ear&ear HY300 PRO vs PANSEBA vs AUBOR Mini Projector: Which Offers Superior Digital Keystone Features?
WWGHIAFTC
ear&ear HY300 PRO Projector​
PANSEBA Mini Projector​
AUBOR Mini Projector​
$59.99​
$59.99​
$89.99​
Home Cinema​
Indoor/Outdoor​
User Manual, Power Cord, Projector Screen, Remote, HDMI Cable​
System: Android TV 13.0
App Ecosystem: Access to over 500,000 movies and TV shows
GPU: Mali-G31
Connectivity: WiFi 6, Bluetooth 5.0, compatible with 2.4G and 5G networks
Projection Flexibility: 180° rotational projection (wall, ceiling, floor)
Image Correction: Auto keystone correction, manual focus adjustment
Audio: 360-degree surround sound system
Video Resolution: Supports 1080P and 4K
Brightness: 200 ANSI lumens
Contrast Ratio: 1500:1
Noise Level: Below 25 dB
Ports: HDMI, USB, audio ports
Bluetooth Version: 5.2
Speaker Type: HIFI built-in speakers
Screen Size: Up to 200 inches
Brightness: 50% brighter than similar projectors
Contrast Ratio: 8000:1
Resolution: Supported 1080p
Image Clarity: 50% clearer than similar projectors
Lamp Life: 50,000 hours
Noise Level: Low noise operation
Input Compatibility: Laptops, smartphones, tablets, USB drives, X-Box
Connection Requirements: HDMI adapter for phones/tablets (not included)
MHL Support: Required for certain Android devices
Usage Note: Incompatible with Hulu for mirrored projectors
Smart Projector with Android TV 11.0: Access to 8000+ apps, 500,000+ movies/TV episodes, supports Netflix, Prime Video, YouTube, Disney+, HBO Max.
Design: Compact, palm-sized, weight 1.1 lb.
Video Quality: Native resolution 720P, supports 1080P Full HD, advanced LED technology for brighter edges.
Connectivity: WiFi 6, compatible with 2.4G and 5G networks, Bluetooth 5.2 for audio devices.
Projection Features: 180° rotating projection, projects onto walls/ceilings/floors, screen size 40-130 inches.
Correction Technology: Auto keystone and manual focus correction.
Audio: 360-degree sound.
Noise Level: <25dB.
Multi-device Connection: HDMI, USB, and audio ports; compatible with laptops, TV sticks, USB disks.
Customer Support: Free replacements and support offered.
Unboxing Experience​
ear&ear HY300 PRO Projector:​
The HY300 PRO Portable Projector impresses with its compact and lightweight design, making it easy to transport and set up in various environments. Its sleek and modern aesthetics add a touch of style, whether placed in a living room or taken outdoors for a movie night. The build quality feels solid, suggesting durability despite its small size, and the intuitive control layout makes it user-friendly right out of the box.
PANSEBA Mini Projector:​
Upon unboxing the mini projector, I was immediately struck by its compact and stylish design. It’s lightweight and portable, making it easy to transport for various uses, whether it's movie nights at home or presentations on the go. The sleek finish adds a modern touch, and the overall design feels sturdy without being cumbersome. The included projector screen is a nice touch, although it’s somewhat thin and transparent, which can be a drawback in certain lighting situations.
AUBOR Mini Projector:​
At first glance, this compact projector is surprisingly sleek and portable, which instantly caught my attention. Its small footprint makes it easy to store and transport, but it doesn’t compromise on build quality. The design is minimalistic yet stylish, allowing it to blend seamlessly into various environments, whether it's a cozy movie night at home or an outdoor gathering. I appreciate how its understated elegance adds a touch of sophistication without being overly flashy.
35 Inches - 130 Inches​
32 Inches - 200 Inches​
40 Inches - 1.3E+2 Inches​
35 - 130​
2.65 Feet - 26.25 Feet​
N/A - 13.12 Feet​
1500:1​
8000:1​
4096 x 2160​
1980 x 1080 Pixels​
1080 Pixels​
1280 x 720​
1280 x 720​
200 Lumen​
95 Lumen​
10000 lumen​
LED​
LED​
LED​
High Contrast Ratio and Full HD Resolution​
The viewing experience with the HY300 PRO is impressive, particularly given its price point. The projector delivers sharp and vibrant images, supporting resolutions up to 4K and 1080P, even in moderately lit rooms. Whether for gaming, watching movies, or giving presentations, the picture quality remains clear and engaging. The 180° rotatable design enhances flexibility in projecting onto different surfaces, while the built-in speaker provides decent audio quality, although connecting external speakers can elevate the experience even further.
The picture quality exceeded my expectations for such a compact device, delivering sharp and vibrant visuals even in less-than-ideal lighting conditions. The Full HD 1080P resolution is impressive, and I found the brightness adequate for dim rooms. However, I did notice that black levels could be a bit lacking unless in a darker environment. The built-in speaker is decent for casual use, but pairing it with external speakers significantly enhances the audio experience, especially when watching movies or playing games.
The viewing experience has been quite enjoyable, especially considering the projector's size. The brightness is impressive, and while it performs best in darker environments, I found it still delivers decent picture quality even in semi-lit rooms. The colors are vibrant and create a cinema-like atmosphere, enhancing the overall enjoyment of family movie nights. However, I did notice that darker scenes sometimes lose detail, particularly if the room isn't dark enough. The ability to project onto my ceiling has added a fun twist to watching movies, allowing for a unique viewing angle while lounging comfortably.
Portable, Auto Screen Alignment, Digital Keystone Correction, Built-In Wi-Fi, Built-In Media Player​
Built-In Speaker, Portable, Digital Keystone Correction, Lightweight, 50%-100% Zoom​
Portable, Built-In Cooling System, Automatic Keystone Correction, Speaker​
AVC​
H.264 or MPEG-4 AVC​
H.264 or H.265​
50000 Hours​
50000 Hours​
Button Control​
Wi-Fi​
Laptop, Tablet, Smartphone, Speaker​
TV Stick, Smartphone, USB, SD Card​
55 watts​
60 watts​
Mount Type​
Tabletop Mount​
Ceiling/Floor/Tabletop/Tripod/Wall Mount​
No installation​
7.28"L x 5.98"W x 2.95"H​
3.97"L x 3.97"W x 7.48"H​
Setting up the HY300 PRO is a breeze, requiring minimal time and effort. With pre-installed apps like YouTube and Netflix, plus the ability to download additional applications, navigating through the Android 13 interface is straightforward. The projector supports multiple connectivity options, including HDMI and USB, along with wireless capabilities through Wi-Fi 6 and Bluetooth 5.2, ensuring seamless streaming from various devices. The auto keystone correction feature makes alignment effortless, allowing users to focus on enjoying content rather than fiddling with settings.
Setting up the projector was refreshingly simple. Within minutes, I had it swapped out with my old projector and ready to go. The device offers multiple connectivity options, including HDMI, USB, and micro SD, which makes it versatile for connecting various devices like my Roku, Firestick, and even gaming consoles. The user interface is straightforward, allowing for quick adjustments to settings such as zoom and focus, ensuring I achieved a clear image with minimal hassle.
Setting up the projector is a breeze, making it incredibly user-friendly. I simply plugged it in, connected my devices, and was ready to go in just a few minutes. The various connectivity options, including HDMI, USB, and wireless capabilities, provide great versatility for different setups. The auto-keystone feature works flawlessly, allowing me to adjust the projection angle with ease, which is particularly handy when using it in multiple locations. Overall, the setup experience was straightforward and hassle-free.
• Good image quality – supports 4K and 1080P, delivering sharp and vibrant visuals.
• Fast connectivity – Wi-Fi 6 and Bluetooth 5.2 ensure stable and quick connections.
• Portable design – small, lightweight, and easy to carry.
• Auto keystone correction – makes setup effortless.
• 180° rotation – allows projection on the ceiling, wall, or any surface.
• Works best in a dark room; daylight affects image brightness.
• Built-in speaker is decent, but for better sound, an external speaker is recommended.
• Compatibility issues with Netflix accounts that have ads may limit streaming options.
Overall, the HY300 PRO Portable Projector exceeds expectations for its size and price, making it a fantastic option for anyone in search of a versatile and reliable projector. Its portability and ease of use make it suitable for a variety of settings, from home entertainment to outdoor movie nights. With impressive image quality and a user-friendly interface, I highly recommend this projector for anyone looking to enhance their viewing experience without breaking the bank.
• Excellent picture quality for a mini projector.
• Easy to set up and connect to various devices.
• Portable and lightweight design.
• Two-way Bluetooth functionality enhances audio options.
• Good value for the price.
• Built-in speaker could be improved; external speakers recommended.
• The included screen is somewhat thin and can be transparent.
• Limited adjustment options for picture size and angle.
• Some latency when using Bluetooth audio.
Overall, I am thoroughly impressed with this mini projector. It delivers exceptional value, combining portability with impressive image quality and versatile connectivity options. While there are minor drawbacks, such as the need for external speakers for optimal sound and some limitations with the included screen, these do not detract significantly from the overall experience. Whether for movie nights, gaming, or presentations, this projector is a fantastic investment that I would highly recommend to anyone looking for a reliable and portable projection solution.
• Portability is a standout feature.
• Excellent picture quality for a compact projector.
• Quick and easy setup.
• Multiple connectivity options available.
• Vibrant colors and decent brightness.
• Built-in sound quality could be better; external speakers are recommended.
• Limited resolution compared to higher-end projectors.
• Some streaming apps have compatibility issues.
Overall, I am quite satisfied with this mini projector. While it has some limitations, especially regarding sound quality and app compatibility, its portability and ease of use more than make up for these drawbacks. It's an excellent choice for anyone seeking a compact and affordable projector for casual viewing, whether it’s for family movie nights at home or outdoor gatherings. Despite a few quirks, I find it to be a fantastic value for the price, and I can see it becoming my go-to gadget for entertainment.
GreatKangaroo
The ear&ear HY300 PRO Projector is awesome! The picture is super sharp, and the auto keystone correction lines everything up perfectly. With WiFi 6 and Bluetooth, streaming is a breeze. It’s small, light, and perfect for movie nights. Plus, it has a built-in Android system! For the price, it's a steal. Totally happy with my buy!
GreatKangaroo
Just got the ear&ear HY300 PRO mini projector, and I’m loving it! It’s super portable and the picture quality is awesome. Set up was a breeze and it connects with all my devices. The built-in speaker’s decent, but hooking up external speakers really pumps up the sound. Overall, if you want a compact projector, this one’s a winner!
El_Frijol
The ear&ear HY300 PRO Projector is awesome! I wanted a budget-friendly option for movie nights, and this one blew me away! The picture is super clear and bright, even with some lights on. Plus, it’s lightweight and easy to take anywhere, perfect for inside or outside fun!
Check out the PANSEBA Mini Projector! It's super compact and you can easily plug in a USB stick or an external hard drive, plus it works great with a Google Chromecast. You can enjoy your media on a big screen—up to 100 inches! While it’s not exactly theater-level quality, it definitely delivers for the price. Plus, it’s a breeze to set up and adjust on any wall.
fosterzar
I got the AUBOR Mini Projector to replace my TV, but it turned out to be perfect for holiday decorations! It’s awesome for Halloween and Christmas!
