Shelby_Compare
- 1 Introduce
2
Side-by-Side Comparison
- 2.1 Display
- 2.2 Features
- 2.3 Connectivity
- 2.4 Measurements
- 3 Conclusion
Parameter | BenQ HT2060 | BenQ TK700 | BenQ TH575 |
Picture | |||
Price | $899 | $1099 | $599 |
Recommended Uses | Education, Home Cinema, Gaming, Business | Home Cinema, Gaming | Education, Home Cinema, Gaming, Business |
Highlight | LED Color Performance: DCI-P3 and 98% Rec.709 color coverage, compatible with HDR10 and HLG Usage: Suitable for TV, gaming, movies Connectivity: Dual HDMI 2.0, S/PDIF support for 5.1 channel audio Latency: 16.7ms (1080p 60Hz), 33.4ms (4K 60Hz downscaled to 1080p) Audio: Built-in 5Wx2 speakers, optimized design for sound output | Models: TK700, TK700STi Throw Distance: TK700: 100"@8.2ft; TK700STi: 100"@6.5ft Resolution: 4K HDR, 16ms input lag @4K/60Hz, 4ms @1080p/240Hz Audio: eARC for Dolby Atmos, 7.1-Channel audio, Game Sound Mode/Game Mode Color Performance: 96% Rec. 709, 3200 ANSI lumens, black detail enhancement Compatibility: Supports consoles (PS5, PS4, Nintendo Switch, Xbox Series X/S), Google Stadia, external audio systems | Model: New 2023 Brightness: 3800 ANSI Lumens Contrast Ratio: 15,000:1 Resolution: 1080p Full HD Low Latency: 16ms (1080p@60Hz) Response Time: Microsecond DMD fast response Contrast Performance: Deeper blacks and fine details Projection Distance: 100" images from 10.8ft Target Use: Gaming |
Screen Size | 3E+1 Inches - 300 Inches | 60 Inches - 3200 Inches | 30 Inches - 300 Inches |
Throw Distance | 8 Feet - 10 Feet | 2.5 Meters - 5 Meters | 8 Feet - 5 Feet |
Contrast Ratio | 500000:1 | 16:9 | 15000:1 |
Display Resolution | 1920 x 1080 Pixels | 3840 x 2160 Pixels | 1920 x 1080 Pixels |
Native Resolution | 1920 x 1080 | 3840 x 2160 | 1920 x 1080 |
Brightness | 2300 Lumen | 3200 Lumen | 3800 Lumen |
Display Type | LED | DLP | DLP |
Picture Quality Enhancement | - | - | LED |
Video Encoding | - | MP4 | - |
Lamp Wattage | 10 Watts | 5 Watts | 210 Watts |
Light Source Life | 30000 Hours | 4000 Hours | 15000 Hours |
Controller Type | Remote Control | Remote Control, Button Control | Remote Control, Button Control |
Mount Type | Ceiling Mount | Tabletop Mount, Ceiling Mount | Tabletop Mount |
Noteworthy Features | Built-In Speaker, Digital Keystone Correction, Auto Focus, Built-In Wi-Fi, 3d-Ready | Built-In Speaker, Digital Keystone Correction, Auto Focus, 4K support, 3d-Ready | Digital Keystone Correction, Speakers, 3d-Ready |
Connectivity
Connectivity Technology | HDMI | HDMI | HDMI |
Hardware Connectivity | HDMI | HDMI, USB 2.0 Type A | HDMI |
Compatible Devices | Laptop, Gaming Console, Television | Laptop, Gaming Console, Speaker | Laptop, Gaming Console, Speaker |
Measurements
Dimensions L x W x H | 14.4"L x 9.6"W x 5.2"H | 12.28"L x 9.69"W x 4.33"H | 11.65"L x 8.7"W x 4.72"H |
Item Weight | 7.9 Pounds | 6.8 Pounds | 7.65 Pounds |
Product | PROS AND CONS |
BenQ HT2060 | Pros • Excellent picture quality for the price, rivaling projectors costing four times as much • Bright image, capable of lighting up a 10-foot wide screen easily • Spectacular out-of-the-box color accuracy • Good performance for a projector under $1000, considered the best in its category • Large projection size enhances cinematic experience • Affordable option for those seeking a front projector without breaking the bank Cons • Lack of uniformity in image quality, especially with white fields • Shadows and contrast could be improved; detail in dark scenes is lacking • Requires a dark room for optimal performance; ambient light negatively affects image quality • Installation needs careful planning, including power source and HDMI cable placement • Sound system quality is subpar; external audio system recommended • Electronic keystone correction is not reliable, requiring precise alignment with the screen |
BenQ TK700 | Pros • Incredible colors and crispness • Very easy to set up and scale to the screen size • Great value for money • Excellent image and color quality • Outstanding performance as a gaming projector with awesome picture and response time • Brightness is impressive, especially in gaming mode • Fun experience for watching movies despite not achieving the deepest blacks Cons • Requires specific throw distance; may not fit all room setups • Quick adjust capstone limits placement options, particularly with ceiling fans • Not ideal for dedicated movie watching if deep black levels are a priority • May not work as advertised in certain environments, leading to potential returns |
BenQ TH575 | Pros • Bright, sharp picture quality • Very quiet operation • Impressive performance at a very good price • Vivid colors compared to older models • Smaller footprint than previous models • Significant advancements in technology over older projectors Cons • 3D quality not as good as LCD projectors • Noticeable 'screen door effect' for some users • May require adjustment of colors/brightness settings |
