BIGASUO Mini Projector vs WiMiUS Mini Projector vs BIGASUO Projector: Which is Right for Outdoor Use?
WWGHIAFTC
BIGASUO Mini Projector​
WiMiUS Mini Projector​
BIGASUO Projector​
$34.99​
$129.99​
$99.98​
Indoor Outdoor Projector for movie​
Home Cinema​
Home Cinema, Outdoor Movies, Gaming​
Quick Guide, Small Projector with Tripod, Remote Control, Battery Built-In Projector Rechargeable, HDMI Cable​
1* HDMI Cable, 1* Lens Cover, 1* S27 WiFi Bluetooth Mini Projector, 1* Power Cord, 1* Remote Control​
Projector, Built-in DVD Player, User Manual, Remote Control, Carry Bag, Tripod, HDMI Cable, AV VGA AC Adapter, Dual Powerful Speakers​
Projector Type: Built-in Battery Powered
Battery Life: Up to 1-1.5 hours
Resolution: Native 1080P
Brightness: 9000L (DC Power Mode)
Contrast Ratio: 10000:1
Audio: Built-in dual speakers, Bluetooth support (audio only)
Projection Size: 35-200 inches
Keystone Correction: ±15°
Size Comparison: Approximately the size of 2 Coke cans
Connectivity: HDMI, USB, AV, Micro SD, 3.5mm headphone jack
Compatibility: Fire TV Stick, Roku, DVD, Laptop, USB, Computer, Headphone, External Speaker, iPhone, Android Phone, iPad, PS5
Installation Options: Desktop, bracket support, ceiling installation
Model: S27
Projection Ratio: 0.98:1
Projection Size: 40~200 inches
Throw Distance: 2.8ft to 14ft
Aspect Ratios: 4:3, 16:9
Interfaces: HDMI, USB, 3.5mm audio port
Connectivity: 2.4G/5G Dual Band WiFi, Bluetooth 5.2
Mounting Options: Ceiling and wall mounting
Sound System: Upgraded for clearer sound
Support: 24/7 after-sales, 2-year Money Back, 3-year Repair, Lifetime Technical Support
Firmware Updates: Available for HDMI compatibility and screen mirroring issues
Note: Not battery-powered, requires plug-in during use
Product Type: 2-in-1 DVD projector
Resolution: HD 1080P
Brightness: 9000 Lux
Speaker: Built-in dual speakers with HiFi sound
Bluetooth: Bluetooth 5.0 (not compatible with smartphones)
Port Compatibility: USB, HDMI, AV, VGA, Micro SD, Audio port
Supported Disc Formats: CD, DVD, CD-R/RW, DVD-R/+R, DVD+RW/-RW, VCD, SVCD (not Blu-ray)
Display Size: Up to 200 inches
Included Accessories: Carry bag, tripod, multi cable
Warranty: 30 days refund/replacement, 3 years tech support
Unboxing Experience​
BIGASUO Mini Projector:​
Upon unboxing the projector, I was pleasantly surprised by its sturdy build and the inclusion of a quality carrying case. The projector itself is compact and lightweight, making it ideal for travel and outdoor use. The design is straightforward with buttons that are easy to access, though I found the button icons to be a bit difficult to read due to their color and size. Overall, the presentation of the product felt premium for the price, and I appreciated the thoughtful design that allows for easy packing and storage.
WiMiUS Mini Projector:​
The WiMiUS S27 Mini Projector has a compact and lightweight design, making it incredibly portable. At less than 2 lbs, it's easy to carry for travel or moving between rooms. The aesthetics are simple yet functional, with an adjustable built-in stand that allows for a 270° projection angle. This feature particularly impressed me as it opened up creative viewing possibilities, like projecting onto the ceiling for a cozy movie night in bed. The overall build feels sturdy, and the projector is well-protected in its packaging, which is a plus for transport.
BIGASUO Projector:​
Upon unboxing the projector, my first impression was quite positive. It arrives in a sturdy carrying case that securely holds the projector and its accessories, ensuring everything is organized and protected for use. The projector itself has a simple plastic build that feels robust, and the buttons, while functional, could benefit from clearer labeling, as they blend into the casing. Overall, the presentation is neat and functional, making it a great companion for outdoor movie nights.
BIGASUO Projector​
35 Inches - 300 Inches​
40 Inches - 200 Inches​
2.5E+2 Inches - 322 Inches​
3 Feet - 17 Feet​
3.6 - 17.7 Feet​
1 Meters - 4 Meters​
10000:1​
15000:1​
8000:1​
1920*1080 Pixels​
1920 x 1080 Pixels​
1080P Supported​
1280 x 720​
9000 lumen​
71.1 lumen​
The viewing experience varied significantly depending on the light conditions. Indoors or at night, the picture quality was quite impressive, with bright and clear visuals. However, during the day or in well-lit rooms, I noticed some washout, making it difficult to see less contrasted images. The internal speaker produced decent sound for indoor use, but it fell flat in outdoor settings, prompting the need for external speakers to enhance the audio experience. I found that connecting via Bluetooth to an external speaker improved the sound significantly, although I encountered issues with the Bluetooth connection being too quiet at times.
The viewing experience was exceptional, especially for a projector in this price range. It supports 1080P resolution, and the colors are vibrant with sharp details, making movie nights feel like a mini cinema experience. I was pleasantly surprised by the brightness, even in slightly lit conditions. The projector works beautifully for both indoor and outdoor settings, and the auto keystone correction further enhances the viewing experience by ensuring a properly aligned image, although I did notice some minor brightness inconsistencies in areas of the projection. The built-in speaker is decent for smaller spaces, but I found connecting to an external Bluetooth speaker provided a more immersive experience.
BIGASUO Projector:​
The picture quality is impressive in dark environments, showcasing vibrant colors and sharp clarity. However, I found that during daylight or in well-lit rooms, the image tends to wash out, which is common for projectors at this price range. The sound quality was decent for indoor use, but outside, I recommend connecting an external Bluetooth speaker to enhance the audio experience. The internal speaker struggles to compete with background noise, making external options necessary for outdoor settings.
BIGASUO Projector​
Built-In Speaker​
Portable, Lightweight, ①After-sales: [email protected], Built-In Wi-Fi, Built-In Handle​
Built-In DVD Player, Bluetooth, Speaker​
AVC​
H.265​
AVC​
48 Watts​
50000 Hours​
50000 Hours​
65000 Hours​
Bluetooth, USB, HDMI, AV, Micro SD, 3.5mm Audio​
Wired/Wireless/Bluetooth/WiFi/HDMI/USB/3.5Audio​
DVD Projector HDMI USB VGA AV Bluetooth MicroSD​
Laptop, Television, Smartphone​
Television, Gaming Console, Speaker, Laptop, Smartphone​
24 watts​
200 watts​
48 watts​
Mount Type​
Floor Mount, Ceiling, Table Mount with Tripod​
Table Mount/Wall Mount/Ceiling Mount​
BIGASUO Projector for Ceiling Table Tripod Mount​
4.8"L x 2.4"W x 5.7"H​
4.6"L x 3.9"W x 7.9"H​
7.99"L x 3.86"W x 6.57"H​
Setting up the projector was a breeze. I had everything up and running within minutes, thanks to the clear instructions and the included cables. The projector connects easily to various devices, including laptops and streaming sticks, and I was particularly impressed with the availability of multiple input options. The presence of a remote control and a small tripod made adjusting the projector's angle straightforward, although I did experience some challenges with the button responsiveness and the need for a few moments of waiting for the menu to appear.
Setting up the projector was a breeze. I appreciated the clear instructions that guided me through the initial setup process. It was straightforward to plug it in and connect my devices, whether through HDMI or wirelessly via Wi-Fi and Bluetooth. However, while Bluetooth connection worked at first, it did face some hiccups when trying to connect my phone or external speakers, suggesting that while the feature is there, it may not be the most reliable. The adjustable stand and keystone correction feature significantly reduced the setup time, allowing me to focus on enjoying the content rather than fussing with adjustments.
BIGASUO Projector:​
Setting up the projector was a breeze, especially since I have experience with similar devices. Within minutes, I had it operational in my basement. The inclusion of a remote, HDMI cable, and a stable tripod enhances the overall ease of setup. One minor confusion arose regarding the "charging cord" mentioned in the description; it is actually an AC adapter, not a battery. This projector seems adaptable for both home use and outdoor adventures, provided you have the right power source.
• Easy setup and operation
• Compact and portable design with a carrying case
• Multiple input options including HDMI and USB
• Good picture quality in low light conditions
• Excellent customer service experience
• Internal speaker lacks sufficient volume for outdoor use
• Bluetooth audio connection can be quiet and problematic
• Icon readability on buttons is poor
• Requires complete darkness for the best picture quality
Overall, I am quite satisfied with the projector, especially given its price point. It functions as a reliable entertainment system for family movie nights, both indoors and outdoors, though it does have limitations in bright environments and sound quality. While I faced some initial setup challenges, these were outweighed by the projector's convenience and performance. With a few adjustments—such as investing in a good external speaker—this projector can provide a great viewing experience for various occasions. I would recommend it to those looking for an affordable option for casual use, particularly for outdoor movie nights.
• Easy setup and multiple connection options
• Excellent picture quality with vibrant colors
• Adjustable stand for versatile projection angles
• Good value for the price
• Bluetooth connectivity can be unreliable
• Built-in speaker quality is average
• Some limitations with direct app streaming from mobile devices
Overall, I am thoroughly impressed with the WiMiUS S27 Mini Projector. It strikes a remarkable balance between affordability and quality, making it an excellent choice for anyone looking for a reliable and versatile projector. Whether for family movie nights, outdoor events, or personal use, this projector has exceeded my expectations. Despite a few minor issues, such as Bluetooth connectivity and sound quality, the positives far outweigh the negatives. I would highly recommend this projector to anyone in the market for a portable and user-friendly option that delivers great performance for the price.
BIGASUO Projector:​
• Great picture quality in dark environments
• Easy setup process with included accessories
• Portable design with a sturdy carrying case
• Limited brightness in well-lit conditions
• Internal speaker volume is low, requiring external speakers for better sound
• Confusing product description regarding power options
• Adjustment settings can be cumbersome at times
Overall, I am quite satisfied with this projector, particularly given its price point. It serves well for family movie nights, both indoors and outdoors, although some adjustments are necessary for optimal sound and image quality. The ease of use, portability, and multiple input options make it a practical choice for various settings. While it may not outperform higher-end models, it stands out for its value and functionality, thus earning my recommendation for casual use.
Roy_Knable
The BIGASUO Mini Projector is awesome! Great picture quality and it works like a charm. Just a heads up, grab a wired or wireless speaker too for better sound outside. Super happy with my buy—came nicely packaged and even has a soft storage case!
Happy7User
I had the WiMiUS Mini Projector for two months, but then it quit on me. I left a review, and Leyna.Lee from customer service reached out. They were awesome! Got my full refund, no hassle. I really liked the projector while it lasted!
69Shelby1969
The BIGASUO Projector is awesome! The picture quality is great, but definitely grab some extra speakers for the best sound outside. Super happy with my buy! It came nicely packaged and even has a soft case for storage.
