Call of Duty: Warzone 4 basic tips for getting out in a battle royale
Celine2020
Each battle royale presents specificities, but all are based on the same unshakable principle: a large number of players (150 for Call of Duty Warzone ) dropped into a card that will be tirelessly reduced until the end of the game, where it can only stay one person (or squad) alive. So let's start with some basic tips to last more than three minutes in this hostile world.
1.The goal is to be the last alive, not to have the most frags
We can never repeat it enough, the BR is a marahon, not a sprint. Do not hesitate to take your time, to measure the risks of each of your decisions and, sometimes, to wait foolishly until the next area is indicated on the map. Camping is sometimes winning and securing a place in the last twenty or ten players in the running will sometimes require spending time defending an area until migrating to the interior of the next area. Don't be afraid to camp .
2.Engage the enemy only if you are sure of winning the confrontation
Spotting a player is not reason enough to shoot him. Evaluate the risks, indicate their position to your allies and try to see if he was part of a squad or not. A few seconds spent following it from afar can allow you to determine whether it was a lone wolf or a well-equipped squad, so prepare for the confrontation with intelligence. Coordinate your actions, divide up different lines of fire to cover, plan an emergency exit and above all, take care of your entry. An explosive, a stun grenade or a smoke bomb can do the trick.
3.Communicate, use the compass and abuse the ping system
Already, the question does not even arise if you play with partners who do not have a microphone. Your only means of communication will be in the ping system, which you can use to indicate a destination, an item to pick up, or an enemy. However, having a microphone does not exempt you from using it, and you will be much more effective if you abuse the on-screen directions to tell your friends exactly where to go. For points of interest that are too far away that cannot be marked, look up at the compass and orient yourself using the numbers.
4.Do not stay near your vehicle after getting out
A car that is not well parked, a helicopter in the forest or an SUV on the roof of a building, it quickly becomes a task. Unless you are forced to use your vehicle to protect yourself from a heavy fire, try to move away from it after arriving at your destination to surprise your opponent. In Warzone, this is an even more important concept since vehicles belonging to an opposing player are indicated in red on the minimap.
