AssasinK
If you are a beginner in Borderlands 3, which character is easy to use? Which role should you choose? New game players don’t know which character is good. Here is a guide to the selection of the characters in the Borderlands 3. Let’s take a look.
1. Amara
Although Amara has auxiliary and defensive capabilities, Amara is still a hunter. In terms of combat, Amara can play the most powerful combat power and bring elemental weapon damage. If you want to stay aggressive all the time, then Amara is your best choice. Players can also upgrade Amara's melee combat power and elemental weapon combat power. Compared with other characters, Amara is more difficult to get started.
2. Zane
Zane likes to throw grenade madly. He is good at attacking while moving around and can use 2 active skills at the same time. Zane has the Digi-Clone ability, which allows Zane to summon his static clones and then exchange positions with it at any time. He can blow up everything quickly and move away quickly. How to choose the position of your clone, so that Zane can still withdraw after a crazy bombing, is a required course for players.
3.Moze
Moze is very suitable for beginners to use. Moze itself does not have a strong combat power, but Moze can use robot bear for various battles. The robot bear has a time limit, but it is enough for Moze to cause huge damage. Its weapons started with professional V35 grenade launchers, Minigun and Railgun, but upgrading Moze's skills can get more weapons and unlock other firepower equipment, such as flamethrowers and rockets.
4.FL4K
FL4K is more like a hunter designed specifically for singles. FL4K pets can revive FL4K when FL4K dies, and FL4K can also revive their pets through skills. FL4K's main skills are designed for pets, so understanding the characteristics of pets and making decisions is the focus of playing FL4K. FL4K is suitable as a long-range sniper, with some Mordecai and Zero skills, can enter a short-term invisible state. The difficulty of FL4K is how to skillfully operate your pet to cooperate with yourself, which may require players to spend a certain amount of time and energy.
The above is the Borderlands 3 role selection suggestions. Wish you have a good time with this game. For more information about the Borderlands 3, check my reviews and click here. Welcome to comment.
1. Amara
2. Zane
3.Moze
4.FL4K
