BigZ
Does JMGO O1 Pro projector include a sleep timer?
Yes, you can activate the timer.
1. Go to the Settings of your projector.
2. Select Advanced Settings
3. Go to Timed Shutdown. JMGO O1 Pro will be shut down if no activity is detected after 15/30/60/120/180 minutes. You may set your own timer by clicking the "User-Defined" button on the same menu.
Alternatively, you may set JMGO O1 Pro to enter Companion Mode if no activity is detected after 15/30/45/60 minutes.
