AKIYO Mini Projector: Is Portable Power Enough for Outdoor Entertainment, or Does Size Compromise Performance?
Stone_The_Rock
In a world where our devices keep getting smaller, the AKIYO Mini Projector raises an intriguing question: Can a projector this compact truly deliver the cinematic experience we crave? This portable DLP projector, with its palm-sized frame and built-in battery, promises to make movie nights and outdoor gatherings more accessible than ever. But with so many compromises often associated with compact tech, like image quality and sound performance, does this little gadget actually hold up under scrutiny?
We'll dive deep into the specifics of the AKIYO Mini Projector, examining its capabilities, from the vibrant colors produced by its DLP chip to the surprisingly decent audio from its built-in speakers. Is it really a game-changer for on-the-go entertainment, or just another gadget that looks good on paper? If you’ve been considering making the leap into portable projection, stick around as we explore whether this compact device is worth your time and investment.
Spec​
AKIYO Mini Projector Projector​
$209.99​
Tripod, USB-C charging cable, possibly HDMI adapter or dongle​
AKIYO Z9 DLP projector fits in the palm of your hand, easy to enjoy home theater and outdoor entertainment anytime, anywhere, whether traveling or camping is a good choice. Size: 10.5*10.5*2.5cm, weight: 280g. Stylish design and piano baking lacquer finish to create a stylish appearance.
Uses Texas Instruments DLP chip, generating less heat Delivers vibrant colors and more vivid images than LED projectors High-performance fan ensures fast heat dissipation and far lower noise levels than LED projectors Built-in 1.5W HiFi dual speakers bring you a great audio and visual experience.
Simple UI design, HDMI plug-and-play. Playback time is 1.5 hours using the USB-C charging port, or if there is no available outlet, you can use a mobile power source or laptop to charge. It can also be used as a mobile power source to charge your phone. With the included tripod, the portable projector can be used for clear outdoor viewing.
With a powerful DLP chip, built-in 854*480p resolution, 120 ANSI lumens and three-stage adjustable brightness, you can enjoy clear and bright imaging even in dark environments. The projector is available in projection sizes of 30-120 inches and is equipped with ±40° vertical keystone correction for rectangular imaging.
Equipped with HDMI, audio output and USB ports (no reading support, for charging only). The projector supports connection to laptops, Chromecast, PS4 and Fire Stick. iPhone or Android smartphones can also be connected if you purchase an additional HDMI adapter or dongle.
30 Inches - 120 Inches​
10000:1​
854 x 480​
120 lumen​
DLP​
DLP​
H.264, MPEG-4, or AVC​
20000 Hours​
Button Control​
App​
1.5 Watts​
3 watts​
HDMI
Hardware Connectivity​
USB, USB Type C, HDMI, 3.5mm Audio​
Built-In Speaker, Digital Keystone Correction, Lightweight​
0.98"L x 4.13"W x 0.98"H​
Item Weight​
0.28 Kilograms​
Setting up the projector was fairly straightforward, which is one of the aspects I appreciated the most. I love gadgets that don’t require a PhD to get up and running, and this one fit the bill nicely. Its lightweight design made it easy to transport, which was a huge draw for me since I often find myself needing something portable. However, despite the initial ease of setup, I quickly realized that the projector didn’t really live up to my expectations for on-the-go use.
When it came to picture quality, I found myself feeling quite disappointed. I had high hopes that it would deliver a vibrant display, especially for the price. Unfortunately, the resolution was noticeably low, and even in dim lighting, the projection left much to be desired. It’s frustrating when you invest in tech and it fails to provide the experience you were hoping for. The colors didn’t pop like I imagined they would, and that took away from the overall enjoyment.
Other Experience​
My overall experience with the projector was a rollercoaster of emotions. Initially, I was impressed by how compact and easy it was to carry around. But as time went on, the excitement faded as I encountered issues. It heated up more than I expected, which made me wary about using it for extended periods. After just a couple of weeks, it began to show signs of trouble, not holding a charge, and eventually, it just wouldn't turn on at all. That was incredibly frustrating, especially since I was careful with it.
On the positive side, I do appreciate how portable and lightweight the projector is. It’s easy to throw in a bag and take along to various places, which is something I value. Additionally, the sound was surprisingly quiet, and I liked that it charged quickly. When it did work, the contrast was decent, and I could see the potential for vibrant colors in the right conditions.
Unfortunately, the list of cons is pretty significant. The high price tag felt unjustifiable given the low resolution and poor projection quality. The fact that it overheats adds to my list of worries, especially since it doesn’t seem to have the durability I was hoping for. Ultimately, after a short period of use, it became clear that it wasn’t built to last, and the lack of support or warranty made it feel like a gamble.
In the end, I can’t help but feel let down by this projector. What started as a promising purchase quickly turned into a regretful one. For the money I spent, I expected a lot more in terms of performance and longevity. Based on my experience, I would recommend saving up for a more reliable option rather than settling for a product that feels like a waste of money. It’s a shame because it had potential, but the shortcomings ultimately overshadowed the benefits.
jcwillia1
1. Super portable
2. Lightweight
3. Simple to fix and use
Dislikes:
1. Kinda pricey
2. Resolution kinda sucks
3. Doesn’t project well in low light
4. Gets hot pretty fast
Why I bought the projector
So, I got this projector thinking it’d be awesome to take it anywhere I wanted. But honestly, it doesn’t really do what I hoped it would. If it actually worked like it should, it’d be a decent gadget. But for the price I paid, I’m feeling pretty let down.
NetworkingJesus
It was awesome for a bit, but then it just gave up on me after about 8 months. I couldn’t find any support to help me out, either. Honestly, if you’re thinking about getting a projector, just bite the bullet and spend a little more on a decent one. This $200 was definitely not worth it!
