- 1 First Impressions
- 2 Introduce
- 3 Display
- 4 Features
- 5 User Feedback
First Impressions
It seems there are two schools of thought when it comes to the design of portable projectors today, the most popular of which yields devices shaped like cylinders or cones. Just as interesting is the movement to replace them with cubes or rectangular devices, like the Anker Nebula Mars 3 Air. At 7 x 4.8 x 5.2 inches and 3.7 pounds, it's slightly larger and heavier than the cylindrical Asus ZenBeam L2 but has a carrying handle for moving it to the living room at home or an empty room at work.Its perforated gray plastic case has a large central lens that's placed 4-inches above the base so that in many cases it won't need to be tilted for screen or wall viewing. It does, however, lack a pull-out leg beneath the projector—as is the case with some competitors—for situations where tilting is necessary. Like most others, there's neither a lens cap nor a way to level the projector.
Parameter | Anker Nebula Mars 3 |
Reference Price | $999.99 |
Recommended Uses | Home Cinema, Business |
Built-In Media | Nebula Mars 3, Remote, Power Adapter, Power Cord, 2x AAA Batteries, Quick Start Guide |
Highlight | • Brightness: 1000 ANSI Lumens • Max Screen Size: 200 inches • Resolution: 1080p • AI Brightness Adjustment: Yes • Operating System: Android TV 11.0 • App Compatibility: 400,000+ movies and shows, 7000+ apps • Chromecast and Google Assistant Support: Yes • Battery Capacity: 185Wh • Playtime: Up to 5 hours for movies, 15 hours for music • Water Resistance: IPX3 • Drop Resistance: 0.5 m • Dust Resistance: 0.7 mm • Built-in Speaker Power: 40W with Dolby Digital Plus • Setup Time: 3 seconds (autofocus, keystone correction, Screen Fit) • Additional Features: Built-in stand, lens cover, camping light, power indicator, integrated controls, carry handle. |
Screen Size | 200 Inches - 200 Inches |
Throw Distance | 5.54 Feet - 13.85 Feet |
Brightness | 1000 lumen |
Display Type | DLP |
Picture Enhancement | HDR10 |
Viewing Experience | The Anker Mars 3 Air projector offers a straightforward approach to projection with four presets and a Custom mode for personalized settings. It provides various color temperature options, allowing users to fine-tune the color balance, although it lacks standardized color settings like sRGB or Rec.709. The projector delivers a peak output of 399 ANSI lumens in Conference mode, suitable for well-lit environments, but struggles against direct sunlight, producing a noticeable green tint. In Standard mode, brightness slightly decreases to 383 ANSI lumens, but the color balance improves significantly, resulting in a vibrant display, albeit with a hint of warmth. Overall, the Anker Mars 3 Air is a capable projector that performs well in controlled lighting conditions, with adjustable settings for enhanced usability. |
Video Encoding | H.264, H.265 (HEVC), VP9 |
Control Method | Touch |
Lamp Wattage | 40 Watts |
Wattage | 40 watts |
Hardware Connectivity | Bluetooth, USB |
Compatible Devices | Television, Laptop, Smartphone, Gaming Console, Speaker |
Other Features | Autofocus, Auto keystone, 1000 ANSI Lumens, Android TV 11.0, 200-Inch Picture, Chromecast built-in, netflix ;IEA technology,AI powered, Built-in Battery ;IPX3 water resistance,Drop resistance,Dust resistance,camping light; Office and business use |
L x W x H | 6.29"L x 10.23"W x 9.84"H |
System Experience | The product delivers a high-quality full HD 1920x1080 resolution image using advanced LED technology, ensuring vibrant color output through its DLP imaging chip. The maintenance-free design, highlighted by the sealed lighting components and the impressive 30,000-hour lifespan of the LEDs, adds significant convenience for users, making it a reliable choice for long-term use. Overall, it combines excellent performance with minimal upkeep, making it an appealing option for anyone in need of a projector. |
User Feedback
Pros• Excellent picture quality with HDR and sharp image
• Easy to set up and use with auto sizing, keystone adjustment, and focus
• Impressive built-in speakers outperform competitors
• Portable design ideal for outdoor use
• AI image feature adjusts brightness according to the environment
• Great value for money compared to higher-end 4k models
Cons
• Slight lag in loading and menu navigation
• Lack of native Netflix support, requiring additional device for streaming
Overall Impression
The Anker Mars 3 projector offers an outstanding performance, particularly for those looking for a portable option that excels in outdoor settings. With its impressive picture quality, excellent sound, and user-friendly features, it stands out as a fantastic alternative to more expensive 4k projectors. While there are minor drawbacks in terms of menu navigation and streaming capabilities, these do not significantly detract from the overall value and experience. Highly recommended for anyone seeking a versatile and budget-friendly projector.
