Mialulu
TV brands Vizio, TCL and Samsung are very popular in the market due to the features they offer. Each of these TV brands has a variety of models to meet the budgets and needs of different buyers. Here's a comparison of three different brands of 65-inch 4K TVs for you to see which one is better for you.
1. Appearance
These three TVs have their own characteristics and also have something in common, for example, they all have a solid stand and a wonderful look. From the side, the TCL is thicker, the Samsung is thin and light on top and thick on the bottom half, while the Vizio looks to have a curved screen that makes it look more special.
2. Speaker
All three TVs have TV tuner and built-in speakers, but they have different speaker power, so they will offer different levels of volume and sound quality. As you can see from their spec sheets, TCL is 16W, Samsung is 20W, and Vizio offers 30W of sound.
3. Display
These 60 inches TVs offer the same 4K resolution and Ultra HD, and the difference is that the TCL 65S535 uses QLED display technology, while Samsung and Vizio have the same LED technology. Different display technologies do bring different viewing experience, you can refer to QLED vs LED. Also, TCL supports Full HD, but Samsung and Vizio do not support that feature. Also, for Refresh Rate which is very important for gaming, Vizio P65Q9-H61 is better here because it offers 120Hz while TCL 65S535 and Samsung TU8300 only have 60Hz.
4. Connection
TV connectivity is also very important to the user. They both have more than enough HDMI ports, but Vizio does not have WIFI connectivity, while the other two TVs do. samsung does not have Bluetooth connectivity, while the other two do. So, if you want a TV that can connect to wireless networks, this Vizio is not quite right for you. If Bluetooth connectivity is very important to you, don't pick this Samsung TU8300.
If you are looking for a 4K 65inches TV, there are many brands and models on the market. The above TVs are good choices for they offer good performance. Also, they have their own features, choose the one right for you.
Product Name | TCL 65S535 | Samsung TU8300 | Vizio P65Q9-H61 |
Screen Size | 65 inches | 65 inches | 65 inches |
Resolution | 4k | 4k | 4k |
HDMI | 4 | 3 | 4 |
Speaker power | 16W | 20W | 30W |
Display type | QLED | LED | LED |
Wi-Fi | YES | YES | NO |
TV tuner | YES | YES | YES |
Bluetooth | NO | YES | NO |
Full HD | YES | NO | NO |
Weight | 41.90 pounds | 56.00 pounds | 55.12 pounds |
Smart TV | YES | YES | YES |
Refresh Rate | 60 Hz | 60 Hz | 120 Hz |
Ultra HD | YES | YES | YES |
Dimensions | 56.9 x 11.6 x 34.9 inches | 4.8 x 57.2 x 33 inches | 57.01 x 11.81 x 35.14 inches |
1. Appearance
2. Speaker
3. Display
4. Connection
