ASHATA vs EMIUZEK: Which Mini Projector Delivers Better 4K Experience with WiFi6 and Bluetooth?
cruets620
  1. 1 Specs
  2. 2 Which to get
In the realm of portable projectors, two contenders stand out: the ASHATA Portable Mini Video Projector and the EMIUZEK Mini Portable Projector. While both aim to enhance your viewing experience, their approaches and features differ significantly, raising a crucial question for potential buyers: which one truly offers the best balance of performance and convenience?
The ASHATA projector touts a compact design with impressive brightness and an energy-efficient LED light source, perfect for casual movie nights or outdoor gatherings. It's designed for ease of use, featuring multiple input options and a silent cooling system to keep the noise at bay. However, does its 1500 lumens and 1080P support hold up against the competition?
On the other hand, the EMIUZEK projector claims to elevate the game with its 4K support, an astounding 15000 lumens, and advanced features like automatic keystone correction and dual-band WiFi 6. But with its complex setup and reliance on a strong WiFi connection, does it sacrifice user-friendliness for performance?
Join us as we dissect the strengths and weaknesses of these two projectors, helping you decide which one aligns better with your needs—whether that’s portability, image quality, or ease of use.
Specs​
ASHATA Portable Mini Video Projector​
EMIUZEK Mini Portable Projector Projector​
$33.11​
$79.99​
Education, Home Cinema, Gaming​
Home Cinema​
no​
【Visual Feast】1500 lumens, 2800:1, rich color and detail display stand out. Supports 1080P high-definition display and a large screen up to 60 inches, providing sharpness and extracting detailed images from high-definition content without shrinking or manual focus, aspect ratio is 4:3, projection distance can reach 32-79 inches. Super mini size, two different color coatings, is the beautiful decoration of your room
【Excellent performance】In order to reduce noise, the projector has an advanced silent cooling system with fans running at the same time for better performance and immersive audio experience. The portable projector also uses a new generation of Bridgelux LED light source, power consumption 10W-24W, energy saving and environmental protection, does not damage eyesight, LED bulb life is more than 30,000 hours, no need to replace
【Portable Multimedia Input】Mini private home theater, convenient to travel and carry, allowing you to enjoy movies, videos, games in a dim environment, whether at home or outdoor courtyard, travel, camping, etc. It supports HDMI, AV, USB and memory card input, and can easily connect to various media devices, such as TV boxes, laptops, desktop computers, digital cameras, HDMI devices, etc., allowing you to enjoy videos in a variety of ways
【Support 4K, automatic horizontal keystone correction and 15000 lumens】This smart projector has high-resolution 1920*1080P Full HD native and 4K support, 300 ANSI 15000 lumens brightness and 10000:1 contrast ratio. You must manually scroll to adjust the clarity before turning on the projector. Provides clear and sharp images, automatic keystone correction does not distort the image, corrects the image up and down, and can be adjusted in the settings if you need to adjust the side projection. Automatic zoom can be easily set to watch videos
【Built-in dual-band WiFi 6 and 180° adjustable portable projector】No fixed installation is required, the projection angle can be flexibly adjusted, and a more immersive viewing experience is provided on a 150-inch giant screen. Not restricted by the environment, it can be projected onto the ceiling. Convenient. Built-in dual-band 5G Wifi 6, experience lower latency and higher response speed, so that you feel like you are in a movie theater, fully immersed in movies or other entertainment content. Great for video conferencing and games, watching movies, yoga.
【Easy to use】: The projector must be connected to wifi when it is turned on. Open Applications and download TV Casting to perform wireless screen mirroring. Strong wifi signal has lower latency. Built-in app applications (If Netflix cannot be used, you can try to update or uninstall and then install again. If it still cannot be used, please contact us) The projector has a built-in speaker if you have high requirements for sound quality. You can use Bluetooth wireless and wired speakers.
32 Inches - 60 Inches​
N/A - 6.5 Feet​
3.28 - 13.12​
800:1​
320 x 240​
1500 lumens​
LED​
LED​
Lightweight​
Digital Keystone Correction, Native Full HD 1080P, Bluetooth5.0, 2.4/5G WiFi6, 300ANSI​
MP4​
30000 Hours​
Button Control​
vga cable, USB, HDMI
Bluetooth, Wi-Fi, USB, 3.5mm Jack​
TV Box, Laptop, Desktop Computer, Digital Camera, DVD Player​
24 watts​
Mount Type​
Tabletop Mount​
Tabletop Mount​
Which to get​
I've been looking to get a portable projector and I’m torn between two options: the ASHATA Portable Mini Video Projector and the EMIUZEK Mini Portable Projector. Here’s what I’m seeing:
The ASHATA boasts 1500 lumens and supports 1080P, so it should deliver decent picture quality, especially for its size. Plus, it has a cool silent cooling system and a long LED bulb life. It’s compact and can project up to 60 inches, which is great for casual movie nights. However, I wonder how it really holds up in terms of sound since it mentions an immersive audio experience but doesn’t elaborate much.
On the flip side, the EMIUZEK projector claims to support 4K with a much higher brightness of 15000 lumens and a contrast ratio of 10000:1. It also has automatic keystone correction, which sounds super handy. The built-in dual-band WiFi 6 is a nice touch, especially for streaming—no one wants to deal with lag, right? But it does require a WiFi connection to operate, which could be a hassle if I want to use it outdoors or in places without good internet.
Both seem pretty portable, but what do you all think? Is the higher resolution and brightness of the EMIUZEK worth the potential WiFi dependency and setup hassle? Or should I stick with the ASHATA for its simplicity and reliability? Would love your thoughts on picture quality, sound, and any downsides you've noticed with either!
goalweiser
So, I picked up this ASHATA Portable Mini Video Projector, and honestly, I thought it would be perfect for filling up a whole room with a movie vibe. But get this: it actually works best when you keep it closer, kinda like a mini TV. Sure, you can make the image bigger, but then it gets a bit blurry, especially when you’re trying to read subtitles. Oh, and the fan is louder than whatever you’re watching, which can be a bit annoying. But hey, for the price, I can’t complain too much! I’m still pretty happy with my buy! 😊
Happy7User
I was super pumped to get my hands on the ASHATA Portable Mini Video Projector for our movie night at home. I fired it up, and everything seemed great—except for one major bummer: the sound. The audio jack just wouldn’t cooperate at all. It totally killed the vibe and made it feel like a waste. What a letdown!
OneTimeSE
So, I got this ASHATA Portable Mini Video Projector thinking it’d be perfect for my Zoom meetings. But man, I should’ve done my homework! First off, it doesn’t have any sound at all—you’ve gotta hook up some speakers to get any noise out of it. And then there’s the whole lighting situation; the room needs to be pretty dark if you want to see anything clearly.
Long story short, it just wasn’t gonna work for me. Since it was my bad for not checking the details, I didn’t even bother reaching out to the company. Instead, I gave it to a friend who has kids. They’ll have a blast with it!
Hey folks, just a heads up about the ASHATA Portable Mini Video Projector. Honestly, it’s not worth your cash. Setting it up is a real pain, and the picture quality? Yikes! Plus, you’ll need to buy an extra cord to make it work. Trust me, save your money and skip this one!
