJSG Mini Projector:​
Upon first glance, this projector strikes me as sleek and compact, making it an appealing addition to any setup. Its lightweight design enhances portability, allowing me to easily carry it around for various viewing experiences, whether indoors or outdoors. The build quality feels solid, giving me confidence in its durability despite its small size. The overall aesthetic is modern and unobtrusive, blending well into different environments, which I appreciate as it doesn't draw unnecessary attention when in use.
WANBO T2 Ultra Projector:​
The Wanbo T2 Ultra projector boasts a sleek and modern design, reminiscent of high-end tech gadgets. It feels sturdy and well-built, with a compact form factor that makes it highly portable. The adjustable stand, which allows rotation up to 120 degrees, adds to its versatility, enabling users to project images onto walls or ceilings effortlessly. Overall, its aesthetic appeal and robust construction give it a premium feel despite its budget-friendly price.
Polocsh Mini Projector:​
The projector boasts a compact and portable design that is both functional and aesthetically pleasing. Its small size makes it easy to carry around, and the sleek finish adds a modern touch. I appreciate the magnetic battery pack that attaches seamlessly, allowing for a clean, wireless look without the clutter of extra cords. It’s a well-thought-out design that not only emphasizes portability but also enhances usability, making it a great addition to any home entertainment setup or outdoor movie night.
40 Inches - 130 Inches​
30 Inches - 150 Inches​
13.12 Feet - 3.94 Feet​
4 Feet - 12 Feet​
3.68 Feet - 19.68 Feet​
2500:1 Pixels​
13000:1 or higher Pixels​
1280 x 720 Pixels​
1920 x 1080 Pixels​
1920 x 1080 Pixels​
1280 x 720​
500 ANSI​
AI Image Engine​
The viewing experience has truly exceeded my expectations. The picture quality is exceptionally crisp, with vibrant colors that pop, even in bright environments. I found the brightness, rated at 600 ANSI lumens, to be more than adequate for my smaller apartment, and it performs admirably in darker settings as well. Watching 4K videos gives me that immersive theater-like feeling I crave. The audio quality is surprisingly robust for such a compact projector, but the option to connect external speakers via Bluetooth adds versatility for larger gatherings.
The viewing experience with the Wanbo T2 Ultra is quite impressive, especially in dark environments where it excels in delivering a bright and vibrant picture quality. The 1080p resolution ensures that images are clear and detailed, making it suitable for movie nights or sports viewing. However, it’s essential to note that the projector struggles in well-lit conditions, which limits its usability during the day. The auto focus and keystone correction features work effectively, allowing for quick adjustments and stable images, thus enhancing the overall experience.
The viewing experience is truly impressive, with crystal-clear images that shine even in darker settings. The projector supports 1080P resolution with an option for 4K, which is a fantastic bonus for movie lovers. Watching films outdoors was a joy, as the image remained bright and vibrant. The sound quality also exceeded my expectations, especially for a built-in speaker, enhancing the overall experience while still allowing for Bluetooth connection to external sound systems for those who want a richer audio experience.
• Portable and lightweight
• Easy to set up
• Good picture quality
• Built-in streaming apps
• Magnetic battery pack for wireless use
Built-In Speaker, Portable, Lightweight, Built-In Wi-Fi, Built-In Media Player​
Built-In Speaker, Auto Obstacle Avoidance, Digital Keystone Correction, Auto Focus, Built-In Wi-Fi​
①Rechargeable②1080p 4K Support③Built-in Smart Android 11④Electric Focus ⑤WiFi6&5.3Bluetooth​
H.264, H.265​
55 Watts​
60 Watts​
50000 Hours​
20000 Hours​
50000 Hours​
Bluetooth, Wi-Fi​
Bluetooth, Wi-Fi, HDMI
Bluetooth, Wi-Fi, USB, HDMI
Laptop, Smartphone, Speaker​
65 watts​
60 watts​
Mount Type​
Tabletop Mount​
Floor Mount​
Projector with stand​
4.49"L x 6.69"W x 5.51"H​
5.7"L x 5.6"W x 8.6"H​
Setting up this projector was a breeze. Within moments of unboxing, I was able to plug it in, power it on, and connect to WiFi without any issues. The intuitive controls and remote made navigating through the menu and options a straightforward process. Automatic focus and keystone correction features ensured the image was perfectly aligned and sharp in seconds. The inclusion of pre-installed streaming apps is an incredible convenience, allowing me to dive straight into my favorite shows without needing additional devices or complicated setups.
Setting up the Wanbo T2 Ultra is a breeze; it’s user-friendly and quick to get started. I was impressed by how seamlessly it integrates with Android TV, providing direct access to a plethora of streaming apps right out of the box. However, while the interface offers a decent experience, I did encounter some lag when navigating through menus, which could be frustrating at times. Despite these minor issues, the overall setup process is straightforward, making it ideal for both tech-savvy users and those less familiar with technology.
Setting up this projector was surprisingly straightforward, even for a first-time user like myself. The instruction manual, while detailed, was not even necessary as I was able to connect it to Wi-Fi and access streaming apps like Netflix and YouTube within minutes. The auto keystone feature is a game-changer, allowing for quick adjustments to ensure a perfectly aligned image regardless of the projection angle. Additionally, the built-in Android operating system provides access to a variety of apps, making it a versatile standalone device that doesn't rely on external hardware.
• Easy setup with automatic focus and keystone correction
• Impressive picture clarity and vibrant colors
• Built-in streaming apps with Android OS
• Good sound quality with additional Bluetooth connectivity
• Affordable price point for the features offered
• Built-in speakers may not suffice for larger spaces
• May require additional cables for external devices
• Not designed for ceiling installation
Overall, I am thoroughly pleased with this projector and would highly recommend it to anyone in search of an affordable yet high-quality option. It brilliantly balances portability, user-friendly setup, and impressive performance, making it a fantastic choice for both casual movie nights and more structured viewing experiences. Whether I'm using it for family movie nights or casual outdoor gatherings, it has proven to be a reliable and enjoyable device. If you're looking to experience big-screen entertainment without breaking the bank, this projector is definitely worth considering.
• Easy to set up and use; stylish and portable
• Surprisingly good color and contrast; projects a true HD image of 100-inches plus
• Auto focus and keystone work well; stable image in focus quickly
• Clear and decently loud speakers, even a little bass, with a relatively quiet cooling fan
• Both casting and built-in Android 11 run without stutter or lag, after you get past menu
• Only for use at night or in a darkened room
• All controls are via remote
The Wanbo T2 Ultra projector offers exceptional value for its price, making it an ideal choice for anyone looking to enjoy a cinematic experience without breaking the bank. Its combination of portability, decent built-in audio, and easy access to streaming services makes it a versatile option for both indoor and outdoor use. While it does have some limitations, particularly in bright environments and with the reliance on a remote control, the positives far outweigh the negatives. For under $200, this projector is a fantastic option for casual viewing and outdoor movie nights.
• Battery life could be improved for longer use
• Color accuracy could be better
• Limited focus range
• Built-in speaker volume isn't very high
Overall, I'm incredibly satisfied with this projector. It offers exceptional value for the price, combining portability, ease of use, and high-quality projection. Whether for family movie nights, outdoor gatherings, or work presentations, it performs admirably in all scenarios. The ability to connect seamlessly to various devices and streaming services makes it a versatile choice for anyone looking to enhance their viewing experience. I would highly recommend this projector to anyone in the market for a reliable and portable solution.
Gizmoitus
The EGJSG Mini Projector is awesome! Super easy to use and the picture quality is great. The built-in speaker rocks, and you can even connect a Bluetooth speaker for bigger crowds or different spots.
pricelesslambo
EGJSG Mini Projector is awesome for outdoor movie nights and camping! It's super compact but works like a charm. Super easy to connect too. Totally worth the price!
Just got the EGJSG Mini Projector for my country house and it’s a hit! The TV room is spacious, so we had a crowd watching, and everyone loved it. The picture quality is solid, too. Totally recommend it!
ZacRedact
WANBO T2 Ultra Projector is awesome! Amazing sound and picture, super easy to set up, and packed with cool features! I’m obsessed! Perfect for a fun date night!
pricelesslambo
I’m totally loving my WANBO T2 Ultra Projector! The sound and picture are awesome, and it even comes with apps. Totally worth it!
The Polocsh Mini Projector is awesome! The video quality blew me away, and it works well even in the daytime. The auto-focus is spot on, and it's super compact too!
Check out the Polocsh Mini Projector! It's super easy to use straight out of the box. You can stream, use USB, or hook up HDMI devices, plus it’s got audio options. My fave part? It's rechargeable, so you can take it anywhere! And it comes with a remote too. Perfect for family fun, especially in the summer!
