BenQ HT2060 vs TK700 vs Epson Home Cinema 1080: Which Popular Gaming Projector with Built-In Speaker is Right for You?
windstri85
BenQ HT2060​
BenQ TK700​
Epson Home Cinema 1080​
Price​
$699.99
Home Cinema, Gaming​
Lamp Life: Long
Color Coverage: DCI-P3, 98% Rec.709
HDR Support: HDR10, HLG
Contrast: Deep blacks for details in dark scenes
Use Cases: TV Projector, Gaming Projector
Connectivity: Dual HDMI 2.0, S/PDIF (5.1 channel audio out)
Latency: 16.7ms (1080p 60Hz), 33.4ms (4K 60Hz downscaled)
Audio: Built-in 5Wx2 speakers, projector-fit design​
Models: TK700, TK700STi
Throw Distance: TK700: 100"@8.2ft, TK700STi: 100"@6.5ft
Resolution & Latency: 4K HDR, 16ms@4K/60Hz, up to 4ms@1080p/240Hz
Audio Features: eARC for Dolby Atmos, 7.1-Channel Audio, Game Sound Mode
Color & Brightness: 96% Rec. 709, 3200 ANSI lumens, black detail enhancement
Compatibility: Sony PS5, PS4, Nintendo Switch, Xbox Series X/S, Google Stadia, external audio systems​
Dynamic Contrast Ratio: up to 16,000:1
Color Technology: 3LCD, 100% RGB color signal
Color Brightness: Best-in-Class, no rainbowing issues
Setup: Easy setup with built-in speaker
Brightness: 3,400 lumens (color and white)
Image Quality: 1080p, optimized for fast-action content​
Side-by-Side Comparison​
BenQ HT2060​
BenQ TK700​
3E+1 Inches - 300 Inches​
60 Inches - 3200 Inches​
33 P - 300 Inches​
8 Feet - 10 Feet​
2.5 Meters - 5 Meters​
2 Feet - 11.1 Feet​
500000:1​
16:9​
Display Resolution​
1920 x 1080 Pixels​
3840 x 2160 Pixels​
3840 x 2160​
2300 Lumen​
3200 Lumen​
3400 Lumen​
LED​
DLP​
Picture Quality Enhancement​
BenQ HT2060​
BenQ TK700​
MP4​
10 Watts​
5 Watts​
Light Source Life​
30000 Hours​
4000 Hours​
Button Control​
Remote, Touch​
Mount Type​
Ceiling Mount​
Tabletop Mount, Ceiling Mount​
Tripod Mount, Tabletop Mount​
Noteworthy Features​
Built-In Speaker, Digital Keystone Correction, Auto Focus, Built-In Wi-Fi, 3d-Ready​
Built-In Speaker, Digital Keystone Correction, Auto Focus, 4K support, 3d-Ready​
Built-In Speaker, Digital Keystone Correction​
Connectivity​
BenQ HT2060​
BenQ TK700​
HDMI​
HDMI​
USB, HDMI, 3.5mm Jack​
Hardware Connectivity​
HDMI​
USB 2.0 Type A, HDMI​
HDMI​
Laptop, Gaming Console, Television​
Laptop, Gaming Console, Speaker​
Measurements​
BenQ HT2060​
BenQ TK700​
Dimensions L x W x H​
14.4"L x 9.6"W x 5.2"H​
12.28"L x 9.69"W x 4.33"H​
11.9"L x 9.9"W x 3.6"H​
Item Weight​
7.9 Pounds​
6.8 Pounds​
8.2 Pounds​
Product
PROS AND CONS​
BenQ HT2060​
• Light-weight and quiet-running
• Crystal clear picture quality with vibrant colors
• Excellent sound quality, potentially eliminating the need for additional speakers
• Two HDMI inputs for versatile connectivity (cable TV and Apple TV)
• Smart eco-mode extends bulb life up to 6000 hours without noticeable picture quality loss
• Affordable price compared to large HDTVs
• Easy setup with no need for calibration out of the box
• Multiple picture modes available (vivid, normal, cinema, sports)
• Ceiling mount designed specifically for the unit enhances aesthetics
• Bulb replacement costs could be a consideration, though lower than previous models
• Requires a suitable projection surface (e.g., white wall) for optimal performance
• May not perform as well in bright daylight without proper setup
BenQ TK700​
• Incredible colors and crispness
• Easy setup and scaling to screen size
• Excellent performance for gaming with great response time
• Bright picture quality, especially in gaming mode
• Sufficiently dark blacks in HDR10 and HDR Game modes
• Vibrant colors without being washed out
• No noticeable blurriness or latency in games
• Great for social settings with ample screen space for group viewing
• Reliable performance over extended use (1400+ hours without issues)
• Compatible with high-quality HDMI cables without latency issues
• Requires specific throw distance; may not fit all room setups
• Quick adjust capstone limits placement options at an angle
• Not ideal for dedicated home cinema users seeking the best black levels
• Occasional issues with powering on after limited use
• Fast mode disables keystone correction, affecting setup flexibility
• Potential limitations based on the GPU used for connection
Pros
• Impressive picture quality at an affordable price
• Bright and crisp colors on the 16ft screen
• Good throw distance, effectively replaces older projectors
• Bright bulb suitable for the intended use
• Low latency for upscaled 4K content
• Works well with external audio devices like soundbars
Cons
• Not a smart projector; lacks native streaming capabilities
• Visible projection border areas; black areas appear grey
• Not designed for high light room environments
• Audio performance is subpar if used internally
• Design flaw related to heat sensor that can lead to malfunction
• Requires technical knowledge to repair if issues arise
