Alwtniet Smart Projector vs Magcubic Mini Projector vs AKIYO Smart Projector: Which One is Best for Netflix?
mufcroberts
Alwtniet Smart Projector​
Magcubic Mini Projector​
AKIYO Smart Projector​
$199.99​
$86.99​
$159.99​
Education, Movie Night​
Gaming​
Adapter​
User Manual, Remote, Adapter​
Blu-ray​
Resolution: Native 1080P
Brightness: 700 ANSI Lumens
Screen Size: Up to 200 inches
Offset Technology: 75% auto offset
Throw Ratio: 0.6:1
Focus Adjustment: Electric Focus
Keystone Correction: Vertical Auto Keystone Correction
Audio Output: Dual speakers with stereo sound
Smart Features: Built-in Smart TV OS, access to 1,000,000 videos, licensed apps like Netflix, Prime Video, YouTube
System Update: Manual update required for optimal performance
Built-in Apps: Access to 1,000,000 videos without external devices
Remote Control: Air Mouse remote with voice command support
Resolution: Native 720P with 4K support
Brightness: 200 ANSI lumens, 10000:1 contrast ratio
Usage Scenarios: Suitable for casual use, family entertainment, outdoor movies
Design: Versatile with ceiling, table, tripod options and 180-degree rotation
Built-in Apps: Officially supports Netflix, Prime Video, YouTube, Hulu, 1000+ applications; one-click access for popular apps on remote.
AI Autofocus & Keystone Correction: Autofocus in 5 seconds, ±45° horizontal and vertical keystone correction, 4P corner adjustment.
Connectivity: 5G WiFi (2.4G/5GHz, max speed 9.6G bps), two-way Bluetooth 5.2 for external speakers and mobile device connection.
Resolution & Brightness: Native 1080P, 4K support, 600 ANSI lumens brightness, 20000:1 contrast ratio.
Screen Size & Zoom: Displays 30 to 300 inches from 1m to 5m distance; 50% zoom function without moving the projector.
Weight & Portability: Weighs 30% less than similar projectors, compact size for easy transport.
Connections & Support: Built-in HDMI, USB*2, AV, 3.5mm audio output; compatible with PC, Fire Stick, PS5; lifetime tech support and 2-year warranty.
Unboxing Experience​
Alwtniet Smart Projector:​
The projector boasts a solid and well-built design, which provides both aesthetic and functional appeal. Its compact size allows it to fit neatly in any media room, while the sleek finish gives it a modern look that can complement various interior styles. I appreciate the thoughtful layout of the buttons and ports, making it easy to access and manage.
Magcubic Mini Projector:​
The projector has a sleek and lightweight design, making it travel-friendly while still offering a decent size that fits well in my entertainment space. The construction feels reliable, but the placement of the power supply could be improved as it sits close to the arm, which could potentially cause some inconvenience. Overall, it presents a visually appealing look that doesn’t scream “budget,” and I appreciate its compactness.
AKIYO Smart Projector:​
The mini projector presents a sleek and modern design, making it visually appealing for various settings. Its compact size ensures portability, and it comes with a customized carrying case, which is a thoughtful addition that enhances its usability. While it looks nice overall, I did find that the remote control lacks batteries, which is a minor inconvenience, though I had spare ones available.
40 Inches - 150 Inches​
30 Inches - 240 Inches​
0.55 - 2.1​
0.9 Meters - 4 Meters​
1 Meters - 3 Meters​
10000:1​
20000:1​
7680×4320​
1980 x 1080 Pixels​
1920x1080 Pixels​
1280 x 720​
8000 Lumen​
20000 Lumen​
LED​
Some picture quality enhancement technology​
The viewing experience has been mostly enjoyable, thanks to the projector's bright display and clear images. At a short distance, I was pleasantly surprised by the large screen size it produced. The projector supports native streaming from platforms like YouTube, Disney+, and Netflix, which adds to its versatility. However, I did face some challenges with picture quality—while the brightness is excellent, the resolution is more akin to 720p rather than the promised 1080p. Additionally, it requires a dark environment for optimal viewing, which can limit its usability in brighter settings.
The viewing quality is quite good, especially when projecting onto a wall, which I prefer over a separate screen. The size of the projection is impressive, filling up most of my bedroom wall even at the lowest setting, and the keystone correction works effectively. However, I did notice some lag when mirroring my phone, which caused audio to fall out of sync with the video. The brightness could be enhanced, particularly around the edges, and I found that a darker room yields the best results. Overall, I was satisfied with the clarity and size of the image, especially for casual movie nights.
The viewing experience was generally satisfying, especially with the projector's native 1080P resolution that delivered sharp and vivid images. However, I did notice a disparity in image quality, as it seemed to be clearer in the center and less so at the edges. Even with the brightness turned up to 100%, I found the colors lacked the vibrancy I had hoped for, which was a bit disappointing. For casual movie nights, though, the projector holds up well, especially when projecting onto larger spaces like a 9'x10' screen.
Built-In Speaker​
Air Mouse Control, Portable, Bluetooth, Voice Control, Built-In Wi-Fi​
WiFi-6, Native 1080P, Auto Focus-Keystone, Built-in System, Netflix Licensed​
AVC​
H.264, H.265, VP9, AV1​
50 Watts​
20000 Hours​
9000 Hours​
Remote, Button Control​
Wi-Fi​
Bluetooth, Wi-Fi, USB, HDMI
56.00​
Mount Type​
Tabletop Mount​
Tabletop Mount​
Front/Rear/Ceiling/Tripod​
12"L x 6"W x 10"H​
Setting up this projector was a breeze; after simply plugging in the power and upgrading the system for initial use, I was up and running in no time. The inclusion of popular apps and an App Store allows for easy downloading of additional software. Once I connected it to WiFi, I found it incredibly convenient to stream content without needing to deal with HDMI cables or other connections. This user-friendly setup makes it perfect for quick family movie nights.
Setting up the projector was incredibly straightforward, with Android onboard making navigation easy. However, I encountered some initial difficulties with connectivity, particularly with streaming apps like Netflix, Hulu, and HBO. After several frustrating hours of trying to log in and troubleshoot, I realized that I might need additional devices, like a Roku stick, to improve performance. The Bluetooth capabilities were also a mixed bag; while I had success connecting to Bluetooth speakers, it took multiple attempts, which added to my setup challenges.
Setting up the projector was a breeze; the straightforward process allowed me to connect it to my Windows and Mac laptops without any issues. The HDMI connectivity is particularly seamless, and I appreciated the option for wireless connection, which reportedly takes just five seconds. However, some users have expressed concerns about the projector's ability to stay connected to Wi-Fi, which might affect its usability for streaming purposes.
• Solid and well-built design
• Easy setup with popular apps included
• Bright display with clear images
• Good sound quality for standalone use
• Affordable price for the features offered
• Picture quality resembles 720p, not true 1080p
• No manual or detailed configuration support available
• Poor customer service regarding Amazon purchases
• Limited functionality with certain apps, especially Netflix
• Requires a pitch-dark environment for best visibility
Overall, I find this projector to be a solid choice for home entertainment, especially given its reasonable price point. While it has some drawbacks—such as the resolution issues and the need for a dark setting—it still delivers an enjoyable viewing experience and is straightforward to set up. If you’re looking for an affordable projector that performs well in a home theater environment, this one is worth considering, but be prepared for some limitations in app performance and picture quality.
• Excellent video quality for the price
• Easy to set up and navigate
• Good size projection covering a large area
• Sound quality is subpar and tinny
• Lag when mirroring from a phone
• Connectivity issues with streaming apps
• Short power cord may limit placement options
Overall, I find this projector to be a great value for the price, despite its few drawbacks. It excels in providing a large projection size and decent image quality, making it suitable for casual use, especially for family movie nights. While the sound leaves a lot to be desired, the option to connect to better speakers mitigates that issue. I would definitely recommend it for anyone looking for an affordable projector, but I advise potential buyers to be aware of the setup challenges and connectivity issues with apps.
• Excellent 1080P resolution for clear images
• Easy setup and connectivity with multiple devices
• Includes carrying case for portability
• Good for outdoor family movie nights and camping
• Zoom function works effectively
• Picture quality inconsistent at edges
• Wi-Fi connectivity issues reported by some users
• Remote control does not come with batteries
• Lack of vibrant colors in projection
• Some streaming features do not work well with phones
Overall, the mini projector is a solid choice for those looking for a budget-friendly option with decent performance. It excels in connectivity with computers and is easy to set up, making it great for family nights or outdoor activities. However, its limitations in Wi-Fi stability and color vibrancy, along with some user-specific issues, make it worth considering if you prioritize ease of use over top-notch image quality. While I would recommend it for casual viewing, I would also advise potential buyers to be aware of its shortcomings, particularly regarding mobile streaming.
GreatKangaroo
The Alwtniet Smart Projector is awesome! It's perfect for movie nights at home, work presentations, or outdoor fun. The picture is super clear, colors pop, and it's a breeze to use. Plus, it won't break the bank—way better value than other brands. Definitely check it out!
Trollatopoulous
AKIYO Smart Projector is awesome for my golf simulator! No problems at all. Great detail at 1080P, plus it’s got WiFi, Bluetooth, HDMI, and a speaker. Can’t go wrong with it! Just a heads up, the zoom works well, but I had to move it back a bit to fit my 9’x10’ screen. Super easy!
