Guide: The newly launched Dangbei X3Pro is a strong upgrade on the basis of the previous generation, and it has leapfrogged to achieve 4K ultra-high-definition pictures. What is the difference between it and the XGIMI rspro2, which also has 4K, has become a hot topic. So, which is better when comparing Dangbei X3Pro and XGIMI rspro2 projector? After reading this article, you will have a clearer understanding of the parameters of Dangbei X3Pro and XGIMI rspro2.
![]() ![]() content: 1. What is the difference between Dangbei X3Pro and XGIMI rspro2? 1. Optical display comparison 2. System configuration comparison 3. Comparison of projection parameters 4. Feature comparison 5. Image technology comparison 2. Dangbei X3Pro vs XGIMI rspro2 parameter comparison table 3. Summary of Dangbei X3Pro vs XGIMI rspro2 projector ![]() 1. What is the difference between Dangbei X3Pro and XGIMI rspro2? 1. Optical display comparison In terms of optical parameters , these two projectors also use DLP display technology. The Dangbei X3Pro projector uses ALPD laser fluorescent display technology , while the XGIMI rspro2 projector uses traditional LED light sources. Dangbei X3Pro laser has the advantages of high brightness and good color simplicity. In terms of brightness , the Dangbei X3Pro has an ultra-high brightness of 3200ANSI lumens , while the brightness of the XGIMI rspro2 projector is only 2200ANSI lumens. Obviously, Dangbei X3Pro is absolutely overwhelming in brightness. With the advantage of high screen brightness, even in the room with ambient light interference, it can easily cast a clear picture. In terms of resolution , both projectors have 4K resolution, which can ensure high-definition lossless image quality viewing, but limited by the light source technology, the XGIMI rspro2 has a relatively weak picture performance. ![]() ![]() 2. System configuration comparison In terms of hardware configuration , Dangbei X3Pro and XGIMI rspro2 projectors are also equipped with MT9669 flagship processor, and equipped with 4+128G large storage, with powerful image processing capabilities, which can decode video signals faster and facilitate local storage. Ultra-high-definition video source, bringing the ultimate viewing experience. In terms of built-in system , Dangbei X3Pro adopts the new Dangbei OS3.0 intelligent operating system , equipped with system memory optimization technology and multi-user mode that far exceeds the industry, and integrates videos from the whole network including Mango TV, iQiyi, Tencent Video, Youku, etc. Platform resources, while saying goodbye to drama shortages, can also ensure a smooth operation experience with zero lag. XGIMI rspro2 has a built-in INUI intelligent operating system and also supports multi-user mode. ![]() ![]() 3. Comparison of projection parameters In terms of projection range , Dangbei X3Pro is equipped with a 1.2:1 projection ratio and a distance of about 2.6 meters, which can easily project a 100-inch large screen, while XGIMI rspro2 is equipped with a 1.25x optical zoom, which can be flexibly adjusted according to the projection distance. , but for home use, Dangbei X3Pro is enough for daily use. In terms of picture correction , both projectors support automatic keystone correction technology and have automatic sensorless focusing function. Among them, Dangbei X3Pro adopts automatic six-way keystone correction, which can realize automatic keystone correction, automatic screen entry and intelligent obstacle avoidance three-in-one 1. Depth-corrected projection images to keep them square at all times. ![]() ![]() 4. Feature comparison In terms of use functions , Dangbei X3Pro and XGIMI rspro2 are equipped with automatic screen entry, intelligent obstacle avoidance, intelligent eye protection and wireless screen projection. Among them, Dangbei X3Pro has a built-in self-developed Dangbei projection screen, and the mobile phone screen can be played immediately, completely free of charge, without advertising interference. In terms of special functions , Dangbei X3Pro, with its powerful software and hardware strength, exclusively launched functions such as magic on the same screen, mobile application compatibility, desktop DIY, double-speed playback, remote control multi-mode and full-network search, etc., to take care of users of all ages. Use experience. ![]() ![]() 5. Image technology comparison In terms of image processing , Dangbei X3Pro adopts AI color engine Pro, which can intelligently reshape the color and details of the picture in real time, repair the color blocks from the source, and reshape the original picture quality; while XGIMI rspro2 adopts X-VUE2.0 picture quality Engine, both projectors support global MEMC motion compensation, and are equipped with ambient light adaptation and AI image quality enhancement to optimize viewing details. ![]() ![]() 6. Comparison of accessories specifications In terms of accessories , Dangbei X3Pro and XGIMI rspro2 both use metal textured Bluetooth remote control, but Dangbei X3Pro adds dual magic side buttons, which support one-key focus and call up the shortcut menu, which is more convenient to use. In terms of specifications , both projectors are equipped with Dolby DTS, and the Dangbei X3Pro projector is equipped with dual 10W speakers, with Viper sound effects, to fully immerse the scene. The XGIMI rspro2 still uses Harman Kardon speakers. ![]() ![]() 2. Dangbei X3Pro vs XGIMI rspro2 parameter comparison chart ![]() ![]() ![]() 3. Summary of Dangbei X3Pro vs XGIMI rspro2 projector The above is the difference between Dangbei X3Pro and XGIMI rspro2? It is not difficult to see which of the two 4K flagships is better. Although they are both 4K projectors, the Dangbei X3Pro is positioned as the 4K laser flagship projector within 10,000 yuan, while the XGIMI rspro2 is LED home 4K projection, Dangbei X3Pro is a better choice in terms of picture brightness, hardware configuration and cost-effectiveness. For more projector purchases, you can also pay attention to: Dangbei Projector . Source : touying.com |
