ear&ear HY300 PRO vs ENUOSUMA Mini vs PANSEBA Mini Projector: Which Offers the Best Built-in Apps?
joe603
ear&ear HY300 PRO Projector​
ENUOSUMA Mini Projector​
PANSEBA Mini Projector​
$59.99​
$59.99​
$59.99​
Education, Indoor/Outdoor, Home Cinema, Gaming, Business​
Home Cinema​
Projector, Power Cord, infrared remote​
User Manual, Power Cord, Projector Screen, Remote, HDMI Cable​
Operating System: Android TV 13.0
App Ecosystem: Access to over 500,000 movies and TV shows
GPU: Mali-G31
Connectivity: WiFi 6
Projection Angle: 180° free rotation
Use Cases: Home theater, education, video conferencing
Keystone Correction: Automatic with manual focus adjustment
Audio System: 360-degree surround sound
Video Resolution: Supports 1080P/4K
Brightness: 200 ANSI lumens
Contrast Ratio: 1500:1
Cooling Noise Level: Below 25 dB
Ports: HDMI, USB, audio ports
Bluetooth Version: 5.0
Network Compatibility: 2.4G and 5G networks
Smart Projector: Android TV 11, over 4000 apps, access to Netflix, Prime Video, YouTube, 500,000+ movies and TV shows
Video Resolution: Native 1080P, 4K support, advanced LED technology
Brightness & Contrast: 200 ANSI lumens, 1500:1 contrast ratio
Connectivity: WiFi 6, Bluetooth 5.2, compatible with 2.4G and 5G networks
Projection Capabilities: 180° rotation, 35-130 inch screen size
Audio: 360° sound
Keystone Correction: Automatic keystone and manual focus adjustment
Noise Level: Below 25dB
Bluetooth Version: 5.2
Speaker Type: HIFI
Screen Size: Max 200 inches
Brightness: 50% brighter than similar projectors
Contrast Ratio: 8000:1
Resolution Supported: 1080p
Image Clarity: 50% clearer than similar projectors
Noise Level: Low noise
Lamp Life: 50,000 hours
Input Compatibility: Laptops, smartphones, tablets, USB drives, X-Box
Connection Requirements: HDMI adapter for phone/tablet connection (not included)
Special Note: Mirrored projectors incompatible with Hulu, use TV Stick instead.
Unboxing Experience​
ear&ear HY300 PRO Projector:​
Upon first glance, the HY300 PRO mini projector boasts a sleek and modern design that immediately catches the eye. Its compact size allows it to fit easily in a backpack, making it highly portable for various settings. The build quality feels solid, and the overall aesthetics are pleasing, giving it a stylish look that would fit well in any home or office.
ENUOSUMA Mini Projector:​
The ENUOSUMA Mini Projector has a sleek and compact design that is both stylish and practical. Its lightweight build makes it highly portable, allowing me to easily move it around or take it on trips. The 180° rotatable feature stands out, enhancing versatility in positioning. Overall, it’s an attractive device that doesn’t take up much space, making it ideal for any setting, whether at home or outdoors.
PANSEBA Mini Projector:​
The PANSEBA Mini Projector boasts a sleek and compact design that is both lightweight and portable, making it easy to transport for various uses, whether indoors or outdoors. Its modern aesthetic fits well in any setting, whether it’s a cozy movie night at home or an outdoor gathering. Despite its small size, the projector feels well-constructed and sturdy, with a balanced weight that ensures it remains stable when placed on stands or tables.
35 Inches - 130 Inches​
35 Inches - 1.3E+2 Inches​
32 Inches - 200 Inches​
35 - 130​
1.2 Meters - 4 Meters​
2.65 Feet - 26.25 Feet​
1500:1​
1500:1 Pixels Per Inch​
8000:1​
4096 x 2160​
1280 x 720 Pixels​
1980 x 1080 Pixels​
1280 x 720​
1024 x 720​
200 Lumen​
160 lumen​
95 Lumen​
LED​
LED​
LED​
High Contrast Ratio and Full HD Resolution​
The viewing experience with the HY300 PRO has been nothing short of impressive. The projector delivers sharp and vibrant images, supporting resolutions of up to 4K and 1080P, which makes it ideal for movie nights, gaming, or presentations. Even in rooms with some ambient light, the image quality remains bright and clear. The auto keystone correction works flawlessly, ensuring that the projection is perfectly aligned regardless of the surface, while the 180° rotation feature provides flexibility in setup.
The viewing experience with this mini projector is impressive. It supports both 4K and 1080P resolutions, delivering sharp and vibrant images that enhance movie nights and gaming sessions. The brightness level of 200 ANSI lumens performs well in dimly lit rooms, although I noticed that it may struggle slightly in brighter environments. The picture quality is consistently clear and detailed, making it feel like a home theater experience. However, while the built-in speakers are decent for casual use, I found that connecting external speakers, such as the ANKER Soundcore 2, significantly enhances the audio quality.
The viewing experience with this projector is impressive, especially considering its price point. The Full HD 1080P resolution delivers sharp and vibrant visuals that enhance movie nights or presentations. While it performs well in dimly lit environments, it’s worth noting that black levels may struggle in brighter rooms. The overall picture quality remains satisfactory, with easy adjustments for zoom and focus that make achieving the perfect image a breeze.
Portable, Auto Screen Alignment, Digital Keystone Correction, Built-In Wi-Fi, Built-In Media Player​
Built-In Apps and Android 11, 5G WIFI + 2.4G WiFi, Support 4K 1080P, Auto Keystone Correction, Built-In Media Player​
Built-In Speaker, Portable, Digital Keystone Correction, Lightweight, 50%-100% Zoom​
AVC​
H.264 or MPEG-4 AVC​
6E+1 Watts​
50000 Hours​
50000 Hours​
Button Control​
App, Remote​
Laptop, Tablet, Smartphone, Speaker​
TV Stick, Smartphone, USB, SD Card​
55 watts​
Mount Type​
Tabletop Mount​
Tabletop Mount​
Ceiling/Floor/Tabletop/Tripod/Wall Mount​
7.28"L x 5.98"W x 2.95"H​
Setting up the HY300 PRO was a breeze, taking just a few minutes to get started. The intuitive interface means that no lengthy manual is necessary, which is a huge plus for someone like me who prefers quick and straightforward configurations. With multiple connection options, including HDMI and USB, I found it easy to stream content directly from my devices without hassle. The built-in Android system also allows for seamless access to popular streaming apps, further enhancing its usability.
Setting up the projector was a breeze; I was pleasantly surprised by how quickly I could get it going. The user-friendly interface and clear setup instructions made connecting to Wi-Fi and Bluetooth effortless. I used it with an HDMI device, and the automatic keystone correction worked flawlessly, ensuring the image was perfectly aligned. I appreciate the built-in Android 11 system, which allows for direct app access, although I found that using external devices like a Fire Stick greatly improved the overall experience.
Setting up the projector was incredibly straightforward and intuitive. Within just a few minutes, I was able to swap it out for my old projector and get it running seamlessly. The connectivity options are extensive, including HDMI, USB, and micro SD card slots, which allow for easy connections to devices like Roku, Firestick, or gaming consoles. The included projector screen, while somewhat sheer, adds to the convenience, although care should be taken if projecting against a non-plain surface to avoid translucency issues.
• Excellent image quality with 4K and 1080P support.
• Fast connectivity with Wi-Fi 6 and Bluetooth 5.2.
• Lightweight and portable design.
• Auto keystone correction for easy setup.
• Versatile projection options with 180° rotation.
• Best performance is in dark environments; daylight can diminish brightness.
• Built-in speaker is decent but an external speaker is recommended for better audio quality.
Overall, the HY300 PRO mini projector has exceeded my expectations, proving to be a powerful and versatile device that’s perfect for both home and outdoor use. Its combination of portability, ease of use, and impressive image quality make it a fantastic choice for anyone in need of a reliable projector. Whether for family movie nights or casual presentations, I highly recommend this projector for its excellent value and performance.
• Very good and clear picture quality.
• Bright and looks great on a white ceiling.
• Super easy setup; just plug in and power on.
• Compact and portable, making it easy to carry.
• Excellent value for the price.
• Native apps can be laggy and don't connect well to the internet.
• Built-in audio quality is decent but not ideal for larger gatherings.
• Remote control does not come with batteries.
• Limited app selection on the device itself.
Overall, the ENUOSUMA Mini Projector has exceeded my expectations in terms of performance and value. It’s a fantastic option for anyone looking for a reliable and portable projector for home entertainment or presentations. While there are minor drawbacks, such as the sound quality and app performance, the advantages, including the image clarity and ease of use, make it a worthwhile investment. I highly recommend it for anyone seeking a quality projector at an affordable price.
• Excellent picture quality for the price
• Portable and lightweight design
• Wide connectivity options (HDMI, USB, micro SD)
• Two-way Bluetooth functionality for enhanced audio experience
• Included projector screen for improved viewing
• Built-in speaker is decent but not powerful enough for larger spaces
• Screen can be slightly transparent when projecting on non-plain surfaces
• Bluetooth audio may have minor latency issues
• Limited internal app functionality; requires external devices for streaming apps
Overall, the PANSEBA Mini Projector has exceeded my expectations and stands out as a fantastic choice for anyone in need of a portable and affordable projection solution. Its combination of excellent image quality, user-friendly setup, and versatile connectivity options make it suitable for a variety of uses, from family movie nights to outdoor events. While there are a few minor drawbacks, such as the need for external speakers for optimal audio, the overall value and performance make this projector a highly recommendable investment for casual users.
Astro51450
I got the ear&ear HY300 PRO Projector and it had all the cool features I wanted like smart TV, WiFi, and Bluetooth. But it was too dim for me, so I ended up returning it.
Curtis_Baefield
Just got my hands on the ear&ear HY300 PRO mini projector, and I’m loving it! It's super portable and the picture quality is awesome for its size. Setup was a breeze, and it connects easily with other devices. The built-in speaker is decent, but hooking it up to external speakers really amps it up. Overall, it’s a solid choice if you want a compact projector!
The ENUOSUMA Mini Projector totally blew me away! The picture quality is incredible—super bright, sharp colors, and awesome detail at 1080P. Plus, it supports 4K, so movie nights just got way better. It's super easy to set up and use too. Perfect for your home theater!
AlrightMister
The ENUOSUMA Mini Projector is a lifesaver for our tiny room! We can watch movies on the wall, and the sound is pretty loud with good picture quality. Plus, we can hook up our phones easily. Super convenient!
Wow, the ENUOSUMA Mini Projector is awesome! It throws up a big, clear image even in a lit room. Super easy to focus too. Perfect for anyone looking for a budget-friendly, solid projector!
The ENUOSUMA Mini Projector is awesome! The picture is super clear, and it’s super easy to set up. Perfect for movie nights or presentations. Plus, it’s small enough to take anywhere. Great bang for your buck!
Check out the PANSEBA Mini Projector! It’s super compact and lets you plug in a USB stick, hard drive, or even a Google Chromecast to watch stuff up to 100 inches. While it’s not going to match theater quality, it’s a solid performer for the price. Plus, it’s a breeze to set up and adjust on any wall!
Wwalmarts
PANSEBA Mini Projector is awesome! Great bang for your buck. I’d give it 5 stars if the screen wasn’t a bit wonky and the cord was longer. Also, I wish it had full Bluetooth. Still, I’d totally buy it again!
