Bellmeister
- 1 Introduce
2
Side-by-Side Comparison
- 2.1 Display
- 2.2 Features
- 2.3 Connectivity
- 2.4 Measurements
- 3 Conclusion
Parameter | ClokoWe Mini Projector | ZDK Mini Projector | VOPLLS Mini Projector | Tasofac Mini Projector |
Picture | ||||
Price | $98.89 | $249.99 | $179.99 | $169.99 |
Recommended Uses | Education, Home Cinema, Gaming, Business | Indoor/Outdoor | Indoor/Outdoor, Home Cinema, Gaming | Outdoor/Indoor Movie Nights, Home Cinema Travel, Party, Education, Camping, Gaming, Business |
Highlight | Resolution: HD 1080P and 4K support Lens: High refractive index 5-layer glass lens Projection Modes: 6 galaxy projection modes Ambient Light Colors: 7 colors Stand: 270° rotatable built-in stand WiFi: Dual Band WiFi 6 Bluetooth: Bluetooth 5.2 Speaker: 5W stereo HiFi speaker Keystone Correction: Auto keystone correction Zoom: 50%-100% zoom Aspect Ratios: 4:3 and 16:9 Connectivity: USB/HDMI/AV/Audio/Chromecast interfaces Compatibility: Supports various devices (phones, Fire TV, tablets, laptops, PCs, DVD players, gaming consoles) | Connectivity: Wifi, Bluetooth, HDMI cable, wired or wireless projection Resolution: Supports 4K via HDMI, 1080P wireless Brightness: 16000 Lumens Lamp Life: 50000 hours Screen Size: Adjustable 30-300 inches Compatibility: Works with TV Stick, iPhone, Android, Tablet, Laptop, PC, USB, PS4, Gaming Consoles Dimensions: 7.7 x 6.1 x 3.1 inches Weight: 1.8 pounds Usage Scenarios: Home theater, outdoor activities, conferences, gaming Warranty: 2 years with satisfaction guarantee | Design: Sleek, portable, compact (6cm), lightweight, minimalist, premium hardcover book appearance Projection Technology: 4K resolution, automatic fast focus (5 seconds), 6D all-around keystone correction, real-time image optimization Adjustable Bracket: 360° rotatable, tool-free assembly, easy operation, lens protection Resolution & Brightness: Native FHD 1080P, 550 ANSI brightness, high-definition picture quality Connectivity: WiFi 6 (stable, rapid transmission), Bluetooth 5.2 (seamless audio sync), supports wireless screen mirroring Usage Scenarios: Backyard movie nights, outdoor camping, gaming, garden parties, sports viewing | Auto Screen Adjustment: Automatically fits the projector to the screen size quickly without changing placement. Multi-Connection: HDMI, USB, AV interfaces; compatible with various devices (TV sticks, smartphones, laptops, etc.); offers replacement or refund service. Auto Keystone Correction: 6D Auto keystone correction for clear rectangular images; manual adjustment available via remote. Resolution & Brightness: 1920*1080P native resolution, 800 ANSI brightness, 15000:1 contrast; supports 4K video sources. WiFi 6 Screen Mirroring: Supports wireless screen mirroring with dual-band WiFi; stable and fast transmission; some apps may require HDMI for mirroring. Auto Focus: Focuses automatically within 3 seconds; manual focus adjustment possible via remote control. |
Screen Size | - | 35 Inches - 3E+2 Inches | 210 Inches - 40 Inches | 40 Inches - 300 Inches |
Throw Distance | 3.3 Feet - 9.8 Feet | - | 1.5 - 3 Meters | 1 - 5 Meters |
Contrast Ratio | - | - | - | 20000:1 |
Display Resolution | 1280 x 720 Pixels | 1920x1080 Pixels | 3840 x 2160 Pixels | 4K |
Native Resolution | 1280 x 720 | 1920 x 1080 | 1920 x 1080 | 1920 x 1080 |
Brightness | - | - | - | 800 |
Display Type | LCD | LCD | LCD | LCD |
Picture Quality Enhancement | - | - | - | Implicitly mentioned: advanced chip and LED lens technology |
Video Encoding | - | - | - | H.265 |
Lamp Wattage | - | - | - | - |
Light Source Life | - | - | - | - |
Controller Type | - | Button Control | Remote Control, Touchpad Control | Remote Control |
Control Method | - | App | Remote, Touch | Remote |
Mount Type | Tabletop Mount | Tripod Mount | Ceiling Mount | Ceiling Mount/Table Mount/Wall Mount/ Tripod |
Noteworthy Features | Portable | Speakers | Portable, Auto Obstacle Avoidance, 360° rotating stand and ultra-thin mini projector, 5G+2.4G WiFi Connection & 5.2 Bluetooth Connection, Auto Focus & Auto Keystone | Auto Focus, Keystone, WiFi 6 Screen Mirroring, Two-way Bluetooth, 4K Support, Obstacle Avoidance, Adjustment |
Connectivity
Connectivity Technology | Bluetooth, Wi-Fi, USB, HDMI, 3.5mm Jack | USB | Bluetooth, Wi-Fi, USB, HDMI, 3.5mm Jack | Bluetooth, Wi-Fi, USB, HDMI, 3.5mm Jack |
Hardware Connectivity | - | - | Bluetooth, USB, HDMI, 3.5mm Audio | Bluetooth, USB, HDMI, 3.5mm Audio |
Compatible Devices | - | Iphone, Android, Ipad, Laptop, TV Stick | Laptop, Television, Tablet, Smartphone, Speaker | Laptop, Smartphone, Gaming Console |
Measurements
Dimensions L x W x H | - | - | 7.91"L x 2.36"W x 7.87"H | - |
Item Weight | - | - | 1.01 Kilograms | - |
Product | PROS AND CONS |
ClokoWe Mini Projector | Pros: • High quality and well-built construction • Flexible and long enough for various setups • Durable and reliable performance • Easy to use with simple plug-and-play functionality • Supports high-definition visuals and fast data transfer • Compatible with multiple devices, enhancing versatility • Suitable for both indoor and outdoor use • Affordable price point Cons: • Limited to 5 feet in length, may not suit all setups • No mention of additional features like gold plating or shielding Overall Impression: This HDMI cable is an excellent choice for those seeking a reliable and high-quality connection for their devices. Its durability, ease of use, and compatibility with various technologies make it a valuable addition to any home entertainment system. Overall, it offers great performance at an affordable price, making it highly recommendable. |
ZDK Mini Projector | Pros • Good resolution and image quality • Easy setup and installation • WiFi connectivity for smooth HD streaming • Bluetooth compatibility for enhanced audio experience • Lightweight and portable design • Long battery life, allowing for multiple movie viewings • Versatile usage for various settings (home, outdoor, travel) • Stable connection with no major issues • Suitable for projecting on walls or screens Cons • Sound quality from the projector itself is limited • Requires recharging after several uses Overall Impression This projector is an excellent choice for anyone seeking a portable, user-friendly device that delivers high-quality visuals and seamless connectivity. Its impressive battery life and lightweight design make it ideal for both home and on-the-go use, while the easy setup enhances the overall experience. However, potential users should consider the sound limitations when not connected to an external audio system. |
VOPLLS Mini Projector | Pros • Compact and portable design • Easy setup with intuitive auto focus • Sufficient brightness for indoor use, even with lights on • Quick Bluetooth connectivity for headphones • Effective Android mirroring without issues • Built-in stand for versatile positioning • Impressive audio quality for videos and music • Useful for creative projects like tracing images Cons • Short power cord may require an extension • Bluetooth connection issues with phones • Auto focus can alter settings if not turned off in specific use cases Overall Impression This projector is a surprisingly effective and portable option for various uses, from casual viewing to creative projects. Its ease of setup, decent brightness, and good audio quality make it a solid choice without the hefty price tag of high-end models. While there are minor drawbacks, such as the short power cord and occasional Bluetooth connectivity issues, the overall performance and versatility make it a worthwhile investment. |
Tasofac Mini Projector | Pros: • Easy WiFi connection • Automatic focus and keystone correction • Built-in speaker performs well; Bluetooth functions flawlessly • Low fan noise • Bright and vivid picture quality, even in modest light • Quick and smooth connections with devices like Firestick, iPhone, and iPad • Compact design that's easy to set up • Comes with everything needed to start right out of the box • High-quality remote control • Adjustable screen tone options Cons: • Some streaming services may require a Firestick for playback • Limited manual adjustments needed; might not suit users who prefer detailed customization Overall Impression: This projector stands out as an impressive choice for both indoor and outdoor use, offering exceptional ease of setup and high-quality performance. Its automatic features and strong connectivity options make it an ideal option for those seeking convenience without sacrificing picture quality. While it has minor limitations regarding streaming services, overall, it is a top contender in its class and highly recommended for home theater enthusiasts. |
