ARTSEA vs AKIYO vs PANSEBA Mini Projectors: Which Offers Better WiFi & Bluetooth Connectivity?
mufcroberts
ARTSEA Mini Projector​
AKIYO Mini Projector​
PANSEBA Mini Projector​
$39.99​
$65.99​
$50.99​
Indoor/Outdoor​
Home Cinema​
User Manual, Power Cord, Projector Lens Cover, Remote, HDMI Cable​
Projector Stand​
User Manual, Power Cord, Projector Screen, Remote, HDMI Cable​
Device Compatibility: iPhone/Android casting with Type C to HDMI cable or MHL adapter required (not included), must support Multi-screen/wireless display.
Dimensions: 6.6 x 4.7 x 2.5 inches
Weight: Approximately 2 pounds
Projection Size: 30 to 200 inches
Projection Distance: 2.7ft to 18ft
Lamp Lifespan: Up to 55,000 hours
Noise Reduction: 80% reduction in fan noise
Audio: Built-in stereo speakers, external speaker connectivity available
Connectivity Options: HDMI, 3.5mm audio, USB interfaces
Use Cases: Ideal for videos, photos, and sports; not recommended for PPT/business presentations
Support: 3 years factory support
Portability: Compact design for easy transport
Streaming Restrictions: Apps like Netflix, Prime Video, Hulu require TV Stick or Roku for playback
P2P Direct Connection: No WiFi required for screen casting; one-click connection for iOS/Android.
Resolution: Native 720P (1280*720); supports Full HD 1080P.
Brightness & Contrast: 200 ANSI lumens; 2000:1 contrast ratio.
Size & Weight: Dimensions 5.35*4.33*2.28 in; weight 420 grams.
Connectivity: Supports 5G/2.4G dual-screen WiFi; Bluetooth 5.2 (not for phones).
Input Sources: HDMI, USB, 3.5mm audio output; compatible with multiple devices.
Warranty & Support: 2-year warranty; 24H service response available.
Low Noise: Advanced fan cooling technology reduces noise.
Long Lamp Life: Bulb lasts up to 50,000 hours (~15 years).
Multiple Input Compatibility: Connects with laptops, smartphones, tablets, USB drives, X-Box (note: incompatible with Hulu).
Smartphone Connection: Requires HDMI adapter (not included); Lightning to HDMI for iOS, MHL support for Android.
Image Brightness: 50% brighter than similar projectors, 8000:1 contrast ratio, supports 1080p resolution.
Bluetooth 5.2 & HIFI Speaker: Built-in speakers with HIFI sound, can connect to Bluetooth speakers and function as a Bluetooth speaker.
Unboxing Experience​
ARTSEA Mini Projector:​
The ARTSEA Mini Projector boasts a compact and cute design that is both portable and aesthetically pleasing. It fits comfortably in my hand and is light enough to carry around effortlessly. The overall look is modern, making it a suitable addition to any home or office setup without taking up much space.
AKIYO Mini Projector:​
The AKIYO Mini Projector is surprisingly compact and portable, roughly the size of a large watch box. I was initially impressed by its design; it looks bigger in pictures than in reality. The included tripod adds stability and allows for easy setup, whether on a tabletop or mounted on the ceiling. It has a straightforward aesthetic that doesn’t scream "tech gadget," making it blend well in various environments, perfect for movie nights or casual gatherings.
PANSEBA Mini Projector:​
The PANSEBA Mini Projector boasts a sleek and compact design that easily fits into my backpack, making it highly portable. Its lightweight build and balanced weight distribution give it a professional yet stylish look that stands out in any setting. The included projector screen, while somewhat thin, complements the projector well, and I appreciate the overall aesthetic that doesn’t compromise on functionality.
20 Inches - 200 Inches​
32 Inches - 120 Inches​
32 Inches - 200 Inches​
2.7 Feet - 18 Feet​
0.6 Meters - 4 Meters​
2.65 Feet - 26.25 Feet​
Standard​
5000:1​
8000:1​
1280 x 720 Pixels​
1920*1080 Pixels​
1980 x 1080 Pixels​
1280 x 720​
1280 x 720​
5500 Lumen​
95 Lumen​
LED​
Not Specified​
High Contrast Ratio and Full HD Resolution​
The viewing experience with this projector has been delightful. The clarity and brightness of the images are impressive for a device in this price range, providing vivid visuals even in less-than-ideal lighting conditions. While the projection resolution is only adequate, it remains acceptable given the affordability of the projector. I did find that using the internal speaker provided the best audio sync with video, although connecting to external speakers introduced some lag.
The viewing experience with this projector is quite commendable, especially in darker environments. While the image quality might not rival high-end projectors, the clarity and brightness are impressive for a budget-friendly option. Watching movies or gaming with this projector provided a satisfying experience, particularly when connected via HDMI. However, I did notice some light artifacts typical of projectors in this price range, and those who stream wirelessly might experience occasional lags. Overall, for casual movie nights, it delivers a solid performance.
The viewing experience with this mini projector has been surprisingly fulfilling. The Full HD 1080P resolution delivers sharp and vibrant visuals, making movie nights feel more like a cinema experience. I found the brightness impressive, even in dimly lit rooms, although it struggles a bit in brighter settings. The color quality is rich, but I did notice some challenges with text clarity at times. When projecting onto a wall, the picture quality remains strong, affirming that this projector can accommodate larger screens up to 200 inches without compromising the viewing experience.
Built-In Speaker, Dust-Proof, Portable, Lightweight​
Built-In Speaker, Portable, Digital Keystone Correction, Lightweight, 50%-100% Zoom​
AVC​
AVC​
H.264 or MPEG-4 AVC​
3 Watts​
5.5E+4 Hours​
55000 Hours​
50000 Hours​
Button Control​
App​
HDMI
Wireless​
Laptop, Gaming Console, Tablet, Smartphone​
TV Stick, Smartphone, USB, SD Card​
38 Watt-hours​
55 watts​
Mount Type​
Floor Mount/Ceiling Mount/Floor Mount/Tabletop Mount/Tripod Mount/Wall Mount​
Tabletop Mount​
Ceiling/Floor/Tabletop/Tripod/Wall Mount​
6"L x 4"W x 2"H​
5.35"L x 4.33"W x 2.28"H​
7.28"L x 5.98"W x 2.95"H​
Setting up the ARTSEA Mini Projector was incredibly straightforward. I was able to connect it to my devices with ease, utilizing HDMI and Bluetooth options. The intuitive controls made it simple to operate right out of the box, requiring minimal assembly. Overall, the projector is user-friendly, making it accessible even for those who may not be tech-savvy.
Setting up the AKIYO Mini Projector was a breeze. Although I initially faced some issues with connectivity, particularly with newer devices requiring adapters, the overall experience was user-friendly. I appreciated the inclusion of clear instructions and the option to connect via HDMI or Bluetooth. The projector supports various devices, including phones, tablets, and gaming consoles, which adds to its versatility. While some users experienced minor setup confusion, it ultimately became easy to use after the initial adjustments.
Setting up the PANSEBA Mini Projector was incredibly easy and user-friendly. It took me less than three minutes to swap it out with my old projector and get everything up and running. The intuitive controls—both on the device and via the handy remote—made navigating the settings a breeze. It works seamlessly with devices like Roku, Firestick, and laptops through the HDMI port, which enhances its versatility and makes it suitable for various uses, from movie nights to presentations.
• Excellent picture quality for the price
• Highly portable and easy to set up
• User-friendly controls and connectivity
• Great value for budget-conscious consumers
• Compact size makes it easy to transport
• Limited resolution and no keystone correction
• Audio quality from external speakers can lag
• No built-in streaming apps or advanced features
• Some users reported issues with setup and connectivity
The ARTSEA Mini Projector has exceeded my expectations as an affordable, portable projector. It delivers a satisfying viewing experience, especially for casual movie nights or presentations. While it does have some limitations, such as lack of advanced features and potential audio lag with external devices, the overall performance, ease of use, and stunning value make it a commendable choice. I would highly recommend it to anyone looking for a reliable and high-performing portable projector without breaking the bank.
- Great projection quality, especially with HDMI connections.
- Compact and portable design, easy to transport.
- Good value for the price, especially for casual use.
- Compatible with various devices and offers Bluetooth functionality for audio.
- Customer service is highly responsive and helpful.
- Built-in speakers are not powerful; external speakers recommended.
- Connectivity issues with some devices, especially newer ones requiring adapters.
- Occasional lag with wireless streaming; HDMI is more stable.
- Can overheat during prolonged use.
The AKIYO Mini Projector is a fantastic choice for anyone looking for an affordable and functional projector. It excels in providing decent picture quality and is easy to set up, making it suitable for family movie nights or casual gaming. While it has its limitations, particularly in sound quality and potential connectivity issues, the positives far outweigh the negatives. With excellent customer service backing it up, I can confidently recommend this projector for those who want an economical solution for their viewing needs.
• Easy to setup and use.
• Lightweight and portable design.
• Full HD 1080P resolution delivers vibrant colors.
• Two-way Bluetooth connectivity enhances audio options.
• Decent built-in speakers for casual use.
• Sound quality can be lacking without external speakers.
• Some blurriness and clarity issues with text.
• The included projector screen is a bit transparent.
• Limited functionality with mobile devices unless using adapters.
Overall, the PANSEBA Mini Projector is an impressive device that offers excellent value for its price. It’s perfect for those looking to enjoy movies, gaming, or presentations in a portable format. Although there are some minor drawbacks, such as audio quality and occasional clarity issues with text, the bright, vibrant image quality and ease of use overshadow these concerns. I highly recommend this projector to anyone seeking an affordable yet effective solution for their projection needs.
