Shelby_Compare
Unboxing Experience
- 1.1.1 AKIYO Mini Projector:
- 1.1.2 BIGASUO Mini Projector:
- 1.1.3 TOPTRO Mini Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 AKIYO Mini Projector:
- 1.3.2 BIGASUO Mini Projector:
- 1.3.3 TOPTRO Mini Projector:
- 1.4 Features
1.5
- 1.5.1 AKIYO Mini Projector:
- 1.5.2 BIGASUO Mini Projector:
- 1.5.3 TOPTRO Mini Projector:
1.1
Unboxing Experience
- 2 Conclusion
Parameter | AKIYO Mini Projector | BIGASUO Mini Projector | TOPTRO Mini Projector |
Picture | |||
Reference Price | $55.99 | $99.98 | $99.99 |
Recommended Uses | Indoor/Outdoor | Home Cinema, Outdoor Movies, Gaming | Home theater, Gaming, Education, Conference, Outdoor movie |
Built-In Media | Projector Stand | Projector, Built-in DVD Player, User Manual, Remote Control, Carry Bag, Tripod, HDMI Cable, AV VGA AC Adapter, Dual Powerful Speakers | 1* HDMI Cable, 1* Cleaning Cloth, 1* TR23 Projector, 1* Power Cord, 1* Remote Control |
Highlight | Connection Type: P2P Direct Connection (No WiFi Required), 5G/2.4G dual-screen WiFi, Bluetooth 5.2 Resolution: Native 720P (1280x720), Full HD 1080P supported Brightness: 200 ANSI Contrast Ratio: 2000:1 Size: 5.35 x 4.33 x 2.28 in Weight: 420 grams Keystone Correction: ±50° electronic vertical Zoom Function: 50% zoom via remote Projection Screen Size: 32-120 in Optimal Projection Distance: 3.28-9.84 feet Input Interfaces: HDMI, USB, 3.5mm audio output Device Compatibility: Android, iOS, Windows 10, PC, Fire Stick, PS5 Warranty: 2 years Customer Support: 24H service response available | Product Type: 2-in-1 Projector with Built-in DVD Player Brightness: 9000 Lux Resolution: HD 1080P Audio: Built-in HiFi speakers, Bluetooth 5.0 support (not for smartphones) Supported Media: CD, DVD, CD-R/RW, DVD-R/+R, DVD+RW/-RW, VCD, SVCD (No Blu-ray support) Connectivity: USB, HDMI, AV, VGA, Micro SD, Audio port Display Size: Up to 200 inches Included Accessories: Carry bag, tripod, multi-cable Warranty: 30 days refund/replacement, 3 years tech support | Lumens: 15000 Resolution: 1920 x 1080 (Full HD) Contrast Ratio: 20000:1 Zoom: 100%-50% Focus Type: Electric-Focus Image Correction: 4D/4P Optical Design: Fully Sealed (IP5X certification) WiFi: 5G/2.4G Bluetooth Version: 5.2 Audio: 360-degree stereo surround sound Warranty: 1-year money-back, 3-year repair, lifetime support |
Unboxing Experience
The projector has a compact and practical design that I found visually appealing. It fits well in various settings, whether it's mounted on a shelf or placed on a tripod. The sleek finish and lightweight construction make it easy to transport, which is a significant advantage for both indoor and outdoor use. Despite its small size, the build quality feels robust, and it includes thoughtful touches like multiple orientation options for flexibility in projection.BIGASUO Mini Projector:
Upon unboxing the projector, my first impression was quite positive. It came in a sturdy carrying case that not only protects the unit but also keeps all the accessories organized. The projector itself has a sleek design, and its compact size makes it easy to transport, especially for our camping trips. I appreciated the thoughtful inclusion of a protective case, which I wasn't expecting, and it made the overall experience feel premium.TOPTRO Mini Projector:
Upon first glance, this portable projector impresses with its compact design and low-profile build. Lightweight and easy to handle, it fits seamlessly on tables or bookshelves without taking up too much space. The control buttons are touch-sensitive and illuminated, which adds a modern touch to its aesthetic. The projector is surprisingly attractive for a device of its kind, making it suitable for both casual home use and professional settings.Display
Screen Size | 32 Inches - 120 Inches | 2.5E+2 Inches - 322 Inches | 1E+2 Inches - 139.1 Inches |
Throw Distance | 0.6 Meters - 4 Meters | 1 Meters - 4 Meters | N/A - 16 Feet |
Contrast Ratio | 5000:1 | 8000:1 | 20000:1 |
Maximum Resolution | 1920*1080 Pixels | 1080P Supported | 1920 x 1080 |
Native Resolution | 1280 x 720 | 1920 x 1080 | 1920 x 1080 |
Brightness | 5500 Lumen | 71.1 lumen | - |
Picture Enhancement | Not Specified | - | - |
Viewing Experience
The viewing experience is commendable, especially in dimly lit environments where the picture quality shines. I was pleasantly surprised by the clarity of the image, given the affordable price point. Whether I was streaming content or connecting via HDMI, the projector delivered a satisfying viewing experience. However, I did encounter some light artifacts typical for projectors in this price range, and the occasional audio lag over Bluetooth was noticeable, but not a dealbreaker for casual use.BIGASUO Mini Projector:
The viewing experience varied depending on the lighting conditions. In dark environments, the picture quality was outstanding, providing vibrant colors and sharp images. However, under daylight or in well-lit rooms, the image did wash out, which is a common issue with projectors. I also discovered that when projecting PowerPoints or text-heavy content, it was sometimes difficult to read in bright light, but this is typically expected from projectors.TOPTRO Mini Projector:
The viewing experience is quite commendable for a projector of this size and price range. The picture quality is sharp and the color reproduction is impressive, especially in dark environments. While it may not achieve the brightness levels of a premium projector, it delivers a satisfactory performance in dimly lit rooms. I found that the image quality remained decent even with some ambient light, although complete darkness produced the best results. Sound quality is adequate for casual viewing, but connecting it to external speakers significantly enhances the experience.Features
Other Features | 1080P Supported, 50% Zoom, ±50° Electronic Keystone Correction, Tripod Included, 5G WiFi | Built-In DVD Player, Bluetooth, Speaker | Wireless, Portable, Built In Wi Fi |
Video Encoding | AVC | AVC | - |
Lamp Wattage | 3 Watts | 48 Watts | 50 Watts |
LightSource Life | 55000 Hours | 65000 Hours | 150000 Hours |
Controller Type | Button Control | Remote Control | Remote Control |
Control Method | App | Remote | Remote |
Connectivity Technology | Wireless | DVD Projector HDMI USB VGA AV Bluetooth MicroSD | USB, HDMI |
Compatible Devices | Television, Gaming Console, Speaker, Laptop, Smartphone, Tablet | Television, Gaming Console, Speaker, Laptop, Smartphone | Smartphone |
Wattage | 38 Watt-hours | 48 watts | 50 watts |
Mount Type | Tabletop Mount | BIGASUO Projector for Ceiling Table Tripod Mount | Table Mount/Floor Mount/Wall Mount/Ceiling Mount |
L x W x H | 5.35"L x 4.33"W x 2.28"H | 7.99"L x 3.86"W x 6.57"H | 6.18"L x 5.19"W x 6.88"H |
Setting up the projector was a breeze; I didn't even need to reference the manual. I was able to connect my devices using HDMI and USB-C without any hiccups. The inclusion of a USB hub was particularly helpful as it resolved initial connectivity issues with external drives. Mirroring my iPad was straightforward as well, enhancing the overall user experience. The projector's compatibility with various devices, including laptops and smartphones, adds to its versatility.BIGASUO Mini Projector:
Setting up the projector was a breeze, particularly since I'm somewhat familiar with projectors. I had everything operational in just a few minutes. The instructions were clear, and the included HDMI cable, remote control, and tripod were easy to use. I also received an offer for a free 84” screen, which adds value to the purchase. However, I did find the description misleading regarding the "charging cord," as it actually came with an AC adapter and no onboard battery was present.TOPTRO Mini Projector:
The setup process for this projector is straightforward and user-friendly. It operates on a plug-and-play basis, allowing me to connect it to various devices like laptops and streaming sticks with minimal hassle. The inclusion of multiple connectivity options, including HDMI, USB, and Bluetooth, enhances its versatility. I appreciated the comprehensive user manual that provided clear instructions for first-time users, making it easy to get started quickly.Conclusion
Pros:• Great projection quality via HDMI
• Easy to set up and connect to multiple devices
• Compact and portable design
• Customer service is responsive and helpful
• Digital zoom and manual focusing options
• Inbuilt speakers lack power and quality
• Some connectivity issues with certain devices
• Occasional light artifacts in the image
• Bluetooth audio lag with no adjustment options
• The projector can get hot quickly
Overall, I would say this projector provides excellent value for its price. It’s not without its flaws, particularly regarding sound quality and some connectivity issues, but the positives outweigh the negatives. The clear image quality, ease of use, and customer service experience left a lasting impression on me. It's a reliable choice for anyone looking to enjoy movies or presentations without breaking the bank. I would certainly recommend it to friends and family, particularly for those seeking an affordable alternative to traditional TVs.
Pros:• Excellent picture quality in dark settings.
• Easy setup and operation.
• Comes with a sturdy carrying case and useful accessories.
• Multiple input options and the ability to use USB and microSD cards.
• Good internal speaker quality for indoor use.
• Picture quality suffers in bright lighting conditions.
• Internal speaker volume is low; external speaker recommended for outdoor use.
• Bluetooth connectivity had issues with sound levels.
• Confusing labeling of buttons and symbols on the device.
Overall, I am quite happy with this projector for the price I paid. It has served us well during family movie nights and camping trips, providing a fun way to enjoy films outdoors. While there were some drawbacks, particularly regarding sound quality and the limitations of the internal speaker, the image quality and ease of use outweighed these issues. I would recommend this projector for casual use, especially for those looking for a budget-friendly option with built-in DVD capabilities.
Pros:• Compact and lightweight design
• Easy setup with multiple connectivity options
• Impressive picture quality in dark environments
• Good color reproduction and clarity
• Quiet fan operation
• Limited brightness in well-lit rooms
• Remote control quality could be improved
• No built-in apps for streaming services
• May require external speakers for optimal sound
Overall, this projector has exceeded my expectations, especially considering its affordability. It's a great choice for anyone looking to replace a small TV or for those who enjoy outdoor movie nights. While it has its limitations—such as brightness levels and the need for additional sound equipment—it remains a versatile and portable option for both entertainment and professional presentations. I would wholeheartedly recommend it for casual use, and I have already considered purchasing additional units for friends and family.
