BenQ X3100i Review: Is This LED Projector the Perfect Fit for Gaming?
KeyGood5298
First Impressions​
The BenQ X3100i is a mid-size projector without an integrated battery, so you must plug it in. The projector has auto keystone correction, but only on the vertical axis, so you must center it horizontally. It also doesn't have autofocus, so you must manually adjust that to get the clearest image possible. Its feet are slightly adjustable, and it comes with a set of extra extender feet to increase the vertical angle of the projector. Finally, the projector has two 5W integrated speakers.
The BenQ X3100i uses an LED bulb as its light source, so you likely wont ever have to worry about replacing it; the manufacturer claims the bulb lasts anywhere from 20,000 to 30,000 hours, depending on the selected eco mode. Its not a true 4k projector, as it uses pixel shifting to create a higher-resolution image. This offers better quality than a pure 1080p projector but isn't as good as a native 4k projector. It has a 1.3x optical zoom, allowing you to adjust the projection distance without moving the projector.
BenQ X3100i​
$2199​
Education, Home Cinema, Gaming​
Highlight
Resolution: 4K
HDR Technology: HDR-PRO
Response Time: 4ms (1080p@240Hz)
Vertical Lens Shift: 40%-60%
Zoom: 1.3x
Entertainment Platform: Google-Certified Android TV
Casting Support: AirPlay & Chromecast
Audio Channels: 7.1-channel
Audio Technology: Dolby Atmos
Connectivity: eARC and S/PDF
BenQ X3100i​
N/A - 200 Inches​
8.2 Feet - 12 Feet​
3840 x 2160 Pixels​
3840 x 2160​
3300 Lumen​
LED​
Viewing Experience
The BenQ X3100i projector delivers impressive peak brightness, slightly surpassing its predecessor, the X3000i, making it suitable for moderately-lit environments while maintaining excellent brightness uniformity. It showcases good native contrast, especially in darker settings, with deep blacks enhancing the viewing experience. The projector's color performance shines in the FPS picture mode, where it approaches a wide color gamut, effectively covering most of the Rec. 709 space for SDR content and performing reasonably well with the broader Rec. 2020 color space. Overall, the X3100i offers a vibrant and engaging presentation for both SDR and HDR content, making it a strong choice for immersive viewing.
BenQ X3100i​
HEVC (H.265)​
20000 Hours​
10 Watts​
10 watts​
HDMI​
Hardware Connectivity​
USB, HDMI​
Gaming Consoles​
Built-In Speaker​
This projector offers a robust and user-friendly experience with its integrated Android TV 11 interface via the QS02 dongle, providing seamless access to popular streaming services, including native support for Netflix. The inclusion of Google Chromecast and Apple AirPlay enhances its connectivity options, making it versatile for various streaming needs. The projector features two built-in 5W speakers, delivering decent audio quality for a more immersive viewing experience. Additionally, the 12v trigger out port for screen control adds convenience for users with motorized screens. The extra HDMI port and USB capabilities through the dongle further enhance its flexibility, allowing for easy connection of additional devices. With support for HDR10+ and advanced Wi-Fi 6, this projector is well-equipped to deliver high-quality visuals and a smooth streaming experience. Overall, it combines smart functionality with practical features, making it a compelling choice for home entertainment.
User Feedback​
• Beautiful picture quality, even in well-lit rooms
• Quiet operation
• Excellent for gaming and movies with vibrant colors
• Easy to set up with Android TV dongle
• Easy lens adjustment
• Clear and loud built-in speaker
• Great dark detail visibility for immersive gaming
• Positive feedback from users for gaming performance
• Stroboscopic rainbow effect may be noticeable for some users
• Reports of product failing after a year
• Persistent message regarding keystone and digital zoom can be annoying
• Issues with projector failing to turn on after a few days of use
• Random audio mode switching between ARC and built-in speakers
The BenQ projector presents a compelling option for gamers and movie enthusiasts with its impressive picture quality and ease of use. While it has notable strengths, including vibrant colors and quiet operation, potential issues like the stroboscopic effect and reliability concerns should be considered. Overall, it may offer a satisfying experience for many, but with caution advised for those concerned about long-term durability.
