Dangbei Projector
Best 8K Projector for High-end Audio-Visual Room in 2021
Q:is there an 8k uhd projector?
A:yes
Q:do theaters use 8k projectors
A:High-end cinema will use
8k uhd projector Unlike 8K flat-panel TVs, which are relatively mature in technology at this stage, home theater projectors are obviously only in the early stages of development. For the time being, the only model with 8K display capabilities is JVC DLA-N11, but due to the transmission interface HDMI 2.1 has not been adopted, and in fact it cannot receive high-standard 8K HDR video signals, but the original 4K movie screen can be upgraded to 8K precision output through the 8K image optimization technology in the body. This is a very useful picture enhancement function for players who are holding a lot of 4K UHD Blu-ray discs.
In addition to DLA-N11, do we have any other 8K projector options? It is not available in the household field, but we can still find it in the professional field. Not long ago, Digital Projection brought an ultra-high-brightness laser projector Insight Laser 8K with a three-chip DLP display chip. If you don't mind the huge body over 130kg and the light output brightness of 37000 ISO lumens, of course, including the expensive price, this super bright projector is also an excellent choice for us to build an 8K independent audio-visual room.
Now that 8K projectors have appeared in the home and professional fields? So how long will it take for a full outbreak? We estimate that it may take a long time. After all, it took a lot of time for home projectors to move from 1080p Full HD to 4K UHD. It was not until TI Texas Instruments officially launched the 0.66 inch and 0.47 inch small-size 4K UHD DLP solutions that really allowed 4K projectors to move forward. Enter the mass market within 10,000 yuan. The development of 8K home projectors now obviously also faces the same problems as the development of 4K home projectors. On the one hand, it lacks a native 8K display chip, and on the other hand, the size of the native 8K display chip is large and it is difficult to quote the compactness. In the body of the home projector. In addition, there is also the difficulty of optical engine and lens development. To meet the 33 million pixel 8K projector, there are high requirements for the quality of the optical path and lens. In the future, we believe that 8K home projectors will continue to follow the development concept of 4K, which can increase the screen resolution to 8K through the 4K display chip plus special image or optical processing. At the same time, we will continue to work hard to compress the 8K native display chip. The area is controlled to a small size within 0.8 inches that is more suitable for home projection. Then we hope to see 8K models in the home projector market from entry to high-end.
Best 8K Projector:
JVC DLA-N11
As the first projector supporting 8K video output in the home theater field, JVC DLA-N11 has attracted great attention. The biggest feature of this projector is that the core display part uses three 0.69-inch 4K native D-ILA display chips from JVC, with a physical resolution of 4096×2160, which can be achieved through advanced 8K e-shift technology to achieve 8196×4320 The ultra-high picture resolution.
It is worth mentioning that this is a fairly mature 8K display technology. In 2008, the 8K large-screen display solution adopted by JVC to support the Super Hi-Vision TV broadcasting system of Japan's NHK TV station adopted this technology. DLA-N11 also has the industry-renowned THX 4K Display and ISFccc dual certification. For the projector, the resolution and color reproduction ability of the lens is very important, especially for a model that can have 8K display capability. DLA-N11 uses 8K precision 18 pieces of 16 groups all glass The optical lens composed of lenses has a diameter of astonishing 100mm, which is very rare in the field of home theater projectors. In addition, DLA-N11 also fully supports mainstream HDR high dynamic range technologies, including HDR10 and HLG. At the same time, with the unique automatic tone mapping function, users can easily obtain the ideal HDR movie picture performance and fully display the energy of highlights For a home theater projector that still uses an ordinary high-pressure mercury lamp as the light source, it is impressive.
Insight Laser 8K
When you need to build an 8K home theater system with a 300-inch giant screen, a powerful 8K projector is essential. Generally speaking, home theater projectors seldom can exceed 5000 lumens, but to cast 300 inches, it may need more than 10,000 lumens of light output brightness. The InsightLaser 8K brought by Digital Projection is a powerful projector with a laser light source and 37000 ISO lumens output. This projector uses a three-chip 1.38-inch DarkChip 3 DMD chip in the core display part. It should be noted that although the native resolution of the display chip is still the same as the JVC DLA-N11 DCI-4K level, it can achieve the highest output. With the screen resolution of 8K UHD7680×4320, the refresh rate can be up to 120Hz.
If it is displayed in 4K resolution, the refresh rate can reach 240Hz. Coupled with the ultra-low latency processing technology equipped in the body, it is very suitable for us. Play 8K Ultra HD dynamic shooting game. However, one thing to note is that to achieve 7680×4320/120Hz, it can only be achieved through the 12G-SDI adapter interface, and the HDMI and DisplayPort in the fuselage only support up to 7680×4320/60Hz input, but for a look 8K movies or sports events are more than enough. As a professional projector, Insight Laser 8K has multiple optical lenses with different focal lengths for users to choose to meet the installation and use of various sizes of audio-visual spaces. The closest focusing distance can be up to 2.5m, which is sufficient for the use of home audio-visual rooms.
8K Projector news
Hisense will mass-produce curling-screen laser TVs in 2021, launch 8K laser TVs and commercial laser TVs with 10,000 lumens or more, and start the expansion plan of laser TV production lines in Qingdao, and start production of laser TVs overseas, which will further establish a leader in the laser display industry The status of the person.
