- 1 Specs
- 2 Which to get
In the world of projectors, size and performance often seem to be at odds. On one side, we have the BENQ Lu950, a powerhouse that promises stunning visuals and a top-tier viewing experience for home theaters and professional settings alike. With its robust features, it aims to redefine what we expect from a projector.
On the other side, we have the APIO Mini Portable Projector, a more compact and travel-friendly option designed for those who prioritize portability without sacrificing the thrill of a big-screen experience. With its native resolution and built-in sound system, it invites users to enjoy cinema on the go, but can it really measure up in quality compared to the BENQ?
In this comparison, we'll delve into the strengths and weaknesses of both projectors to answer a critical question: is the convenience of a mini projector worth compromising on performance, or does the BENQ set a standard that the APIO simply can’t compete with? Let’s find out.
From what I've gathered, the BENQ Lu950 seems to focus on picture quality with its higher resolution and likely better brightness, making it suitable for a more immersive experience at home. But I’m curious about the sound quality—does it have built-in speakers or do I need to hook it up to an external system for decent audio?
On the flip side, the APIO is all about portability with its compact size and built-in battery, which is great for taking it to outdoor movie nights or presentations. However, I’m a bit skeptical about the picture quality at only 640*360 resolution and just 20 lumens—how does that hold up in less-than-dark environments? And while it has stereo sound, I wonder if it’s enough for a satisfying experience, or if it’ll just fall flat.
What do you think? Is the BENQ worth the investment for superior quality, or does the APIO's convenience make it a smart choice? Any downsides to either that I should be aware of? Would love to hear your thoughts!
Specs
Parameter | BENQ Lu950 Projector | APIO Mini Portable Projector |
Reference Price | - | $49.99 |
Recommended Uses | - | Home Cinema |
Built-In Media | - | Projector, HDMI Cable, Micro USB Charging Cable, Quick Start Guide |
Highlight | - | [Big Screen Experience] Pocket projector supports 640*360 native resolution, 1080P to have an amazing experience with home cinema, presentations or outdoor entertainment. The projector can delivers 20 lumens of brightness for vivid images in dark environment. [Stereo Sound] The pocket projector is the ideal choice by the projector’s two 1W speakers deliver fantastic sound on the go. Connect the projector to your surround sound system for a bigger sound. Built-in rechargeable Li-polymer battery for up to 2 hours of projecting time without an outlet. [Compact Design] Thanks to the small size (3.46 x 3.46 x 1.69 inches) & lightweight (13.4 ounces) design. The built-in 2600mAh rechargeable battery can work continuously for up to 2 hours. The small and built-in battery design makes sure you can carry the projector everywhere in your bag. |
Screen Size | N/A - 300 Inches | 30 Inches - 60 Inches |
Throw Distance | - | 2.62 Feet - 4.27 Feet |
Contrast Ratio | 3,000,000:1 | 350:1 |
Maximum Resolution | 1920 x 1200 | 640 x 360 Pixels |
Native Resolution | 1920 x 1200 | 640 x 360 |
Brightness | 5000 lumen | 20 lumen |
Display Type | DLP | DLP |
Picture Enhancement | - | Digital Light Processing (DLP) |
Other Features | Portable | Lightweight |
Video Encoding | H.264, H.265 | - |
Lamp Wattage | - | 1 Watts |
LightSource Life | 20000 Hours | 20000 Hours |
Controller Type | Button Control | Touchpad Control |
Control Method | App | Touch |
Connectivity Technology | HDMI | HDMI |
Compatible Devices | Laptop, Gaming Console | Windows lapton, Macbook, DVD player, Tablet, PS3/4 Console, Android Smartphones, iPhone, iPad, TV Box (Some Apple devices require an Apple Digital AV adapter) |
Wattage | 270 watts | 1 watts |
L x W x H | - | 3.46"L x 3.46"W x 1.69"H |
Which to get
Looking to level up my home entertainment setup and trying to decide between the BENQ Lu950 Projector and the APIO Mini Portable Projector.From what I've gathered, the BENQ Lu950 seems to focus on picture quality with its higher resolution and likely better brightness, making it suitable for a more immersive experience at home. But I’m curious about the sound quality—does it have built-in speakers or do I need to hook it up to an external system for decent audio?
