Unboxing Experience
- 1.1.1 AKIYO Mini Projector:
- 1.1.2 antmap Mini Projector:
- 1.1.3 VISSPL Mini Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 AKIYO Mini Projector:
- 1.3.2 antmap Mini Projector:
- 1.3.3 VISSPL Mini Projector:
- 1.4 Features
1.5
- 1.5.1 AKIYO Mini Projector:
- 1.5.2 antmap Mini Projector:
- 1.5.3 VISSPL Mini Projector:
1.1
Unboxing Experience
- 2 Conclusion
Parameter | AKIYO Mini Projector | antmap Mini Projector | VISSPL Mini Projector |
Picture | |||
Reference Price | $47.49 | $59.49 | $49.99 |
Recommended Uses | Indoor/Outdoor | Education, Home Cinema, Gaming, Business | Home Cinema |
Built-In Media | Projector Stand | User Manual, Power Cord, Remote, HDMI Cable | User Manual, Power Cord, Projector Lens Cover, Remote, HDMI Cable |
Highlight | Connectivity: 5G/2.4G dual-screen WiFi, Bluetooth 5.2 (not compatible with smartphones) Resolution: Native 720P (1280*720), supports Full HD 1080P Brightness/Contrast: 200 ANSI lumens, 2000:1 contrast ratio Size/Weight: 5.35*4.33*2.28 inches, 420 grams Keystone Correction: ±50° electronic vertical keystone correction Zoom: 50% zoom function Projection Size/Distance: 32-120 inches, optimal distance 3.28-9.84 feet Input Sources: HDMI, USB, 3.5mm audio output jack Compatibility: Android/iOS/Windows 10, compatible with PC, Fire Stick, PS5 Warranty: 2-year warranty, 24H customer support available | Resolution: 1920*1080P (Full HD) Brightness & Contrast: Excellent brightness and high dynamic contrast ratio Audio: Built-in 3W stereo speakers, Bluetooth 5.1 WiFi Connectivity: 2.4G and 5G dual WiFi Compatibility: iOS and Android smartphones Projection Size: 35-200 inches Projection Distance: 3.3-17 ft Keystone Correction: 17° Ports: USB, HDMI, micro USB, earphone, power input Compatibility with Devices: Amazon Fire TV Stick, USB, DVD player, laptops, MacBook, iOS/Android devices, external speakers, PS4 Use Case: Indoor & outdoor use, ideal for home theater experience | Dimensions: 6.1 x 5.08 x 2.4 inches Weight: 1.1 lb Resolution: Full HD 1080P Screen Size Support: 35-160 inches Keystone Correction: ±15° Audio: Built-in HiFi speaker Connectivity: HDMI, USB, AV, Audio ports Lamp Life: Over 55,000 hours Cooling Technology: Reduces fan noise by 50% Technical Support: Lifetime support available Note: HDCP restrictions for certain streaming services |
Unboxing Experience
The AKIYO Mini Projector boasts a compact design that is both practical and aesthetically pleasing. Its small size makes it easy to transport, and it comes with its own tripod, which adds a nice touch to the overall appearance. The projector fits well in various settings, whether it's in a living room for family movie nights or a cozy bedroom for personal use. Overall, I find it visually appealing and functional.antmap Mini Projector:
The Antmap Mini Projector boasts a compact design, roughly the size of a medium-sized book, which enhances its portability. Its sleek appearance makes it a visually appealing addition to any space, whether it’s set up in a living room or taken outside for a movie night. The projector’s lightweight construction allows for easy relocation, and the included remote adds to the convenience, making it user-friendly for all ages, from kids to adults.VISSPL Mini Projector:
The VISSPL Mini Projector boasts a compact and lightweight design that makes it highly portable and user-friendly. The build quality feels durable, and the inclusion of a mini tripod adds to its versatility, allowing for straightforward setup in various environments. Although some users have noted the lack of a carry case, the overall aesthetic is pleasant and practical, making it suitable for both casual and professional use.Display
Screen Size | 32 Inches - 120 Inches | 50 Inches - 200 Inches | 35 Inches - 160 Inches |
Throw Distance | 0.6 Meters - 4 Meters | 3.28 Feet - 17.06 Feet | 1 Meters - 4.5 Meters |
Contrast Ratio | 5000:1 | High | 10000:1 |
Maximum Resolution | 1920*1080 Pixels | 1920 x 1080 Pixels | 1920 x 1080 |
Native Resolution | 1280 x 720 | 1280 x 720 | 1920 x 1080 |
Brightness | 5500 Lumen | - | - |
Picture Enhancement | Not Specified | - | - |
Viewing Experience
The viewing experience has been quite impressive, especially in dark environments where the picture quality shines. The clarity of the projection far exceeds my expectations, particularly when compared to my previous projector. However, I did notice that if the projector isn’t perfectly leveled, the image can appear uneven. Nonetheless, when set up correctly, the projection is bright and clear, making it ideal for indoor movie marathons.• **Pros**:
- Excellent picture clarity, especially in dark conditions
- Compact and portable design
- Easy to set up and connect with devices
- Good customer service and support
- Comes with a tripod
• **Cons**:
- Can overheat and may cause electrical issues
- Sound quality is mediocre, often requiring additional speakers
- Difficulties with Wi-Fi connectivity
- Brightness adjustment options are limited
The viewing experience with this projector is quite impressive, especially in low-light conditions. With a native resolution of 1080P full HD, the picture quality is vibrant and sharp, creating a mini cinema feel at home. Although it performs best in dark rooms, it still manages to deliver decent visuals with some ambient light. The ability to project onto large surfaces, such as an eight-foot by four-foot screen, enhances its functionality for movie nights or presentations. However, some users have reported challenges with brightness in well-lit environments.VISSPL Mini Projector:
The image quality of the VISSPL Mini Projector is generally praised for its clarity and brightness, especially in darker environments. Users have successfully utilized it for various purposes, including movie nights, presentations, and art projects, with many expressing satisfaction with the vibrant colors and sharp details. While there are some concerns regarding the 4K quality and the projector's performance in well-lit rooms, it remains a solid choice for casual viewing and entertainment. Audio quality is serviceable, especially when paired with external speakers, enhancing the overall experience.Features
Other Features | 1080P Supported, 50% Zoom, ±50° Electronic Keystone Correction, Tripod Included, 5G WiFi | Built-In Speaker, Portable, Two-way Bluetooth 5.2, Built-In Cooling System, WiFi Connection | Zoom 100%-50%, Built-in Hi-Fi Speaker, Mini and Portable, Tripod Included, Full HD 1080P |
Video Encoding | AVC | H.264 or H.265 | AVC |
Lamp Wattage | 3 Watts | - | 6E+1 Watts |
LightSource Life | 55000 Hours | 30000 Hours | 60000 Hours |
Controller Type | Button Control | Button Control | Button Control |
Control Method | App | Remote, Touch | Remote |
Connectivity Technology | Wireless | Bluetooth, Wi-Fi, USB, HDMI, 3.5mm Jack | HDMI |
Compatible Devices | Television, Gaming Console, Speaker, Laptop, Smartphone, Tablet | Laptop, Gaming Console, Tablet, Smartphone, Speaker | Laptop, PS5, External Speakers, Smartphone, TV Stick |
Wattage | 38 Watt-hours | - | 60 watts |
Mount Type | Tabletop Mount | Tabletop Mount | Tripod Mount |
L x W x H | 5.35"L x 4.33"W x 2.28"H | 6.81"L x 5.47"W x 2.76"H | 6.1"L x 5.08"W x 2.4"H |
Setting up the AKIYO Mini Projector is a breeze. I encountered no issues when connecting it to my devices, whether it was my phone or laptop. The instructions provided were straightforward, making it simple for anyone to get started quickly. While I appreciate its compatibility with various devices, I did experience a bit of trouble with Wi-Fi connectivity, but that didn’t detract much from the overall ease of setup.antmap Mini Projector:
Setting up the Antmap Mini Projector is straightforward and user-friendly. The interface is intuitive, allowing for easy navigation through various settings and features. I appreciated the built-in WiFi and Bluetooth functionality, which makes connecting devices like smartphones and tablets a hassle-free experience. The instructions provided in the handbook are detailed, ensuring that even those less tech-savvy can find their way around the setup process. However, some users have noted difficulties with certain connections, particularly with screen mirroring from mobile devices.VISSPL Mini Projector:
Setting up the VISSPL Mini Projector is a breeze, with most users reporting a plug-and-play experience. The projector comes with essential accessories like an HDMI cable and a remote control, although the remote feels somewhat flimsy and requires batteries that aren't included. The electric keystone correction feature simplifies image alignment, although some users have experienced limitations when adjusting focus in conjunction with keystone settings. Overall, the ease of connection to devices via HDMI and the convenience of wireless connectivity enhance the user experience.Conclusion
Overall Impression:My overall impression of the AKIYO Mini Projector is that it offers great value for its price. Despite some minor issues such as overheating and sound quality, the clarity of the picture and ease of setup make it a worthwhile investment for movie lovers. The customer service experience has also been a positive one, indicating a reliable product support system. I would recommend it to anyone looking for an affordable and functional projector, especially for indoor use.
Pros:• Compact and portable design for easy relocation.
• Bright picture quality with 400 ANSI lumens, suitable for indoor and outdoor use.
• Built-in WiFi and Bluetooth for seamless connectivity.
• User-friendly interface and straightforward setup process.
• Solid performance for movie nights and presentations.
• Picture quality may suffer in bright light conditions.
• Sound quality is average; external speakers are recommended for better audio.
• Some users experience connectivity issues with screen mirroring.
• Limited functionality with certain apps and devices.
Overall, the Antmap Mini Projector has exceeded my expectations in terms of performance and versatility. It offers great value for its price, making it a worthy investment for anyone looking to enhance their home entertainment experience. While there are minor drawbacks, such as sound quality and connectivity issues, the projector's impressive image quality, ease of use, and portability make it an excellent choice for movie enthusiasts and casual viewers alike. I highly recommend this projector for anyone seeking a reliable and enjoyable viewing experience.
Pros:• Portable and compact design
• Easy setup and connectivity
• Good brightness and image quality in low light
• Electric keystone correction simplifies image adjustment
• Affordable price point
• Limited sound quality from built-in speakers
• Some skepticism around 4K capabilities
• Remote control feels cheap and requires batteries not included
• Lacks a carry case for portability
The VISSPL Mini Projector offers exceptional value for its price, making it a great choice for anyone seeking a budget-friendly projector for home use, travel, or educational purposes. While it may not rival high-end models in terms of sound and true 4K performance, its portable design, ease of use, and versatile functionality make it a worthwhile investment. Whether for family movie nights, presentations, or creative projects, this projector has proven itself to be a reliable and enjoyable tool, earning high recommendations from users across various applications.
