AAXA Pico+ MAX vs AKASO vs TMY: Which Popular Mini Projector Excels in Wireless Mirroring?
AAXA Pico+ MAX Mini Projector​
AKASO Mini Projector​
TMY Ultra Mini Projector​
$184.99​
$239.99​
$127.49​
Indoor​
Home Cinema, Gaming​
Rechargeable Battery, Built-in Speaker, Remote Control, Tripod, HDMI & Micro USB Cables, Projection Lens Cover​
Adaptor, User Manual, Remote, HDMI Cable, Cleaning Kit​
Brightness: 100 LED Lumens
Resolution: 1080p HD (1920x1080)
LED Lifespan: 25,000 hours
Input Interface: Mini-HDMI, 3.5mm Audio Out, Bluetooth Audio Output, Composite A/V, Micro SD, USB (up to 512GB)
Wireless Connection: Direct Wireless Screen Mirroring (Android/iOS compatible, excludes DMCA content)
Battery: 2.7 Hour Built-in Rechargeable Lithium-ion Battery
Projection Type: Pocket projector
Screen Size: Up to 150” adjustable
Connectivity: Micro USB, USB, HDMI, AV, Micro SD, wireless mirroring (Airplay, EZCast)
Brightness: 50 Ansi lumens
Lamp Life: Up to 30,000 hours
Resolution: Supports 1080P
Contrast Ratio: 1000:1
Portability: Compact, lightweight, built-in rechargeable battery (up to 2.5 hours)
Included Accessories: Remote control, tripod
Limitations: Cannot mirror copyrighted content from services like Hulu and Netflix; best used in dark environments.
Projection Technology: DLP
Brightness: Good
Image Quality: Clear, no fuzzy edges
Battery Capacity: 5000mAh
Playback Time: 3.5 hours
Charging Options: Compatible with power banks
WiFi Connectivity: 5G
Connectivity Options: HDMI, MicroSD, USB
Audio Enhancement: Bluetooth speaker connectivity
Unboxing Experience​
AAXA Pico+ MAX Mini Projector:​
The AAXA Pico+ MAX Mini Projector has a compact design that makes it portable and easy to handle. Its small size is especially appealing for those like me who want to use it in tight spaces for projects like cookie decorating. However, the overall aesthetic feels somewhat basic, and while it’s functional, it doesn’t particularly stand out in terms of style.
AKASO Mini Projector:​
The AKASO Mini Projector is impressively compact and lightweight, making it easy to carry and set up in various locations around my home. Its size is comparable to my iPhone, which is a huge plus when considering portability. The design feels sturdy, and the button layout is intuitive, although I sometimes found the side placement of the buttons a bit inconvenient when mounted on a tripod. Overall, it looks sleek and modern, fitting seamlessly into my tech collection.
TMY Ultra Mini Projector:​
From the moment I unboxed the TMY Ultra Mini Projector, I was struck by its sleek and compact design. It fits comfortably in my hand and is lightweight enough to carry around in a bag or even a pocket. The build quality feels solid, and the modern aesthetic is appealing, making it a nice addition to any entertainment setup.
N/A - 3E+1 Inches​
38 Inches - 130 Inches​
3.3 Feet - 10 Feet​
5 - 0.5 Meters​
1000:1​
> 1000:1​
1920x1080 Pixels​
360 x 640 Pixels​
720 x 480​
640 x 360​
100 lumen​
50 lumen​
DLP​
DLP​
DLP​
Vibrant Color Technology​
[Unknown]​
DLP​
The viewing experience varies significantly based on the usage scenario. While it does project images well for cookie decorating, the picture quality can be inconsistent. I’ve noticed color issues, such as a purple tint, and the brightness is not always adequate in well-lit environments. Additionally, I’ve faced problems with the focus wheel, making it difficult to achieve a clear image. For anything beyond decorating, like watching movies, I wouldn’t recommend it due to these shortcomings.
The viewing experience with the AKASO Mini Projector has been varied. In well-lit conditions, I found that projecting onto darker walls yielded better results than on lighter colors. While playing games or watching videos with large text, the image quality was decent, but I noticed that smaller text sometimes became difficult to read. The overall picture clarity is satisfactory for casual use, but I wouldn't recommend it for those with high expectations for image quality, especially when dealing with dark scenes where details tended to get lost.
The viewing experience has been impressive overall. The picture quality is vibrant, with colors that pop and a decent resolution, especially for such a small device. I've used it in different lighting conditions, and while it performs best in dark environments, it still holds up well in dimly lit spaces. The size of the projected image is quite large, especially when I place it just a few feet away from the wall, making it great for movie nights or presentations.
Pico​
Built-In Wi-Fi​
Built-In Speaker, Portable, Lightweight, Ultra Short Throw, Wi-Fi Ready​
AVC​
MP4​
25000 Hours​
20000 Hours​
Button Control​
Button Control​
HDMI
USB, HDMI
Smartphone​
Laptop, Smartphone, Tablet, Gaming Console​
24 watts​
15 watts​
Mount Type​
Tripod Mount​
Tripod Mount, Tabletop Mount​
Tabletop Mount/Ceiling Mount/Floor Mount/Tripod Mount​
6.49"L x 3.07"W x 0.86"H​
5.51"L x 2.71"W x 0.62"H​
3.78"L x 3.38"W x 1.14"H​
Setting up the AAXA Pico+ MAX is relatively straightforward, even for someone like me who isn’t particularly tech-savvy. I found it easy to connect to my iPhone wirelessly, which was a huge plus for my cookie decoration needs. However, the requirement to frequently check the battery and keep it plugged in, due to its short battery life, can be a bit of a hassle. Plus, I encountered some compatibility issues with other devices, which added to the frustration.
Setting up the projector was generally straightforward, although I encountered some hiccups, particularly with wireless connectivity. While the HDMI connection worked flawlessly, I faced challenges when attempting to connect via AirPlay and other wireless methods—this often required a tedious setup process. The included manual could use more detailed instructions, especially regarding connecting to different devices, which left me relying on trial and error. Despite these challenges, I appreciated the option to connect via USB and HDMI, and the addition of a remote control for easier navigation.
Setting up the projector was a breeze, thanks to its user-friendly interface. I was able to connect it to various devices such as my smartphone and streaming sticks via HDMI and USB without any hassle. The projector also supports wireless connections, although I did encounter some difficulties with screen mirroring from my iPhone due to copyright limitations. Once I switched to using an Apple TV or Fire TV Stick, everything worked seamlessly.
• Compact and portable design
• Easy wireless connectivity with iPhone
• Good for cookie decorating, projecting templates clearly
• Straightforward setup process
• Short battery life, requiring constant charging
• Inconsistent image quality with color issues
• Difficult focus wheel makes adjustments challenging
• Sound issues, with poor quality or no sound at all
My overall impression of the AAXA Pico+ MAX Mini Projector is mixed. While it serves its purpose for cookie decorating by allowing me to project templates effectively, I’ve been disappointed with its overall performance and durability. The frequent charging requirement and image quality problems detract from its usability for other applications. If you’re looking for a projector for anything beyond simple tasks like cookie decoration, I would recommend investing in a more reliable model.
• Compact and portable design.
• Easy to set up with HDMI and USB connections.
• Good battery life, lasting several hours.
• Wireless connectivity works well for certain devices.
• User-friendly interface with remote control.
• Ideal for casual movie nights and art projects.
• Wireless connectivity setup can be frustrating.
• Image quality can be poor with dark scenes.
• Remote control response lag can be annoying.
• Inconsistent performance with smaller text and detailed images.
• Sound quality is lacking; external speakers recommended.
The AKASO Mini Projector has proven to be a versatile tool for both entertainment and creative projects, especially for cookie decorating and casual movie nights. While it has its share of limitations—particularly in image quality and connectivity issues—it remains a useful gadget for those who value portability and ease of use. Given its compact size and decent performance, I feel it’s worth the price, but potential buyers should have realistic expectations about its capabilities, especially if they prioritize high-quality image output.
• Compact and lightweight design for portability.
• Easy to set up and connect to various devices.
• Good picture quality with vibrant colors.
• Supports battery operation for outdoor use.
• Versatile connectivity options, including HDMI and USB.
• Great value for the price.
• Built-in speaker lacks volume and quality; external speakers are recommended.
• Some difficulties with wireless screen mirroring, particularly with iOS devices.
• Requires frequent refocusing during initial use until it warms up.
The TMY Ultra Mini Projector has exceeded my expectations in many ways. It combines portability, ease of use, and decent picture quality in a compact package, making it an excellent choice for both indoor and outdoor use. While it has some minor drawbacks, such as the sound quality and the need for external devices for best performance, the overall value it offers makes it a worthwhile investment for anyone looking for a small yet capable projector. I would highly recommend it to anyone in need of a versatile projector for home entertainment or travel.
Elfman72
El proyector AAXA Pico+ MAX es genial, dura hasta 2 horas de batería, así que puedes ver una peli completa. La imagen se ve bien tanto de cerca como de lejos. Tiene un modo espejo que es perfecto si tienes poco espacio. Eso sí, si hay mucha luz, la imagen no se ve tan bien. Es ideal para hacer proyecciones en pasteles y galletas. Te sugiero usarlo con un altavoz extra porque el que trae no es muy potente.
AwesomenessDjD
Check out the TMY Ultra Mini Projector! It's super tiny, fits in your palm, but packs a punch with crystal-clear 1080P video and bright colors that make movies pop. Setting it up is a piece of cake, and it connects easily via Bluetooth, HDMI, USB, and works with TV sticks too.
The sound is surprisingly good for its size, so you might not even need extra speakers. Plus, it runs for 3 hours on battery, making it great for movie nights or quick presentations. If you love watching stuff, I totally recommend this little gadget!
MsPippiton1117
I got the AAXA Pico+ MAX Mini Projector to up my cookie decorating game. I almost went for the old model since it was cheaper, but then I realized I’d have to buy extra cords for my iPhone, which was a bummer. Then I found out they dropped a WIRELESS version that was still pretty affordable! So, I snagged it the day it launched. I was a bit worried since I'm not great with tech, but connecting it to my iPhone was super easy. It’s perfect for decorating cookies!
