Best Mini Projectors for iPhone: Pocket-Sized Cinema for 2024
The mini projector market is booming, especially for iPhone users who demand portability, simplicity, and stellar image quality. In 2024, these pocket-sized marvels have become more than just gadgets—they're your personal cinema, wherever you go. But here’s the twist: with so many options, from 1080p resolution to wireless connectivity, are mini projectors really as convenient as they claim? Or do their limitations cast a shadow on their promise of on-the-go entertainment? Let’s break it down.
Best Budget Mini Projector for iPhone​
Maypug Mini Projector with WIFI 6 Auto Keystone Compatible​
Specs & Configurations​
ParameterValue
Item Weight0.46 Kilograms
Item Dimensions L x W x H3.94"L x 3.94"W x 7.48"H
Contrast Ratio1500:1
Maximum Throw Distance13.12 Feet
Light Source Operating Life50000 Hours
Maximum Image Size130 Inches
Lamp Wattage60 Watts
Minimum Image Size40 Inches
Video EncodingH.264, H.265
Hardware ConnectivityUSB, HDMI, 3.5mm Audio
Control MethodRemote
Minimum Throw Distance3.94 Feet
Mounting TypeTabletop Mount
Brightness120 Lumen
ColorWhite
Wattage60 watts
Controller TypeRemote Control
Compatible DevicesLaptop, Television, Tablet, Smartphone, Speaker
Additional FeaturesBuilt-In Speaker, Portable, Built-In Cooling System, Built-In Wi-Fi
Connectivity TechnologyBluetooth, Wi-Fi
Native Resolution1280 x 720
Display Resolution Maximum1280 x 720 Pixels
Display TypeLCD
Form FactorPortable
Price$119.99
Why Picked It:​
Compact yet powerful, this projector redefines home entertainment. Wi-Fi 6 ensures seamless connectivity with smartphones and laptops, while Bluetooth 5.0 compatibility elevates audio by pairing easily with external speakers.
The 180° rotatable stand is more than a convenience—it's a design triumph, enabling effortless projection onto walls or ceilings. At its optimal 5.5 ft distance, the 4K-supported picture stuns with razor-sharp clarity and vibrant colors. Auto keystone correction eliminates setup guesswork, delivering a flawless 130" screen ideal for movie nights.
Compatible with a range of devices—laptops, PCs, and smartphones—it combines portability with performance, proving that small can be mighty.
Best Cheap Mini Projector for iPhone​
NICPOW Mini Projector 1080P and 240" Movie Projector​
ParameterValue
Contrast Ratio6000: 1
Maximum Throw Distance22.9 Feet
Maximum Image Size1E+2 Inches
Minimum Image Size32 Inches
Video EncodingAVC
Minimum Throw Distance3.3 Feet
Mounting TypeWall, ceiling, vertical, desktop mount
Brightness7500 lumen
Colorwhite
Compatible DevicesTelevision, Gaming Console, Speaker, Laptop, Smartphone, Tablet
Connectivity TechnologyMHL, USB, HDMI, VGA
Display Resolution Maximum1920 x 1080 pixels
Display TypeLCD
Item Dimensions L x W x H8.66"L x 7.09"W x 3.94"H
Price$49.99
Why Picked It:​
This projector exceeds expectations for its price. While it won’t rival premium models, its performance in the right settings—dark rooms and proper screens—makes it a budget-friendly choice for home viewing. A good pick if you’re willing to improvise and prioritize affordability over perfection.
Surprisingly sharp for the price. While the projector displays at 720p with support for 1080p 60fps, the clarity holds up even at a 100-inch diagonal. Expecting 4K at $70 would be unrealistic, but for its resolution, it delivers beyond expectations.
Decent, but not built for bright environments. Natural light dims the picture noticeably, making it unsuitable for outdoor use before sunset. Indoors, in a darkened room, it performs well and provides a vibrant viewing experience for the price.
The weak link in the package. The mesh-like material does little to optimize projection, especially with any backlighting. A simple white bed sheet worked far better, proving you don’t need a pricey screen to get solid results.
Best Mid-Range Mini Projector for iPhone​
KODAK Luma 150 Ultra Mini Pocket Pico Projector LED DLP Projector​
ParameterValue
Item Weight16 ounces
Item Dimensions L x W x H3.9"L x 3.9"W x 0.89"H
Contrast Ratio3500:1
Maximum Throw Distance8.5 Feet
Light Source Operating Life3000 Hours
Maximum Image Size150 Inches
Lamp Wattage1 Watts
Voltage15 Volts (AC)
Minimum Image Size80 Inches
Hardware ConnectivityBluetooth, USB, HDMI
Control MethodApp
Minimum Throw Distance6 Feet
Mounting TypeWall Mount
Brightness60 Ansi lumen
ColorSilver
Wattage5 watts
Controller Typeandroid, vera, ios
Compatible DevicesiPhone, PC, Smartphone, MAC, Android
Additional FeaturesPortable
Connectivity TechnologyUSB
Native Resolution1920 x 1080
Display TypeRGB
Form FactorPocket
Price$219.99
Why Picked It:​
Lightweight and tripod-ready, this projector is built for convenience. The sound is decent with room for improvement, but the aux input allows for easy pairing with external speakers. Battery life holds up, and USB charging means no proprietary chargers—just a standard micro USB cable, though USB-C would have been a welcome upgrade.
Connectivity options include WiFi mirroring and HDMI, but there's no internal OS for streaming apps like Netflix or Hulu—perfect for those who prefer external devices. Paired with an HDMI-to-Lightning adapter, it integrates smoothly with an iPhone.
Specs deserve scrutiny: while marketed as 60 ANSI lumens, it's actually 50, and yes, it supports 4K rather than just 1080p. Amazon listings may mislead, so check Kodak's site for the real details. After weeks of research, it’s clear: for the price, this mini projector delivers solid value, even with minor spec discrepancies.
VOPLLS 1080P Full HD Supported Video Projector Mini Projector​
ParameterValue
Item Weight1.4 Pounds
Item Dimensions L x W x H6.69"L x 4.9"W x 2.64"H
Contrast Ratio10000:1 Pixels
Maximum Throw Distance23.6
Light Source Operating Life55000 Hours
Maximum Image Size210 Inches
Lamp Wattage50 Watts
Voltage100 Volts (AC)
Minimum Image Size35 Inches
Picture Quality Enhancement TechnologyAdvanced LED and uniform illumination technology
Minimum Throw Distance3.6 Feet
Mounting TypeTripod Mount
Brightness9500 Lumen
Colorwhite
Wattage50 watts
Controller TypeRemote Control, Button Control
Compatible DevicesLaptop, USB Drive, Tablet, X-Box, Smartphone
Additional FeaturesMini and Portable, Supports Table, Tripod, Ceiling Installation, Compatible with TV Stick, Phone, PS4/5, Laptop, PC, Hi-Fi Stereo Speakers,Zoom 100%-50%, Equipped with Cooling system, Low Noise
Display Resolution Maximum1920x1080 Pixels
Display TypeLCD
Form Factoradapter
Price$69.99
Why Picked It:​
This mini projector checks all the boxes for portability, quick setup, and versatility. Whether for home streaming or workplace meetings, its user-friendly menu makes adjustments straightforward. Paired with a $7 screen, it rivals pricier models in picture quality and offers a compact, space-saving alternative to traditional TVs.
The sound quality outperforms expectations, and the well-sized, responsive remote adds convenience. For presentations or event slides, the large, clear image ensures visibility from various vantage points.
A design flaw, however, is the placement of all connections on one side, causing weight imbalance on a tripod. Wrapping the cord around the tripod reduces the tilt, but this workaround highlights a missed opportunity for better design. Despite this, the projector remains a practical, budget-friendly option for diverse needs.
Best lightweight Mini Projector for iPhone​
Kodak Ultra Mini Projector 1080p LED DLP Rechargeable Pico Projector​
ParameterValue
Item Weight150 Grams
Item Dimensions L x W x H3"L x 3"W x 0.8"H
Contrast Ratio1000:1
Maximum Throw Distance5 Feet
Light Source Operating Life30000 Hours
Maximum Image Size80 Inches
Lamp Wattage5 Watts
Voltage5 Volts
Vertical Keystone Correction45 Millimeters
Video EncodingAVC
Picture Quality Enhancement TechnologyDLP
Hardware ConnectivityHDMI, USB 2.0
Control MethodApp
Minimum Throw Distance5 Meters
Brightness35 Lumen
ColorSilver
Wattage9.25 watts
Controller Typeandroid, ios
Compatible DevicesLaptop, Computer, Tablet
Additional FeaturesBuilt-In Speaker, Portable, Pocket, Built-In Battery, Built-In Media Player
Connectivity TechnologyMicroSD, USB, HDMI, 3.5mm Jack
Native Resolution640 x 360
Display Resolution Maximum640 x 360 Pixels
Display TypeLED
Form FactorPocket
Price$179.99
Why Picked It:​
Pocket-sized and ultra-portable, this tiny projector is easy to carry and simple to set up. The picture quality impresses for its size, and a dedicated carrying case neatly stores the projector alongside all cables. Perfect for travel or quick presentations.
However, battery life falls short of the advertised 2 hours—real-world use delivered just 20 minutes before requiring a recharge. While inconvenient, this isn’t a deal-breaker if you plan to stay plugged into a power outlet or battery pack.
The built-in speaker adds convenience, and the device pairs seamlessly with an iPhone 15 and MacBook Pro. While the resolution maxes out at 1080p—resulting in a lower-quality image from a MacBook—the iPhone display looks crisp. Brightness remains a limitation, performing best in dim or dark environments. Bonus points for versatile connectors and a micro SD card slot, making this an affordable, functional choice for lightweight projection needs.
Best Auto Focus Mini Projector for iPhone​
Dangbei Neo Mini Projector 1080P 540 ISO Lumens Portable Projector​
ParameterValue
Item Dimensions L x W x H7.87"L x 6.18"W x 3.94"H
Maximum Throw Distance5 Meters
Lamp Wattage6 Watts
Video EncodingH.264 or H.265
Picture Quality Enhancement TechnologyHDR10
Hardware ConnectivityHDMI, USB 2.0, Bluetooth 5
Minimum Throw Distance0.5 Meters
Mounting TypeCeiling Mount/ Tripod Mount/ Table Mount
Brightness540 lumen
ColorWhite
Wattage6 watts
Compatible DevicesTelevision, Tablet, Smartphone, Speaker
Additional FeaturesNetflix Officially-Licensed, Auto Obstacle Avoidance, Auto Focus, Bulit-In Dolby Audio Speakers, Short Throw
Connectivity TechnologyBluetooth, Wi-Fi, USB, HDMI
Display Resolution Maximum1920 x 1080 Pixels
Display TypeDLP
Form FactorPortable
Price$339
Why Picked It:​
Stylish and feature-packed, this compact projector delivers convenience with pre-installed streaming apps like Netflix and Amazon Prime, plus access to a Roku-like app store—even hosting niche channels like OAN.
Technically impressive, it offers auto-focus and keystone correction, both working effectively. That said, manual adjustments might yield better results for keystone perfectionists. A minor annoyance? Auto-focus kicks in whenever the image is obstructed (think kids running around), and there’s no “lock focus” option. Startup also triggers auto corrections, requiring extra patience and manual resets if you prefer fine-tuning.
Image quality punches above its weight, rivaling higher-end models like the Mars Pro 4K. Though rated at 540 ISO, it performs closer to a 1500 ISO projector in certain settings, handling daytime use decently with closed curtains.
Two 6W speakers round out the package, offering solid audio for most uses. While not perfect, the Neo combines style, functionality, and adaptability, making it a compelling choice for casual movie nights or everyday streaming.
From movie nights to business pitches, the best mini projector for iPhone makes sharing your screen effortless. But remember, portability often comes with trade-offs: are you ready to sacrifice a little brightness for convenience? Or is there a perfect balance waiting to be found? Let’s hear your take—what features would make a mini projector irresistible to you?
