BenQ MW560 vs ViewSonic PA700W vs ViewSonic 4000: Which WXGA Projector is Right for Your Business Needs?
WWGHIAFTC
BenQ MW560​
ViewSonic PA700W​
ViewSonic 4000​
Price​
$499
$429.99
$399.99
Business​
Education, Business​
Business​
Image Quality: 4000 ANSI Lumens brightness, 20000:1 contrast
Connectivity: Dual HDMI, fast data transmission
Text Clarity: Exclusive Data Review Mode
Setup: Ergonomic retractable foot, auto vertical keystone
Eco-Friendly: SmartEco Mode, 70% lamp power savings​
Brightness: 4500 Lumens
Resolution: WXGA (1280x800p)
Zoom: 1.1x optical zoom
Keystone Correction: 40-degree vertical
Lamp Life: Up to 12,000 hours (SuperEco Mode)
Connectivity: Dual HDMI, VGA, USB; supports media players, PCs, Macs, mobile devices​
Projector Type: WXGA
Brightness: 4000 Lumens
Optical Zoom: 1.1x
Vertical Keystone Adjustment: 40 degrees
Input Latency: 16ms
Lamp Life: Up to 15,000 hours (SuperEco Mode)
Connectivity Options: HDMI, VGA, mini USB, supports media players, PCs, Macs, mobile devices​
Side-by-Side Comparison​
BenQ MW560​
ViewSonic PA700W​
ViewSonic 4000​
N/A - 300 Inches​
30 Inches - 300 Inches​
1 Feet - 1 Feet​
1.18 Meters - 13.17 Meters​
3.28 Feet - 38.02 Feet​
22000:1​
22000:1​
Display Resolution​
1920 x 1080 Pixels​
1280 x 800 Pixels​
800 Pixels​
1280 x 800​
1280 x 800​
1280 x 800​
4000 Lumen​
4500 Lumen​
4000 Lumen​
DLP​
DLP​
DLP​
Picture Quality Enhancement​
[Inferred] DLP, high resolution, and high contrast ratio​
SuperColor​
BenQ MW560​
ViewSonic PA700W​
ViewSonic 4000​
DLP-compatible​
AVC​
203 Watts​
300 Watts​
200 Watts​
Light Source Life​
1.5E+4 Hours​
4000 Hours​
5000 Hours​
Button Control​
Mount Type​
(Optional),Yes, CMG3​
Tabletop Mount​
Ceiling Mount​
Noteworthy Features​
Digital Keystone Correction​
UHP​
Lightweight​
Connectivity​
BenQ MW560​
ViewSonic PA700W​
ViewSonic 4000​
VGA, HDMI​
USB, Ethernet, HDMI, 3.5mm Jack​
VGA, USB, HDMI​
Hardware Connectivity​
VGA​
VGA, Ethernet, HDMI, USB 2.0 Type A, 3.5mm Audio​
USB​
Laptop​
Laptop, Tablet, Smartphone​
Personal Computer​
Measurements​
BenQ MW560​
ViewSonic PA700W​
ViewSonic 4000​
Dimensions L x W x H​
11.65"L x 8.7"W x 4.72"H​
9.2"L x 12.2"W x 4.5"H​
11.6"L x 8.6"W x 4.3"H​
Item Weight​
2.3 Kilograms​
6 Pounds​
2.2 Kilograms​
Product
PROS AND CONS​
BenQ MW560​
Pros
• Reliable and efficient performance
• Easy to use, suitable for everyday use
• Produces clear and bright images, even in bright rooms
• Durable construction, holds up well under long run times
• Excellent color accuracy and image focus across the screen
• Cost-effective alternative to renting audiovisual equipment
Cons
• Bulky and large design
• Emits significant heat during operation
• Initial plastic smell that dissipates quickly
Overall Impression
This projector is a robust and reliable choice for professional and personal use, particularly in environments with challenging lighting conditions. Its durability and performance make it suitable for frequent use, although its size and heat output may be considerations for some users. Overall, it delivers excellent value and functionality, making it a recommended option for those in need of a dependable projection solution.
ViewSonic PA700W​
Pros
• Affordable price for a bright projector
• Sharp optics and good image quality
• Multiple mounting options (right side up or upside down)
• Keystone and white balance adjustments available
• Suitable for bright environments without needing to dim the room
• Lightweight and portable
Cons
• Does not reach the advertised 200" image size at the specified distance
• USB input limitations for video/photo display
• Reports of fan issues leading to automatic shutdown
• Feels somewhat cheap and lightweight compared to other units
Overall Impression
The Viewsonic PA700W projector offers great value with its affordability and bright, sharp image quality, making it suitable for various settings like conferences and presentations. However, potential buyers should be cautious about the advertised image size and consider the limitations regarding USB functionality and build quality.
ViewSonic 4000​
• Excellent image quality with bright and vivid colors
• High contrast ratio enhances movie viewing experiences
• Affordable price point for a home theater projector
• Feature to reduce lamp brightness, extending lamp life to approximately 15,000 hours
• Easy setup and compatibility with various devices (e.g., FireTV, game consoles)
• Allows for 3D movie viewing with compatible glasses
• Sturdy packaging ensures safe delivery
• Resolution falls short of true 1080p
• Built-in speaker lacks bass and distorts at higher volumes
• Menu navigation and remote control are poorly designed, causing issues with lamp mode settings
• Instructions are limited to pictures, making setup unclear for some users
• Screen door effect visible when viewed closely
This projector is a fantastic upgrade for anyone prioritizing image quality over portability, particularly for home theater setups. Its affordability, combined with bright and vivid visuals, makes it a strong contender in the market. However, potential buyers should be aware of its limitations in terms of resolution and sound quality, as well as some frustrating design aspects regarding the menu system. Overall, it's a great choice for movie enthusiasts seeking a cost-effective solution for a cinematic experience at home.
