- 1 Introduce
2
Side-by-Side Comparison
- 2.1 Display
- 2.2 Features
- 2.3 Connectivity
- 2.4 Measurements
- 3 Conclusion
Parameter | BenQ TH685P | BenQ TH575 | BenQ TK700STi |
Picture | |||
Price | $799 | - | - |
Recommended Uses | Gaming | Education, Home Cinema, Gaming, Business | Home Cinema, Gaming |
Highlight | Model: TH685P (lacks VGA-in/Monitor-Out compared to TH685) Audio: Integrated 5W speaker by treVolo with equalizer Resolution: 1080P, 4K supported, HDR ready Brightness: 3500 ANSI lumens Image Size: 100 inches from 8.2 feet (2.5m) Color Accuracy: 95% Rec. 709 HDR Technology: HDR10 with enhanced whites and blacks Gaming Features: Low latency 8.3ms at 1080p/120Hz, Game Mode/Game Sound Mode, LumiExpert for eye strain reduction | Model: New 2023 Brightness: 3800 ANSI Lumens Contrast Ratio: 15,000:1 Resolution: 1080p Full HD Low Latency: 16ms (1080p@60Hz) Projection Distance: 10.8ft for 100" image Features: Improved gaming performance, high contrast ratio for dark scenes | Models: TK700, TK700STi Throw Capabilities: TK700STi - short throw (100" at 6.5ft), TK700 - standard throw (100" at 8.2ft) Resolution & Latency: 4K, 16ms low latency at 4K/60Hz Gaming Features: Game Mode, Game Sound Mode Console Compatibility: PS4, PS5, Nintendo Switch, Xbox Series X, Google Stadia Image Quality: Bright, sharp images, equalized audio Setup Features: 1.2x zoom, 2D Auto Vertical Keystone, Picture Rotation Adjustment Entertainment Platform: Google-certified Android TV, Google Play Store, 5,000+ apps |
Screen Size | 30 Inches - 300 Inches | 30 Inches - 300 Inches | 30 Inches - 300 Inches |
Throw Distance | 1.8 Feet - 1.5 Feet | 8 Feet - 5 Feet | 2.2 Feet - 21.5 Feet |
Contrast Ratio | 10000:1 | 15000:1 | 10000:1 |
Display Resolution | 1920 x 1200 Pixels | 1920 x 1080 Pixels | 3840 x 2160 Pixels |
Native Resolution | 1920 x 1080 | 1920 x 1080 | 3840 x 2160 |
Brightness | 3500 lumen | 3800 Lumen | 3000 Lumen |
Display Type | DLP | DLP | DLP |
Picture Quality Enhancement | - | LED | - |
Video Encoding | - | - | H.264 or H.265 (HEVC) |
Lamp Wattage | 5 Watts | 210 Watts | 5 Watts |
Light Source Life | - | 15000 Hours | 20000 Hours |
Controller Type | Button Control | Remote Control, Button Control | Remote Control, Button Control |
Control Method | Voice | Remote | Remote |
Mount Type | Tabletop Mount | Tabletop Mount | Floor Mount, Tabletop Mount, Ceiling Mount |
Noteworthy Features | Speakers, Internet Ready, 3d-Ready | Digital Keystone Correction, Speakers, 3d-Ready | Digital Keystone Correction, Short Throw |
Connectivity
Connectivity Technology | HDMI | HDMI | USB, HDMI, 3.5mm Jack |
Hardware Connectivity | VGA, HDMI | HDMI | HDMI |
Compatible Devices | Smartphone | Laptop, Gaming Console, Speaker | Laptop, Gaming Console, Speaker |
Measurements
Dimensions L x W x H | 12.28"L x 8.56"W x 4.33"H | 11.65"L x 8.7"W x 4.72"H | 18"L x 13"W x 7"H |
Item Weight | 6.2 Pounds | 7.65 Pounds | 6.83 Pounds |
Product | PROS AND CONS |
BenQ TH685P | Pros • Substantially brighter picture compared to the W1070 • Excellent performance in well-lit rooms • Improved picture quality with vibrant colors • Low input lag, making it suitable for gaming • Significant upgrade from older budget projectors Cons • Lack of horizontal keystone shift • Requires careful positioning, especially if not ceiling mounted • Can produce a lot of heat, potentially warming a small room |
BenQ TH575 | Pros • Excellent picture quality with bright colors and vivid HD display • No lag in game mode, making it great for gaming • Versatile for multiple uses, including movies and golf simulators • Easy to use and set up • Affordable price point with better specs than competitors • Replaceable bulb, adding to long-term value • Manual focus and zoom capabilities Cons • Sound quality is subpar; external speakers recommended • Limited zoom capabilities and no horizontal keystone adjustment • Finding the optimal distance for different devices can be challenging |
BenQ TK700STi | Pros of BenQ TH690ST: • Stays cool during operation, reducing heat in the room • Almost silent operation on eco mode • Long lamp life, rarely needing replacement • Shorter throw distance, ideal for smaller spaces • Better color accuracy compared to bulb projectors • Reduced eye strain due to healthier light emission Cons of BenQ TK700STi: • Generates significant heat, increasing room temperature • Noisy fan operation, especially during gaming • Requires more frequent lamp replacements (every year or two) • Slightly inferior color quality, appearing washed out • Notable rainbow effects while viewing • Higher upfront cost due to 4K capability, which may not be necessary for all users • Better latency and framerate, but not significantly perceived by all users |
