E460 vs Cacacol P20 Pro: Which Mini Projector Offers Better Features for Outdoor Movie Nights?
Amanda Brown
Active member
  1. 1 Specs
  2. 2 Which to get
In today’s comparison, we’re diving into two projectors that cater to those who want to bring the big screen experience into their space. On one hand, we have the Portable Mini Projector, which touts its compact size and convenience for on-the-go viewing. On the other, there's the Cacacol P20 Pro Smart Projector, which promises impressive specs like native 1080p resolution, 4K support, and a brightness output that could rival a small cinema.
While the Portable Mini Projector focuses on portability, we’ll explore if it sacrifices performance for size. In contrast, the Cacacol P20 Pro aims to deliver a premium home theater experience with features like electric focus and auto keystone correction. But does that make it worth the investment, or is it overkill for casual viewers?
Join us as we dissect the strengths and weaknesses of both options to help you determine whether you should prioritize portability or performance in your next projector purchase.
Specs​
Portable Mini Projector Projector​
Cacacol P20 Pro Smart Projector​
$169​
Home Cinema​
Power Cord, Remote​
-✅ 【Native 1080p Full HD & Support 4k Projector】This Full HD 1080p projector with wifi 6 and bluetooth supports 4K video and has a brightness of up to 700 ANSI/15,000 lumens, presenting clear bright and vivid HD image effects.
✅ 【Electric Focus & 4P Auto Keystone Correction】This video projector has Electric focus, you can easily get a clear projection picture; It also auto keystone correction 4P correction function.
✅ 【Flagship Strong CPU/GPU Hardware System】Amlogic T950S Quad-Core CPU, with 2GB Running Memory and 16GB eMMC Internal Storage;
40 Inches - 150 Inches​
0.5 Meters - 6 Meters​
4096 x 2160 Pixels​
4000 Lumen​
LED​
Portable​
Built-In Speaker, Digital Keystone Correction, Auto Focus, Built-In Wi-Fi​
VP9​
10 Watts​
20000 Hours​
Button Control​
USB​
Smartphone​
180 watts​
Mount Type​
Tabletop Mount​
Tabletop Mount​
Which to get​
Looking to make a decision on which projector to grab, and I could really use your input!
First up, we have the **Portable Mini Projector**. While I don't have the full deets, I’m curious if it can compete with the Cacacol P20 Pro Smart Projector, which boasts some serious specs.
The **Cacacol P20 Pro** comes in with a **native 1080p** and supports **4K**—that’s a big plus for picture quality. Plus, its **700 ANSI lumens** brightness should keep the visuals sharp and vibrant, even in less-than-ideal lighting. The **electric focus** and **4P auto keystone correction** sound like they’ll make setup a breeze.
On the sound front, I’d love to know if the **Portable Mini Projector** has decent audio or if I’ll be left hunting for external speakers. The Cacacol is a bit of a powerhouse with its **Amlogic T950S Quad-Core CPU** and **2GB RAM**, but I wonder if there are any downsides with it, like heat issues or fan noise.
If anyone has experience with either of these, particularly on picture and sound quality, system performance, and any potential downsides, I’d really appreciate your thoughts!
