AAXA P6X vs TMY Ultra Mini vs AKASO WT50: Which Mini Projector’s Built-in Cooling System is Right for You?
cruets620
AAXA P6X Projector​
TMY Ultra Mini Projector​
AKASO WT50 Mini Projector​
$299.99​
$127.49​
$269.99​
Home Cinema, Gaming​
Adaptor, User Manual, Remote, HDMI Cable, Cleaning Kit​
360° rotatable support bracket, possibly others​
USB-C Input: Direct mirroring for iPhone 15 & 16, Android, Macbooks, and other devices; also serves as a charging port.
Weight: 1.8 lbs; portable for travel and camping.
Bluetooth Enabled: Connects to external speakers; includes internal speaker.
Wireless Mirroring: WiFi enabled for streaming from iOS and Android; DMCA content restrictions apply.
Brightness: 1000 Lumens (battery), 1100 Lumens (plugged in); projects up to 160” at Native WXGA HD resolution and supports 1080p.
Connectivity: HDMI, MicroSD, USB, Bluetooth
Audio: Compatible with Bluetooth speakers
WiFi: 5G WiFi connectivity
Weight: 0.53 lbs
Battery: 5000mAh, 3.5 hours playback
Portability: Compatible with power banks
Dimensions: 5.7 x 3.1 x 0.79 inches
Weight: 0.64 lbs
Battery: 5000mAh, approx. 2 hours projection
Operating System: Android 9.0
App Support: Over 3 million apps from Google Play Store
Control Options: Remote control and touchscreen panel
Projection Technology: DLP (0.2DMD Optically processed chip)
Image Quality: Clearer than LCD, high brightness, richer colors, no pixelation or "screen door effect"
Keystone Correction: Automatic
Unboxing Experience​
AAXA P6X Projector:​
The AAXA P6X Projector impresses with its compact size, making it easy to transport and set up. Out of the box, it is smaller than expected, which is a pleasant surprise for anyone looking for portability. Its design is sleek and modern, allowing it to blend seamlessly into various environments, whether for home use or outdoor movie nights. I appreciate that it not only serves a functional purpose but can also act as a stylish piece of decor when not in use.
TMY Ultra Mini Projector:​
The TMY Ultra Mini Projector is a sleek, compact device that impresses with its palm-sized design. I appreciate how lightweight it is, making it effortlessly portable for travel or outdoor use. Its modern aesthetics blend well with any environment, easily fitting into a travel bag or even my pocket. The build quality feels solid, further enhancing its appeal as a reliable gadget for home or on-the-go entertainment.
AKASO WT50 Mini Projector:​
The AKASO WT50 Mini Projector has a compact design, about the size of a Samsung Note but a bit thicker, making it highly portable. It feels sturdy and well-built, which is a pleasant surprise considering its small footprint. The sleek finish and lightweight nature allow it to easily fit into a backpack or luggage, making it a great choice for on-the-go use. I appreciate the inclusion of a quarter-inch mounting screw which allows compatibility with standard tripods, adding to its versatility. Overall, it exudes a modern and practical aesthetic that aligns well with my expectations for a mini projector.
AAXA P6X Projector​
10.9 Inches - 160 Inches​
3E+1 Inches - 120 Inches​
5 - 0.5 Meters​
N/A - 13.78 Feet​
> 1000:1​
[Probably at least] 1000:1​
1920x1080​
360 x 640 Pixels​
1280 x 800​
640 x 360​
1000 lumen​
50 lumen​
DLP​
DLP​
DLP​
DLP​
DLP​
The viewing experience with the P6X is quite impressive. Even in bright rooms, I was able to enjoy clear and vivid images, which is a significant improvement over other projectors I've tried. While colors like greens and yellows can appear a bit exaggerated in factory settings, the overall color reproduction is good. Watching content at night transforms the experience entirely, delivering bright, vibrant, and sharp images. The projector is not 4K but displays at 1080p, and I found it sufficient for casual movie nights and presentations. However, the image quality can suffer with darker content in well-lit environments.
After using this projector in various lighting conditions, I can confidently say that it performs exceptionally well, especially in dimmer environments. The picture quality is impressive for its size, with vibrant colors and clarity that enhance the viewing experience, even though it may not match the quality of larger, more expensive projectors. The ability to project a sizeable image on my wall without needing to be far away is a significant advantage, and it has worked well for both movie nights and casual presentations.
- Compact and portable design
- Easy setup and connectivity
- Good picture quality in various lighting conditions
- Versatile usage options (HDMI, USB, Bluetooth)
- Built-in speaker lacks volume and quality
- Requires frequent focusing during initial use
- Limited battery life for continuous use
The viewing experience with the AKASO WT50 has been impressive, especially considering its size. The picture quality is crisp and clear even in less-than-ideal lighting conditions, with the ability to project images up to 15 feet diagonally without any significant distortion. I found that the resolution holds up well, although the brightness can be a bit lacking in daylight, requiring near-complete darkness for optimal performance. The projector has been great for various uses, from movie watching to projecting images for art projects, which has been immensely helpful for tracing and designing. While the sound quality is decent, I often opted to connect external speakers for a better audio experience.
AAXA P6X Projector​
Ultra Portable, Built-in 4 Hour Battery, Wireless Screen Mirroring​
Built-In Speaker, Portable, Lightweight, Ultra Short Throw, Wi-Fi Ready​
Portable, Digital Keystone Correction, Lightweight, Built In Wi Fi, Short Throw​
MP4​
MP4, AVC​
4 Watts​
30000 Hours​
30000 Hours​
Button Control​
Button Control​
Touchpad Control​
Touch​
HDMI, USB-C Video-In (Direct Smartphone Mirroring)​
Wi-Fi, USB, HDMI, 3.5mm Jack​
Laptop, Smartphone, Windows PC, HDMI devices, USB-C devices, Composite AV devices, Bluetooth speakers​
Smartphone, Gaming Console, Laptop, USB device, HDMI device​
4 watts​
15 watts​
Mount Type​
Tabletop Mount​
Tabletop Mount/Ceiling Mount/Floor Mount/Tripod Mount​
Tabletop Mount​
6.25"L x 6.2"W x 1.85"H​
3.78"L x 3.38"W x 1.14"H​
5.71"L x 3.15"W x 0.79"H​
Setting up the AAXA P6X is straightforward and intuitive. I had it up and running within 10 minutes, thanks to clear instructions and all necessary accessories included in the package. The projector features a stable focus wheel and electronic keystone correction, which enhances the experience significantly, especially for presentations. However, it lacks built-in streaming apps and wireless capabilities, which can be a drawback for those looking for a more integrated smart experience. For streaming, I found that using an external device like a Fire Stick works well, and it can even draw power from the projector’s USB port.
Setting up the TMY Ultra Mini Projector is a breeze, thanks to its intuitive user interface and straightforward controls. I found it easy to connect it to various devices using the HDMI, USB, and Bluetooth options available. The projector quickly pairs with my smartphone for screen mirroring, and I had no issues getting it up and running within minutes. Overall, the setup process has been hassle-free, allowing me to focus on enjoying my content rather than dealing with complicated configurations.
Setting up the AKASO WT50 was relatively straightforward, although I encountered some initial confusion regarding the installation of apps and connections. I was able to connect it to my devices, but the process wasn't seamless—particularly with the built-in apps like Disney+, which I could not download. Thankfully, the projector supports HDMI and USB connections, providing some flexibility. While I had some trouble with the remote control, the option to use my phone as a remote via the EShare app was a nice touch once I got it configured. Overall, it took a bit of trial and error, but I was able to get everything working adequately.
• Very bright for its class
• Decent picture quality
• Good input options
• Easy setup and portability
• Affordable price point
• No wireless options
• Lack of built-in apps
• Limited functionality and archaic tech
• Built-in speakers are just okay
Overall, the AAXA P6X Projector is a solid choice for anyone seeking a portable and bright projector at a reasonable price. Its compact design, ease of use, and good image quality make it a great option for both casual movie watching and presentations. While it does have its shortcomings—like the absence of smart features and a somewhat basic interface—the performance and portability make it a worthwhile investment. I can see myself using this projector for various purposes, from outdoor movie nights to casual presentations, making it a great addition to my tech collection.
The TMY Ultra Mini Projector has exceeded my expectations with its impressive performance, portability, and user-friendly features. While there are minor downsides, such as the speaker quality and the need for manual focusing initially, these are easily manageable given the projector's overall value. It is an excellent choice for anyone seeking a compact and versatile projector for home use, camping trips, or presentations. I highly recommend this device for those looking for an affordable yet effective solution for their entertainment needs.
• Clear picture quality, even in moderate lighting.
• Highly portable and lightweight, easy to carry.
• Good battery life for short usage, around 3-4 hours with Bluetooth.
• Comes with a mini tripod for easy setup.
• Customer service is responsive and helpful.
• Remote control can be slow and requires direct aiming.
• Battery life is limited to about an hour for continuous use.
• Some built-in apps may not work properly, like Disney+.
HDMI connectivity has some limitations with audio.
• Can't turn off the lamp separately without powering down the unit.
My experience with the AKASO WT50 Mini Projector has been largely positive. Despite some initial hiccups with setup and connectivity, the projector delivers on its promise of portability and decent picture quality. It's versatile enough for both entertainment and practical applications like art projects, but the limitations with battery life and certain app functionalities are worth noting. Still, at its price point, I feel it offers solid value, especially for users who need a compact projector for specific tasks. The exceptional customer service also adds a layer of reassurance, making it a recommended choice for those in search of a mini projector.
El_Frijol
Just got the AAXA P6X Projector and wow, it's awesome! The video and sound are top-notch, plus it has built-in speakers that sound amazing. It even has a rechargeable battery that lasts up to 4 hours in Eco mode! Super portable and easy to take anywhere. Comes with a power adapter, tripod, remote, and AV cable, plus USB and Micro SD inputs. Definitely recommend this little powerhouse—great bang for your buck!
yodathekid
AKASO WT50 Mini Projector is awesome! Just what I needed. It fits in my backpack, so I can bike to the woods and chill while watching something.
pricelesslambo
I got the AAXA P6X Projector thinking it would be a cool upgrade from my old AAXA Pico for my gigs. But seriously, it only plays AVI? What year is it, 2005? My old projector even handled .mp4! Why sell a projector that’s stuck in the past? Even Handbrake ditched AVI! What should’ve been a sweet buy just turned into a headache.
yodathekid
So, I just checked out the AKASO WT50 Mini Projector, and honestly, I’m still figuring out what to rate it. Here’s the scoop: it’s a tiny powerhouse with great brightness and contrast for its size—way better than my old $100 no-name projector.
Now, the tech side: even though it’s 1080p, it looks a bit pixelated compared to my old LCD. Plus, the automatic keystone correction is fab, but it doesn’t work with HDMI, which is a bummer. And the Android system? Super dated, so lots of apps just don’t cut it. I ended up using a Chromecast, but that’s a hassle.
The remote? Ugh, it’s a pain. You have to aim it just right and push hard for it to work. I just wanted it to turn on with my smart home stuff, but nope, gotta grab the remote every time.
In the end, it’s a solid little projector, but it doesn’t beat my current setup, so I’m sending it back. If it had matched my old one’s features and was portable, I’d keep it. I’d say it’s a three-star deal. I wish I could give it a lower score to be fair, but I’ll stick with three.
